1947 Ford 2N teardown
   / 1947 Ford 2N teardown #1
slim357
Ford 4110
well, I purchased this 1947 ford 2N for 600$ and have been tearing it apart one piece at a time when I have time and today I just got the oil pan off and it looks like this tractor hasn't had a thing done to it since 1947. DSCF0473.JPG
   / 1947 Ford 2N teardown #2
well, I purchased this 1947 ford 2N for 600$ and have been tearing it apart one piece at a time when I have time and today I just got the oil pan off and it looks like this tractor hasn't had a thing done to it since 1947.View attachment 628768
Probably not worth your effort.
Looks quite bad!
   / 1947 Ford 2N teardown #3
Seen worse as when a block is cracked or imploded...
Is there enough to bore oversize... sometimes the bearings can be saved...
   / 1947 Ford 2N teardown #4
Seen much worse than that brought back to life, in fact my SIL and I just brought back a Ford 640 we got for $200 that looked not much different. Give it a good cleaning, put in new sleeves, crankshaft turned and valves reground/seated it will run again. These old Fords are a lot like Briggs engines, if ya cannot make one run it is time to turn in your man card.
   / 1947 Ford 2N teardown #5
look at yesterdaystractors.com for parts and advice. all 8n parts will work when i did mine on a 9n.
I am hoping it has sleeves.
   / 1947 Ford 2N teardown #8
Appears it does have sleeves according to the list of rebuild kits listed on the website yesterdays tractors dot com.
I think you will find more information on your tractor there than you will here.
   / 1947 Ford 2N teardown #9
$600 ..... plus parts?
What is a repaired 1947 Ford 2N worth?
I consider my 1951 8N, in excellent overall condition, with completely rebuilt engine, and a Sherman transmission, to be worth maybe $2000+ ?
   / 1947 Ford 2N teardown #10
I've got double that in the Jubilee... but it's like a new tractor... fully restored but, alas, no Sherman ;-(
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
(APPROX 20) 3" X 4" X 21 7/8" TUBING (A51247)
(APPROX 20) 3" X...
2015 Infiniti QX60 SUV (A51694)
2015 Infiniti QX60...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
2017 CATERPILLAR 323FL EXCAVATOR (A51246)
2017 CATERPILLAR...
