Small Scale Propane
/ Small Scale Propane #21
With a 100lb tank thats got a multifill valve you own the tank, can take it some where to get filled but can also call the truck and have them do it.
That is the second time you have recommended "multifil valve",I've never heard of that and would love to buy a bunch to resale to neighbors if they can legally have them filled by delivery trucks. Around here and other states I've worked in,it's a stiff fine and possible lose of license if caught filling 100/30/20 pound bottles from a truck. I've heard reports of trucks in the valley filling rv bottles for snowbirds but don't know how they dodge the law. We have thousands of rvs in my area used as permanent residence that have to swap bottles so I see this as an opportunity to make money if you furnish a source of "multifil valves". Thanks in advance.
/ Small Scale Propane #23
Thanks bcp.
I found this chart:
So smaller tanks give more capacity per pound of propane, especially at lower temperatures. Three 20 lb tanks roughly equal a 100 lb tank.
/ Small Scale Propane #25
I think I know the answer, but would it be completely illegal for me to put a 20 lb tank in the basement?
Forget the illegal concern. Never ever do this. Propane is heavier than air, if you had a leak, your basement would fill with an explosive gas and with one spark you would lose your house and everything in it. There are distances that have to be met from a tank to an ignition source and/or windows/doors and varies from 5' to 25'
Propane Tank Distance Rules and Requirements
But to answer your question: I haven't looked it up, but I'm sure it is illegal.
Natural gas explosion kills nearly 3 at Texas school - HISTORY
/ Small Scale Propane #26
True. Finding a new supplier before you buy any tank would be key...or just going electric like someone else said.
Cast iron cooks alot nicer over gas than my current electric stove. When we go stove shopping it will be propane and our first propane appliance in our house. If i didnt enjoy cooking with cast iron i wouldnt own a gas stove.
You might want to consider an induction cooktop. They work with cast iron (they require ferrous pots and pans) and people who have them just love them to death. I'm using gas but we actually have natural gas piped in this area, so that was a pretty easy call. That was a huge selling point for this lot.
/ Small Scale Propane #27
What difference does it make? All the plumbing is still in the house. Regardless of where the tank is how are you supposed to get the gas to the stove? I wouldn’t think twice about putting one or two 20 pound propane tanks in the basement.
/ Small Scale Propane #28
Sorry i mis spelled the name of valve type.
As for legalities of filling a 100lb tank im not sure. I know smaller than 100lb tanks have to be filled by weight. I own a milti valve tank but take all my tanks in to get filled. Laws can be dif in areas in sure too.
I pay $10 to fill a 20lb tank and $60 to fill a 100lb tank at the supplier. The supplier dosnt sell propane that cheap delivered so i bring the tanks in.
I have 22 20lb tanks and 4 100lb tanks so going to the supplier is done about every 14 months.
/ Small Scale Propane #29
I have a half dozen "20 lb. tanks to use for portable shop heater, grill, etc. BUT - they're never filled with more than 18 pounds unless I get them filled at the propane dealer. Even then, they brag that they fill them to 19 pounds. Seems that 20 pound number is pie-in-the-sky number.
Our main tank for the house is a 250 gallon tank, but the propane company won't come out unless they its down to below 25 percent, and then only fill it to 80 percent. That puts the max at around 150 gallons. We'll run through about 200 gallons per year here in mid-Georgia.
/ Small Scale Propane #30
My wife ran the numbers on our propane use as a $ cost per year since installing the 1,000 gal underground tank. We used to have regular fillings every other month on our old 250# above ground tank. Now it痴 once a year in the summer. We no longer get hit with the winter peak prices. Our average yearly propane bill has decreased nearly 20% since the change out. This is over 3 cycles with the new tank and including the previous 5 with small tank. We also get a benefit of lower propane fee as the large tank is considered a bulk fill. We paid $60/ year for tank rental on the old tank for 19 years....what was I thinking. I could have purchased it 2.5 times. I own the new tank
/ Small Scale Propane #31
Thanks. This is incredibly helpful, really gets to the question I'm asking. So a bigger tank does give better performance.
Cooktop is 50K BTU -- five burners, one 16K, three 10K, one 4K.
625854d1571886357-small-scale-propane-qeudt9u9_o-jpg
The vaporization chart shows btu's for 1 hour with a continuous withdrawal.
An intermittent withdrawal could operate a larger load.
/ Small Scale Propane #32
That's a handy chart Tiller. One can use it to size tank and appliance for emergency back-up based on expected low temp. If back-up is critical such as room heater for the elderly,I urge people to have professionals set it up. As ambient temperature fall's below 30F and/or gas consumption increase's,the possibility of complete system shutdown is a reality. The risk can be dramaticly reduced by experienced installers. U-Tube and forums ARE NOT substitutes for classroom and field training.
/ Small Scale Propane #34
If you really need lots of vaporization and it's cold outside, there are heaters specifically for increasing the vaporization rate. You'd definitely want a pro to install that.
/ Small Scale Propane #35
You are small potatoes. I have 2 500 gallon bottles (propane tanks are actually called bottles) for the house ans 2 more for the shop and I empty all 4 every winter.
/ Small Scale Propane #36
Also, they only fill to 80% to allow for expansion if the weather gets warmer.
/ Small Scale Propane #38
I'm using two 100lb tanks with an auto switch over regulator on our cottage. It is used for a gas range/oven, 199,000BTU tankless water heater, and a full size gas dryer. We've been living there full time for the past 3 weeks. The first tank is still around 1/2 full. This is the first time using all of the appliances 'full time' on this system, so not sure how long both tanks will last. I'm anticipating about 2 months. I'm going to get a third tank and have that in rotation so I can take 2 tanks to be filled each time.
/ Small Scale Propane #39
This looks like a good idea. But I would buy a third tank as back up. That way when I ignore the red flag and run both tanks empty I could still finish Thanksgiving dinner. On my grill I have two tanks. When I empty one I take it off the grill and set it by the garage door as a constant reminder I need to get it filled. You mentioned putting them under a deck and I think it would be easy to miss the flag popping up.
Doug in SW IA
I used the two tank setup on my RV for years. I quit putting it on automatic switch and when tank one ran out, I got off my but and had to manually switch it. I tried to go ahead and take the empty tank out then and leave it by the door so it would stare accusingly at me until I got it refilled.
/ Small Scale Propane #40
Going a little off topic but I would never go back to electric for cooking. Way more control of the heat with gas.
Pretty much my set up as well. Used to lease 500gal tank but realized I could pay off and own a 250gal tank rather quickly and then shop for best gas prices. When I had the leased tank, nobody but the leaser would fill it. Lost count of how many 20lb tanks I have but I would guess six as well. I used to run my BBQ off of them but got tired of running out of gas while BBQing. Tee'd off my house line and never run out. The portable tanks power my deck and garage heaters and mini fire pit.
Do sort of wish I would have purchased a 500gal tank but we only use it for our range, aux fireplace heat, and BBQ. If it was my primary heat source, 250gal would not be big enough as I would have to get it filled during the winter (high price season).
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2012 PETERBILT 587 (A67714)
2012 PETERBILT 587...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2017 Volvo VNL T/A Sleeper Cab Truck Tractor (A66736)
2017 Volvo VNL T/A...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2013 MITSUBISHI FE 4X2 S/A 20FT BOX TRUCK (A69167)
2013 MITSUBISHI FE...
