TFseries (eg TF70)
/ TFseries (eg TF70) #1
Blui
Dotau 4570
'58 DavidBrown, '48 IH-T6, '17 454-cn
Are there direct copies of the Yanmar TF series engines (like the 170F is copy of L48).
I want to try get starter & ring gear/flywheel.
I have found R series engines but bore size's 75mm, 80mm not 78mm
cheers
/ TFseries (eg TF70) #2
Are you useing that engine to power a generator, or is that your project idea?
I have an old engine hooked up to a water pump, its very fuel efficient. Some persons have trouble starting...
.au, towards the south pole...
Yep, spot on the dot
/ TFseries (eg TF70) #9
I have been looking at engines like that for a while now. Not just the yanmar brand but another one that has the same design. I want to use it as a generator for my house.
/ TFseries (eg TF70) #10
cheers
Yanmar makes a cultivator that uses the TF120DIY engine out of Italy. Would this be in the same TF engine family you are looking at?
KOMATSU uses a Yanmar TF60 engine in a small walk behind roller for pavement sidewalks.
The Yanmar TF70 engine seems to be a current viable engine from Italy.
https://www.yanmarindustrial.eu/Products/Diesel-Water-cooled-industrial-engines/TF70-119/
Yanmar Global Parts distributor
Yanmar Industry │Yanmar Center
Search results for: 'tf7'
Landhonor 31" Mini Excavator Bucket (A66285)
Landhonor 31" Mini...
82" X 18' EQUIPMENT TRAILER (A64277)
82" X 18'...
Gehl RS5-19 (A62177)
Cattle Feeder (A65640)
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
