1947 Ford 2N teardown
/ 1947 Ford 2N teardown #1
slim357
Ford 4110
well, I purchased this 1947 ford 2N for 600$ and have been tearing it apart one piece at a time when I have time and today I just got the oil pan off and it looks like this tractor hasn't had a thing done to it since 1947. DSCF0473.JPG
/ 1947 Ford 2N teardown #2
well, I purchased this 1947 ford 2N for 600$ and have been tearing it apart one piece at a time when I have time and today I just got the oil pan off and it looks like this tractor hasn't had a thing done to it since 1947.View attachment 628768
Probably not worth your effort.
Looks quite bad!
/ 1947 Ford 2N teardown #3
Seen worse as when a block is cracked or imploded...
Is there enough to bore oversize... sometimes the bearings can be saved...
/ 1947 Ford 2N teardown #4
Seen much worse than that brought back to life, in fact my SIL and I just brought back a Ford 640 we got for $200 that looked not much different. Give it a good cleaning, put in new sleeves, crankshaft turned and valves reground/seated it will run again. These old Fords are a lot like Briggs engines, if ya cannot make one run it is time to turn in your man card.
/ 1947 Ford 2N teardown #5
look at yesterdaystractors.com for parts and advice. all 8n parts will work when i did mine on a 9n.
I am hoping it has sleeves.
/ 1947 Ford 2N teardown #8
Appears it does have sleeves according to the list of rebuild kits listed on the website yesterdays tractors dot com.
I think you will find more information on your tractor there than you will here.
/ 1947 Ford 2N teardown #9
$600 ..... plus parts?
What is a repaired 1947 Ford 2N worth?
I consider my 1951 8N, in excellent overall condition, with completely rebuilt engine, and a Sherman transmission, to be worth maybe $2000+ ?
/ 1947 Ford 2N teardown #10
I've got double that in the Jubilee... but it's like a new tractor... fully restored but, alas, no Sherman ;-(
/ 1947 Ford 2N teardown #11
Make a 50/50 mixture of acetone and ATF, fill the cylinders, you are gonna need it.
I would waste some PB Blaster or other oily spray lube on all of the parts in the picture. At least preserve them from further rust.
Surprisingly, plain old vinegar will get a lot of those rusty parts cleaned up with some time.
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
Kubota Z232 (A60462)
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
1143 (A63745)
1143 (A63745)
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
