Pallet uses, for storage etc...
/ Pallet uses, for storage etc... #1
Beezz27
Gastonia, NC
2013 Kioti DK40SE HST, 1975? Ford 3000
This may seem like an easily answered question but I always am inspired by you TBN member's creativity. So what all do you store on pallets to be moved and/or what do you use pallets for or make with them for storage. I just got a set of forks for my tractor and am looking for all the pallet storage ideas possible! I have already stacked up all the loose bricks laying around and certainly have plans to stack a few pallets with fire wood but what else? 20191026_125100.jpg20191026_115148.jpg
/ Pallet uses, for storage etc... #2
Some people use them for 3 pt implements, then stack them on racking.
I just use them for firewood.
/ Pallet uses, for storage etc... #3
Tractor attachments,wood,items that won't be use for while just get off the dirty damp ground.
/ Pallet uses, for storage etc... #4
My buddy put all his implements on pallets with wheels, yes I said witHis pole barn has a concrete floor, so he just rolls over the one he wants and hooks it up, no need to move the tractor
/ Pallet uses, for storage etc... #5
You'll find forks WAY more handy than a bucket and will likely end up with them on the front most of the time. I use mine for all kinds of things....the hinged top on this hog house for example.....lift it up to clean out between pigs, and move the whole house different places.
enhance
Feed storage shed holds 4 - 55gal drums of feed in the dry, and mostly bear resistant:
enhance
Feed shed in place, 1/2 a 10" PVC pipe for feed trough:
enhance
Miller welded permanently mounted on frame with casters to roll around in the shop, and to take out for various repair/projects/generator needs around the farm.
enhance
Move lumber.....set a whole bunch on saw horses at a time:
enhance
Move baskets of firewood into the shop and greenhouse:
enhance
enhance
Wood tool carrier holds all kinds of tools/chainsaws/etc
enhance
Pc of 6" PVC pipe mounted against back wall of it to hold shovels/etc.
enhance
Haul firewood out of the woods, pile to saw up: (beat cutting in little rounds in the woods, loading into bucket, THEN hauling out !)
enhance
I store quite a bit of gas/diesel, and use these custom made wood pallets to easily move 55gal drums:
enhance
Move saw logs around the mill yard, load the log deck, take slabs to burn pile, move finished lumber into sheds:
enhance
enhance
enhance
And finally, pick up the roll-around trash cart at the house, take it to the road for weekly pickup !
/ Pallet uses, for storage etc... #6
Just be careful not to try and carry a long long through the woods with them. The log might get caught on a tree and twist to quickly to stop it from bending one of the forks. Now I gotta bend it back.
/ Pallet uses, for storage etc... #7
NOTHING I have sits on the ground. Firewood, implements, bricks, old wood stoves - everything sits on a pallet, not on the ground, even if inside my pole barn.
/ Pallet uses, for storage etc... #8
For firewood I find IBC totes are far superior to pallets. But my tractor has the lift capacity to handle them.
Pallets and/or HF dollies are used for all my attachments.
/ Pallet uses, for storage etc... #9
Have I ever told y'all how much use TnAndy find's for his fel? ;)
/ Pallet uses, for storage etc... #10
And that is just some of them....ahahahaaaaa.
If you move both forks together, it makes a pretty good digging spade as well ! Long as the ground isn't too hard, you can plan shrubbery, or slip them under rows of sweet potatoes so the wife has them right up at waist high to harvest......make her quite happy not to have to do all that bending. :D
enhance
/ Pallet uses, for storage etc... #11
Fire starter! Put a couple of pallets under a brush pile, stuff a bunch of crumpled newspapers inside, one match does it. No starter fluids required. Pallets for roofing shingles work great. All thin softwood slats.
I save the good solid oak HD pallets for storing implements on pallet racks.
/ Pallet uses, for storage etc... #12
This may seem like an easily answered question but I always am inspired by you TBN member's creativity. So what all do you store on pallets to be moved and/or what do you use pallets for or make with them for storage. I just got a set of forks for my tractor and am looking for all the pallet storage ideas possible! I have already stacked up all the loose bricks laying around and certainly have plans to stack a few pallets with fire wood but what else?View attachment 626802View attachment 626803
All of our hay goes on pallets, lean one (or ten) against a wall for a vertical garden space. either hook grow containers on or fill with dirt and plant. Get pallet racking and store all your tractor stuff on pallets. Put the walk behind tiller or mower on a pallet and stack them on the racks.
/ Pallet uses, for storage etc... #13
Man lift and truss setter. Setting homemade hoops on our hoop house:
enhance
enhance
/ Pallet uses, for storage etc... #14
Yep, in wife's horse barn, storage area has stone dust floor. Square bales get stored on top of pallets set on top of plastic moisture barrier.
/ Pallet uses, for storage etc... #15
enhance
enhance
You really need to write a book with tons and tons of pictures showing what it took to create everything that you have at your place!!!
/ Pallet uses, for storage etc... #16
Yeah.....that sounds like a lot of work for an old retired guy. :D
But thank you.
enhance
Thanks for the replies so far and keep them coming! I already have plans to make a few of these drum pallets like TnAndy!
/ Pallet uses, for storage etc... #18
enhance
A bar or chain across the front to keep the drum in place might be a good addition.
/ Pallet uses, for storage etc... #19
Was thinking the same thing. Having a brain-fart on the tilt-leveling controls when raising/lowering 55 gallons of gasoline could make a bang.
/ Pallet uses, for storage etc... #20
Also, wondering about putting 400 lbs on one side instead of balanced.
Misc. Pipe Lot 1 1/4", 2", and 3" Poly Pipe (A62679)
Misc. Pipe Lot 1...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2020 Pitts Chip Trailer P16316 (A62613)
2020 Pitts Chip...
2018 VOLVO VNL 670 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 VOLVO VNL 670...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
