7060 R1W tires
/ 7060 R1W tires
Showed up today with the big meats on it!
/ 7060 R1W tires #25
Those bigger dirt scratchers really look great, much better proportions than the tall & skinnies of the past. Look's good fella's.:thumbsup:
/ 7060 R1W tires #26
I was looking at the same set of tires and cast rims to order on my M7060 next week. The dealer was trying to tell me I could get the same weight on the rear end cheaper if I just put the regular rims with add on weights.. I am still thinking of sicking with the cast rims.. I am not getting a FEL right away.. but want to get some weight for disking, plowing and other ground engaging implements .. Any reason not to get the cast rims ?
/ 7060 R1W tires
I’m pretty sure I didn’t get charged anymore for the cast rims than the stamped ones. I would def go with cast if you want the most weight. I believe your dealer may be wrong. The cast wheels weigh way more than you could ever add weight to the stamped ones.
/ 7060 R1W tires #28
Only cost. Cast centers are an extra cost option.
I specified cast centers on my M9960 and wouldn't have it any other way.
SDT
/ 7060 R1W tires #29
SDT
Same here, ordered mine with the cast centers, no regrets.
/ 7060 R1W tires #30
Mine came in this week went with the LSW radials with cast centers
/ 7060 R1W tires #33
Western NC
I was curious because of the limitation JHurt had when getting his R1W tires. He was limited to 20" on the front with simple reversible wheels. Yours appear to be 24" with multiple adjustment wheels?
/ 7060 R1W tires #34
I actually thought that was what I was going to get... When I ordered it the week before thanksgiving. I said I wanted Radial tired with cast rears and the width of the tractor to be around 77 inches ( To work with the implements I already have) And to make sure the front tires are in the same tracks as the rears. I puled up to the dealership on Friday and that is what was there lol And am tickled to death lol It may be because these are the Goodyear Low Side Wall (LSW) tires that require a larger rim.
I spoted this new you tube vid seams to have the same tires only set up for a different width.. and most of the tires on the lot in that vid have the same setup Kubota M76 4x4 Cab Tractor - YouTube
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
KUBOTA LA354 FRT LOADER ATTACHMENT (A62130)
KUBOTA LA354 FRT...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
2013 John Deere 8360RT Track Tractor (A63109)
2013 John Deere...
(2) 18.4-38 TIRES W/SPACERS (1) 18.4-38 TIRE (A62131)
(2) 18.4-38 TIRES...
