Vibrator for pulling out bush honeysuckle?
   / Vibrator for pulling out bush honeysuckle? #1
TreeDreamer
Mt. Gilead, OH
M7060, 3046R
I'm covered up in bush honeysuckle, especially along the creeks, roads, and edges of fields. It dominates the understory and doesn't let new trees grow through it. I've sprayed, cut, pulled by hand, even bought a Fransgard V5000 logging winch to pull them out. But everything is a lot of work. Some of them are big enough it is a hard pull with the logging winch or they just break off. Some clumps of 5 or 6 2" stems from a common root wad that are 20' high. Plus there's all that walking back and forth and crawling under in the briars to hook chokers.
So I've been daydreaming at work about some kind of hydraulic grabber, like a tree puller, to mount on the loader. Since most are along roads and fields, I'm hoping I could just reach in, grab it and lift/curl it out. I could rock and and forth but would likely get a facefull of tops. I know all of the bigger ones won't come out with the loader lift alone. So I considered a diverter on the 3rd function to put a cylinder on it to push against the ground for 15 or 20 tons of lift (similiar to a log splitter), one function of the 3rd function to clamp, one to push up.
Today I started wondering if instead of augmenting my miniscule lift, maybe 1500# at waist high after the weight of the device, it would be easier if I put a vibrator, like a truck bed or bin vibrator or better like a vibratory post driver/puller vibrator. If I could get a vibrator to vibrate the tree I'm guessing it'd be a huge help. If...
So a couple of questions, I have mid- and rear PTOs so I could rig a generator or additional pump to run a vibrator but I don't know what kind, air, electric, or hydraulic. Are there vibrators that just vibrate up and down instead of around a plane like the truck bed type? I'm guessing that a vibrator vibrating a honeysuckle parallel to the ground would be of little help, I think I need it vibrating up and down the trunk to do much good. Also, best way to mount it so it doesn't unduly vibrate the device/loader but instead puts much of its energy into the honeysuckle. And finally, do I vibrate where I grip it, and hopefully grip it low, or do I vibrate against the stump or root wad regardless of where I grip it?
Thanks,
Mark
   / Vibrator for pulling out bush honeysuckle? #3
We had some of that invasive honeysuckle on our place. I found the best way to get rid of mine was to cut it off at the base then paint the cut stumps with straight 2 4-D amine. It has never come back from this. The stumps rot out pretty quick.
   / Vibrator for pulling out bush honeysuckle? #4
What I have is Russian olive. The Danuser Intimdator grapple works great. I can pull roots without breaking off the tops. Works great for multiflora rose and hedge privet too. Uses not just the loader lifting power but the tractor force driving forward or back. Excavator teeth up front for bigger stuff. Handy for a small Kubota b26 but can handle big trees with the m59. Use other root grapples, piranha bar, and bush hog too and have their advantages. The Intimdator can work close to buildings, fences, under fences, over fences, road banks, next to trees with minimal soil disturbance. Sure has helped cleanup and maintained our property. Work force multiplier for an older farmer.
   / Vibrator for pulling out bush honeysuckle? #5
A trackhoe 12,000 lbs and larger is great for removing that stuff, pluck it, stack it, burn it.
   / Vibrator for pulling out bush honeysuckle? #7
We've been pushing a lot of bush honeysuckle out with a Piranha toothbar on the loader bucket. My bushes are big like you've described. Bush honeysuckle doesn't have a deep root system thankfully. If it's not a problem for you to push it back into piles, the toothbar is a fairly cheap route that works well, and doesn't rely so much on the FEL lift capacity. Hit the base of the bush up a foot or two off the ground so you have more leverage, drive forwards to uproot it, and back up to drop the bucket to snag the the root ball if needed. My experience has been that the drier the soil conditions; the better. If its fairly dry, the roots don't pull up much dirt at all. If its wet and gummy though, a lot more dirt pulls up with the root ball. I liked the tooth bar approach better than the grapple I tried. Although the grapple is great for piling them up if you need to after you rolled them out with the bucket. I've eyed that Danuser Intimidator before, I like the looks of it, but I think a guy might struggle a little more pulling stuff out with a compact tractor, than using a track loader with the Intimidator. It's also pretty pricey for me for the 10 acres or so I need to clean up. The tree grapple/puller with the lifting cylinder listed above is a novel approach, should theoretically be able to pull much more out of the ground with a lighter weight machine. Probably overkill for the shallow-rooted bush honeysuckle I have in my parts though. The tooth bar pushing/uprooting first, with the Wicked root rake grapple used next to pile it up to burn has been the most efficient method for me so far with the equipment I have available.
A guy could also look into renting or hiring a forestry mulcher to clean it all up in short order, I'm just not sure about it sprouting right back up from the roots left in dirt that don't get ground up by the mulcher. My plan is to brush hog and spray as needed to keep it in check once I get the property all cleaned up.
   / Vibrator for pulling out bush honeysuckle? #8
This is what we do here with oriental bittersweet. Get yourself a dauber. Online, they're called "Blackthorn (or buckthorn) Blaster". They're just a plastic bottle with some shoe-polish-like dauber on the end in place of the cap that it's shipped with. Just cut and IMMEDIATELY daub. No spilled "paint" and the like.
Can also get a flail mower and go after them. Then daub or spray the greenery that comes back from the roots. The neighbor next door used a Cat with a flail mounted on front.
Web site for the dauber: landscape-restoration.com/product/
Ralph
   / Vibrator for pulling out bush honeysuckle? #9
Mark, welcome to TBN.
I'll just chime in with this tidbit- I've heard that operating a hydraulic jackhammer is hard on heavy construction equipment because the frame has to take all that impact as well. Granted that your vibrator is no jackhammer, but a compact tractor is no brick outhouse.
Thanks guys, building another storage barn now so will have to wait for spring but I like the looks of that Intimidator. I have a lot of honeysuckle growing in with trees I don't want to damage, it looks like it might get in and pick off ones and twos without touching other trees.
2016 Morbark Chipper (A55787)
2016 Morbark...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
MAHINDRA 3650P TRACTOR (A58375)
MAHINDRA 3650P...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
