General freshen up of 1967 Ford 4100
/ General freshen up of 1967 Ford 4100
Revisiting this thread as I have had to revisit part of the repair job. I bought a 6' slasher that weighs a bomb and the extra pressure on the hydraulics caused the O-rings under the diverter valve to leak badly, so I have had to finally bite the bullet and make a decent effort on that part of the tractor.
As mentioned earlier in this thread, the diverter valve bolts down onto a machined surface on the top cover and there are a bunch of oil passages between the top cover and the valve, that are sealed by O-rings. The two machined surfaces were not flat but I had hoped to get away with new O-rings as this area had not been leaking prior to the tear-down, but with the heavy slasher, as well as moving some heavy logs with my 3PL forklift attachment, the leak was pretty bad.
I removed the top cover and stripped it down, then mounted it on my surface grinder to get a properly flat surface on it. The shape of the top cover was a bit of a challenge to mount on the surface grinder but I was able to hang it off the front with the target area within the grinding envelope.
For those unfamiliar, a surface grinder can operate to tolerances of around .0001", much finer tolerances than achievable by machining with most milling machines for example. I was able to get a very flat surface with a fine finish.
I did the same with the underside of the valve itself, getting two mating surfaces that are now very, very flat.
I did a little research on proper fitment of O-rings, it seems the ideal 'squeeze' in this kind of installation is about 30%, meaning the O-ring should be squeezed to 30% less than it's resting thickness when assembled. Having removed a few thousandths from the surface of the valve, I then bored the O-ring seats to a depth equal to 70% of the thickness of each o-ring. I re-sized the diameter of a couple of the seats as I did this, to suit common O-ring sizes rather than the oddball sizes of a couple of them. I made a honing tool to polish the base of the seats with some lapping paste also.
I reassembled the top cover and installed it and the diverter valve to the tractor. I did a little work with the big slasher- very pleased to report I now have no leak from the diverter valve. There was a leak a little lower down that had been hidden by the hydraulic oil leaking from above previously- had to install a new O-ring and apply some thread sealant to this plug on the drop valve.
That was about 5 minutes work, as opposed to about 8 hours on the diverter valve.
Going to have to apply some paint when the weather warms up a bit, as I had to machine the top of the diverter valve to have a surface to mount on the mag chuck.
I had tempted fate with this valve by not doing the job properly first time around, telling myself it was an easily accessible part if the shortcut repair didn't hold; I think I was running out of energy and patience for the rebuild at the time. Easily enough accessible but I was glad not to be paying someone else's hourly rate to do this one.
/ General freshen up of 1967 Ford 4100 #62
Great thread and interesting to see the progress and repairs. Thank you.
/ General freshen up of 1967 Ford 4100 #63
Thanks for the update. I rebuilt the 3pt lift cylinder ony 3910. It leaked so bad it was constantly readjusting when loaded. Took me longer than 8 hours.... :)
/ General freshen up of 1967 Ford 4100 #64
Awesome work! You're really getting into all the little details to make that tractor 100% again.
It's also nice to see the good ol'shaper getting some work done.
Thank you, and yep the shaper comes into it's own with anything that requires internal slotting type work.
Informational Lot - Shipping (A61307)
Informational Lot...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
Unused 2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
Unused 2025 HT360W...
2013 Keystone Laredo LA329RE13 37ft. T/A Fifth Wheel Travel Trailer (A59231)
2013 Keystone...
2017 Hino 195 16ft. Box Truck (A59230)
2017 Hino 195...
