Farmtrac 300 DTC won't start
   / Farmtrac 300 DTC won't start #1
trumanb
fram trac DCT 30
I have a bad switch on the clutch safety switch. This is the one that won't allow the tractor to start unless the clutch is depressed. Took it out and wiggled it around and it started working. Now nothing I can do will allow the tractor to crank. This thing has 4 connector wires and I am seeing a new one looks like it's about $300. wow a switch can't cost that much. I know I probably won't get any help with bypassing the switch. Someone please help
   / Farmtrac 300 DTC won't start #2
Gee, my Craftsman mower has a switch like that. It's really two switches in one. One set of contacts is normally open. When you depress the clutch they close. The other set is normally closed. When you depress the clutch they open. To bypass the switch you need to leave one pair of wires open. The other pair needs to be connected. You'll have to find a wiring diagram for your tractor. That's just how my mower seat is wired. I will concede $300 seems a bit steep for one switch. You may wish to check eBay.
   / Farmtrac 300 DTC won't start #5
Hello i know this is old just curious if tractor would still turn over but not start with the bad switch.
1998 Mazda B2500 (A57148)
1998 Mazda B2500...
2021 SANY SY365C9C5K (A58216)
2021 SANY...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
(2) CASE IH DRAWBARS (A52708)
(2) CASE IH...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2021 Deere 331G (A53317)
2021 Deere 331G...
