ultrarunner
Epic Contributor
- Joined
- Apr 6, 2004
- Messages
- 29,171
- Tractor
- Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
1 - No realizes that in general, if you can find a OEM compressor past 15 years in age for replacement, you'll be lucky.
2 - No one reads the "pro rated" fine print in lieu of a new compressor per #1.
3 - No one understands the R410A, just like R22 is being phased out, and that compressor are dependent on both speficiffic refrigerant along with oil.
4 - No one generally takes into account the ratio between volume of the coil surface area between the indoor and outdoor coil to achieve SEER rating and that genearlly, manufacturers require new comonents to current systems still be AHRI rated.
5 - No one understands the pro rated part about needing a WHOLE new system "under warranty" due #3 and #4
6 - No one understands that the lifetime compressor warranty does NOT include labor.
7 - No one understands the fine print about who is doing in the install and how the equipment is bought (being enforced more and more now due to internet sales).
Just because something is mandatory by the government doesn't mean everyone is going to do it![]()
At one of the buildings I have 14 Carrier Package units of various sizes... some with two compressors most with economizers... economizers have been a problem.
Of the lot 11 are still running the original compressors... all installed in 1995...
On my 100% outside air handler there are two large compressors... the small one was replaced under warranty within 30 days of start-up and again replaced at year 21... the larger one has been running/cycling 24/7 since 1995... did have one coil repair... but so far so good.
In 2010 I was told equipment was on borrowed time... the built up unit runs a lot to keep Operating rooms at 66-68 with 100% outside air.
Some of my medical vacuum pumps which also run 24/7 have more than 60,000 hours with only oil and filter changes... BUSCH pumps... Germany I believe.
I just wish my Heat Pump in Olympia was as reliable!
Not sure if it is a longevity factor but most equipment is 3 phase 480v
