Loader operations on RK tractors
/ Loader operations on RK tractors #1
4tillingdirt
nc
N/A
For the 24, 37 and 55 can you do 2 operations at once - curl and raise or lower? Both of my brothers have a NH Boomer. One has a NH loader with the controls on the fender the other has an aftermarket loader that was added later and the controls for it are mounted like the one for the RK 24 - beside the steering wheel. The crazy thing is the aftermarket loader can perform 2 functions at once while the NH loader cannot. Is that due to one being cable operated and the other being mounted directly to the valve body?
/ Loader operations on RK tractors #2
Yes you can run both functions at once.
/ Loader operations on RK tractors #4
I believe on my 37 that if I'm lifting thwe try to dump the bucket that the lifting stops. But I'm going to try tomorrow.........
/ Loader operations on RK tractors #5
I tested the 55 at the store and you can't operate them together. One will stop before the other begins.
/ Loader operations on RK tractors #6
My 55 will do both at the same time. But you need to have the throttle up a ways so there's enough flow. Are you guys who can't get it to lift and curl at the same time running near idle or are you trying at higher RPMs as well?
/ Loader operations on RK tractors #7
Turn up the RPMs. The RK55 does allow both functions at once, at least mine does.
/ Loader operations on RK tractors #8
Hmm, ok, I could be wrong, I didn't try at high RPM,s
/ Loader operations on RK tractors #9
Being able to operate both functions at once is dependent on three things...
1. Sufficient hydraulic flow.
2. The loader valve itself.
3. Operator skill.
On my RK24, I can do both at once, if the RPMs are up, but not as well as I'd like. Some loader valves have an internal design that better allows this than others. I may, at some point, look into doing some research and getting a different valve. But for now I'm content to alternate between functions if my RPMs are low.
/ Loader operations on RK tractors #10
When I purchased my John Deere 440 loader, they used the “Blended Loader Valve” as a selling point. There seems to be a noticeable in-between direction (at 45 degrees), that gives the dual function. It works smoothly at any RPM.
/ Loader operations on RK tractors #11
Yeah, I have two loaders, they do both functions at idle, just slower.
I believe it's in the valving rather than gpm.
/ Loader operations on RK tractors #12
Page 3-22 of the RK55H/HC owner's manual:
"IMPORTANT:
Do not hold the lever in the "Pull" or "Push" position once the remote cylinder has reached the end of the stroke. As this will cause oil to flow through the relief valve. Forcing oil through the relief valve for extended periods will overheat the oil.
When Using the tractor hydraulic system to power front loader,do not operate the boom and bucket cylinders simultaneously."
That said, same experience as other RK owners. In addition, my older NH behaves the same.
/ Loader operations on RK tractors #13
"IMPORTANT:
I thought I remembered reading that in there
John Deere 7320 (A62180)
John Deere 7320...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
UNUSED KJ 25'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 25'X12'...
KBH Tank Trailer (A63118)
KBH Tank Trailer...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
UNUSED CFG INDUSTRIAL QH12R MINI EXCAVATOR (A62130)
UNUSED CFG...
