Oil & Fuel Fluid Questions for Central NY State
/ Fluid Questions for Central NY State #1
Teeny Greeny
Member
Finger Lakes NY
2021 JD 2025R
Hello, I appreciate the add to this group. Can someone share what the best Oil weight would be for upstate NY in the Cold Country? I just bought a Yanmar 276D and want to change the fluids before I use it. With colder days arriving soon I want to use a Fall/Winter weight Oil. Also I would like to know what most use for Hydraulic Fluid/Transmission Fluid. Lastly, what Filters should I use? Can someone provide part numbers? I will log them in my files. Thank you!
/ Fluid Questions for Central NY State #2
Calls for 15w40 diesel oil. If you want to use a lighter weight for winter it should be fine. just make sure it's diesel rated.
JD 303 is the spec. for hyd oil. you can buy the off brand that meets jd 303. tractor supply brand, etc,.
I used transmission fluid in mine
Sorry, can't help with filters. I had a 3110D. don't know if the same filters would fit your tractor
Thank you. I appreciate the reply. I have the Operation Manual but not a Service Manual. I didn't understand the Oil break down for the temperature change. I did see the referene for Transmission/Hydraulic Oils with JD 303 (J14B). It looks like the engine oil calls for SAE 20 but no multi-viscosity above 32f. I'm not sure I understood that correctly.
/ Fluid Questions for Central NY State #4
well, Oil has changed a great deal since those tractors were built. So I think you would be better off using a multi grade oil for colder temps than a single wt oil.
Perhaps 5w40 synthetic diesel rated oil, or similar
Thank you for the reply. I did switch to synthetic blend for my older vehicle but that is a gasoline engine. I wasn't sure how that would work out for a deisel engine.
/ Fluid Questions for Central NY State #6
Oil - the manual is 30 years outdated. Ask a farmer what Diesel-rated viscosity you need to get it to crank in your cold climate. If you can get it started then any multi-grade Diesel oil should be fine.
The manual says use JD 303 equivalent Universal Transmission Fluid. An obsolete spec. What's sold under that description today is the lowest-spec, non multigrade fluid. J20C is the Deere multigrade UTF spec that superceded 303. That, or better, is my advice. ATF is another good choice. These Powershift models should get better fluid than the minimum-spec stuff that is fine for a manual transmission.
I get my fluids from Tractor Supply, inexpensive and I think sufficient.
/ Fluid Questions for Central NY State #7
if you want to use synthetic blend for your diesel, that is fine. just make sure it's for diesel.
I use 100% synthetic in both my diesels, but a blend should be fine if that is what you choose to use.
As I stated, When I owned my 3110, I used transmission fluid instead of hyd fluid.
your front gear case most likely calls for 90 wt. You'll be hard pressed to find straight 90 wt these days
/ Fluid Questions for Central NY State #8
Welcome to the forum. :welcome: Sent you a pm.
Thank you for the reply. Tractor Supply just happened to open a new store very close by. While looking for the correct filters for a 276D it seems they want the year. I'm not sure of the year as I don't know where to find that information. Did the filters vary during production or are they the same for all 276D's? Thank you again...
/ Fluid Questions for Central NY State #11
Hey there and welcome! I’m in northwestern PA so I also see similar cold temperatures. I have a YM2210D which is also a powershift. I switched to Schaefer Simplex Supreme for the transmission/hydraulic fluid. It’s a synthetic blend and my local NAPA gives me jobber pricing so it’s a good value for a really good fluid. I put the same in my Mahindra 1538 and it behaves much better in the winter. Hope this helps.
Thank you, I appreciate the reply. My local Farm supply store shows the same Oil filter for the Gas and Deisel. I will post what they have listed as maybe this can help others!
So there is no way to determine the year of my YM 276D? I guess it doesn't matter if the parts are the same throughout 81-91. Thanks again...
/ Fluid Questions for Central NY State #13
http://www.nfhconnect.com/Home
Try this. NAPA site. Plug your tractor info in and you値l get the NAPA filter numbers. Worked for my 2210D. Imagine yours will be in there too. I like NAPA filters because I can get them locally and theyæ±*e made by WIX which are one of the best. I run 5-W40 full synthetic motor oil in both my Mahindra and Yanmar. Makes cranking in cold weather easier and still gives the 40 weight for warm weather. I won稚 get into a oil brand debate because there are many good oils out there but I run Amsoil. But almost anything available today will be way better than what was available when these tractors were designed. Just make sure youæ±*e using diesel rated oil and you値l be good.
/ Fluid Questions for Central NY State #14
I use 15w40 too....in both my tractor and skidsteer. Thatç—´ what the nanuals call for. Never any winter issues (in the Syracuse region), even in sub zero temps. Just let it warm up though.
Tip - keep extra fuel filter around in case you have any fuel gelling issues. My tractor is prone to that. Skidsteer has never gelled up. I use the same fuel source for both and add Power Service to the fuel cans
Yes, thank you for the reply. I was hoping to hear from someone close by that experiences the same weather. I will try and price the Hydraulic fluid here at our Napa. I appreciate the help!
Thank you, I appreciate the reply. I only got one fuel filter but will pick up another one when I return the Oil filter. I'm hoping to find the right Oil filter locally for tomorrow as I need to get things done.
/ Fluid Questions for Central NY State #17
For cold weather in WNY along the 2 Great Lakes, Yanmar shows 10W30 & John Deere lists 5W30 for our YM series engines.
I tried the 15W40 last winter. It was a real PAIN getting the engine going. If it had a oil pan heater, then maybe. By the end of December, I switched over to the 5W30 and it was a joy once again running the engine. I had to move so much snow.
Yanmar Self Check Tractor Maintenance doc 2/18/2014 Yanmar.com.jp for the YM series.
John Deere Diesel Maintenance for 650/850/950/1050 with Yanmar engines
/ Fluid Questions for Central NY State #18
I have an Iseki from the 80's I was trying to find the yard on. Someone suggested checking the rear rims, they often have a date stamped in them.
/ Fluid Questions for Central NY State #19
I tried finding the source for those upper temperatures/oil. Do not make sense. The engine upper operating temperature is set by the thermostat, typically 180-190 F. Think the charts are for air cooled engines.
I use 5w30 diesel rated oil in the JD and Isuzu from the VW dealership. Can get 0w30 M1 ESP (exhaust system protection) online for about the same price. When I run out of the Castrol 5w30, the M1 0w30 is what I plan to get.
Use 0w20 in the 3 gasoline engines.
Have 5w30 regular M1 for the air cooled engines.
Racing engines typically use 10w oils (I've read on forums), and they would get pretty hot. Think they do this for protection for max. performance without killing the engine right off the line.
Ralph
/ Fluid Questions for Central NY State #20
Ralph
Those charts are for liquid cooled engines. Look up the John Deere models on tractordata.com to verify for yourself.
I'm not a fan of SAE 30W straight. Thus, if you live in an area for temps hotter than 87F, the 15W40 on both charts is defined.
If you know your oils, you can do a syn 10W30 mixed with a zinc additive for engine protection. This would allow it to reach the hotter temps. The sny will not break down like dino.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61567)
2025 Kivel 48in...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
New/Unused Landhonor Quick Attach Hydraulic Winch (A61166)
New/Unused...
Wooden Wagon Wheel Rocker (A61569)
Wooden Wagon Wheel...
2012 Chaparral Sunesta Boat with 22ft. T/A Continental Boat Trailer (A61569)
2012 Chaparral...
Club Car Intellitrak Golf Cart (A61166)
Club Car...
