BX Back Hoe, Bucket Reversal
/ BX Back Hoe, Bucket Reversal #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
Any body try to reverse the bucket on the BX BH so you dig pushing away from the tractor instead of pulling toward the tractor? Looks like you could but thought I would get opinion from another experimenter before. I need to square up the vertical walls of a pit. Hand digging sucks at my age.
Ron
/ BX Back Hoe, Bucket Reversal #2
I don’t see how this is going to help but if the pins are the same size it should work.
/ BX Back Hoe, Bucket Reversal #3
you can square up the walls of a pit without going into a weird modification. use it as it is.. I've seen it done before..
/ BX Back Hoe, Bucket Reversal #4
Roll the bucket all the way back and move the machine so the boom is about 3/4 of the way extended and dig away. I don’t see how having the bucket on backwards would help. IMG_6942.JPG
/ BX Back Hoe, Bucket Reversal #5
You can, but you're loosing breakout forces. With the bucket reversed, your stick cylinder retracts to push the bucket forward. To curl the bucket up, the cylinder retracts.
On any hydraulic cylinder, the retracting motion is less powerful than the extending motion.
Thanks, had not thought of that. In this case the difference may not be important. Soil is sandy/rocky and mostly loose. If I try I will post my results.
Ron
/ BX Back Hoe, Bucket Reversal #7
I've reversed a bucket to dig under a sidewalk. It works but it is weak and also confusing since the normal bucket control is backwards. Have to be careful. I agree with others the normal setup will get you a straight side down on the other side of the ditch, no need to change the bucket for that purpose.
New/Unused Landhonor Gas Powered Water Pump (A61166)
New/Unused...
UNUSED WOLVERINE TQH-26-02C 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
429768 (A61166)
429768 (A61166)
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
2020 John Deere 2633 Disk 29' 3" (A64047)
2020 John Deere...
