Farmtrac 300 DTC won't start
/ Farmtrac 300 DTC won't start #1
trumanb
fram trac DCT 30
I have a bad switch on the clutch safety switch. This is the one that won't allow the tractor to start unless the clutch is depressed. Took it out and wiggled it around and it started working. Now nothing I can do will allow the tractor to crank. This thing has 4 connector wires and I am seeing a new one looks like it's about $300. wow a switch can't cost that much. I know I probably won't get any help with bypassing the switch. Someone please help
/ Farmtrac 300 DTC won't start #2
Gee, my Craftsman mower has a switch like that. It's really two switches in one. One set of contacts is normally open. When you depress the clutch they close. The other set is normally closed. When you depress the clutch they open. To bypass the switch you need to leave one pair of wires open. The other pair needs to be connected. You'll have to find a wiring diagram for your tractor. That's just how my mower seat is wired. I will concede $300 seems a bit steep for one switch. You may wish to check eBay.
/ Farmtrac 300 DTC won't start #5
Hello i know this is old just curious if tractor would still turn over but not start with the bad switch.
/ Farmtrac 300 DTC won't start #6
No, engine will not turn over as part of the start circuit.
2014 Jeep Compass SUV (A61569)
2014 Jeep Compass...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
2005 International 5900i T/A Flammable Liquid Transport Truck (A60352)
2005 International...
2017 Terex RL4 S/A Towable Light Tower (A60352)
2017 Terex RL4 S/A...
2020 DRAGON ESP...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
