Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #6,381
The right way is to have the mower in front of the tractor.
/ Let's talk flail mowers #6,382
Hello Flail Mower Nation! I’m new to TBN and I’m looking for a sanity check on my flail mower purchase plan. I’ve read a good amount of this thread, and I think my plan will work, but I’d appreciate any comments you all have…
1. Mowing requirements – mainly mowing lawn (cutting to a height of ~4”) and periodic clipping of grazed pasture (cutting to a height of 6-8” of sporadic weeds and tall grasses (18-24” tall))
2. Tractor – NH Boomer 25 with 27 net HP and 20 PTO HP
3. Flail Mower – Titan 72” (I’m looking at the titan because of their pricing and for their “hammer” knives/blades because, from my understanding, they provided the smoothest finish and can still handle ~1-2” thick weeds)
I’ve seen different replies on this tread that leave me thinking I shouldn’t have any issues mowing the lawn, although I will probably sacrifice mowing speed in the pasture with taller weeds/grasses (which I'm fine with)... Are my observations correct or should I be looking for a smaller/narrower mower? Also, any thoughts or concerns on Titan brand for this application?
/ Let's talk flail mowers #6,383
Hello and good evening Creole,
The titan mower is too wide for your mule.
A five foot caroni flail mower with the F rotor with 4 rows of side slicer knives will be more
than enough mower for your mowing needs and you will have a great mowing job in all conditions.
A five foot caroni mower with the B rotor will work but you will not have the ability to recut your
grass clippings with the scoop knives and you don't want dead grass ruining a good lawn.
Time to turn in and send the guard sheep out on a search and destroy mission. :laughing::laughing:
/ Let's talk flail mowers #6,384
A quick check on the spec's for the Titan 72" for minimum 30 pto HP. I have a 60" WoodMaxx, I could run it very well with my 22 PTO HP when it had Y blades. Switched to Hammer Blades. Takes a lot more HP to run this type of blade. I find tractor will bog down cutting with the hammer blades in area's where the Y blades did not.
/ Let's talk flail mowers #6,385
When I used the Titan hammer blades I didn't like the quality of grass cut when compared to a multi blade rotary mower. It did work great on brush and if I ran it at a slow RPM it did ok with rocks too. (High [540] RPM cased visible damage to the blades, running it as slow as possible [just enough to cut the brush] caused little to no damage when rocks were encountered)
/ Let's talk flail mowers #6,386
Thank you leonz, ronjhall, and m5040 for the quick feedback!
It appears I have my blades and their intended purposes mixed up (which I think steams from all the different manufacturing recommendations out there). What would you all say the intended design differences between the Hammer, Duck-foot, and Y-blades?
Also, which light duty/value brand of flail mowers would you recommend?
I've mostly been looking at Farmer Helper and Titan, because those have the strongest returns on my internet searches. Then I also have a bush hog for heavy brush clearing, so I'm mostly looking for a rugged lawn mower that can also go out into the pasture and clip underneath the electric fence...
/ Let's talk flail mowers #6,388
The cast hammer knives are used for orchard and vineyard shredding of limbs and both large and small pruned grapevines and berry canes.
The scoop knife is an all around mowing knife.
The side slicer is the best knife for mowing good sod and brush as you can recut everything on the second pass.
Getting a lawn mower to clip under the electric fence will require you to invest in a boom mounted flail mower and nothing less as an offset flail mower will not prevent you from ripping out the fence line.
If you have less than 15 foot between posts and a very low lower wire you can forget using a boom mounted flail mower.
you will be better off flaming the weeds with a propane roofing torch in the fence line as long as you keep the torch down.
/ Let's talk flail mowers #6,389
If you can swing the cost, the WoodMaxx 62H would be the ticket. With the hydraulic side-shift you can mow along the fence line and slide the mower in and out under the fence as you go along. This would require remote hydraulics.
The Y blades are a good course blade that doesn't leave a perfect finish, but will still cut heavier materials. The fine cut mowers use about 3 times as many narrower Y knives and achieve a better finish. The duckfoot blade is kind of an in-between of course and fine cut. It will leave a nicer cut than the course Y blades (flat top grass, not V shapes), but will still cut heavier grass when needed. The Hammer is good at what it's name implies- hammering. It will cut down small trees given a big enough power plant to run it. It will also cut grass, but it does require more HP to run it. They are also more brittle when hitting rocks.
It is difficult to find a newer mower that uses the duckfoot blades. It sounds like this is the kind of blade you are looking for. I would suggest looking for a used JD 25A or a Ford 917. They use similar blades - JD uses the duckfood, Ford uses an airplane wing. Both have some parts availability, but avoid mowers that are in very rough shape and missing major components.
Otherwise I think a used Mott or Alamo fine cut would serve you well, You will need to go slower on the taller grass, but it will leave you a lawn finish. I would suggest staying under 5 feet wide with your limited HP.
I've heard bad things about the Titan mowers, but good things about their customer service. Their mowers are Chinese imports, as well as Farmer Helper.
After looking at the Farmer Helper, if you go with the standard duty mower it has the option of "mulch blade" which appears to be the duckfoot blade.
/ Let's talk flail mowers #6,390
A caution on that statement. My tractor is a bit wider than 5'. With the WM shifted all the way right I can mow up against a fence but I'd be hard pressed to cut under a fence without running the rear wheels into the fence itself. That is why I wanted the 72H but I don't have the PTO HP to run it.
/ Let's talk flail mowers #6,391
The easy solution to the lack of HP in 90% of situations is do partial passes or go slow. I'm a fan of going wide & going slow. Plenty of width to hang past the tires to get under stuff & a smoother ride.
I really dont find mowing under fence an option though. Field fence goes all the way to the ground & smooth or barbed wire usually has the bottom strand quite a ways below the top of my mower. Also a lot if the fences I'm near arent in great shape. So I stay a bit away to avoid wrapping hidden broken bits up. I get within 6-12" of my own field fence in good shape generally though.
/ Let's talk flail mowers #6,392
The salesman at Woodmaxx talked me out of the 72 even though I said I could just go slower. But the PTO for that is 30 on the low end and I'm just under 25 so it wasn't a case of being on the boundary. He could have sold me a more expensive machine but didn't. My fence is field as well. I can safely get within a few inches with the mower out to the right. Before getting the real tractor I used my garden tractor but that required mowing every week or 2, it doesn't like anything tall. The WM doesn't seem to care how tall it is even with thick stalked weeds. I cut stuff that was close to 5' without slowing down. Of course I'm not running real fast anyway. No speedo but I'm sure I'm under 5 MPH most of the time.
/ Let's talk flail mowers #6,393
Yeah, I forgot about that part... I'm just used to having a mower wider than my tractor to the point I need to be careful when I pass through narrow areas.
/ Let's talk flail mowers #6,394
Thanks ronjhall! I知 not looking for a finished cut, but did the Y blade cut look decent for grass/lawn? Also, why did you decide switch to the hammer blades?
/ Let's talk flail mowers #6,395
What did the Titan cut look like? Was it just rough or streaky?
/ Let's talk flail mowers #6,396
Take a look at Nova too. NOVATRACTOR, the best value tractor implement in the US market, we supply flail mower, wood chipper, ditch mower, etc
/ Let's talk flail mowers #6,397
I'll take a picture after I cut my lawn again. Probably tomorrow evening. Otherwise there is a picture somewhere in this thread showing the "V" shape the Y blades leave.
/ Let's talk flail mowers #6,398
Not who you are asking, but I'll answer. The Ys on my old 719 cut field & pasture great. You could have probably cut a lawn with it & looked fine. I upgraded to the Peruzzo with hammers for brush. I only do pastures & fields or even less developed areas so handling bigger material, trash & what not was mor important to me than cut quality. The Ys would cut finger sized woody material well, but any bigger than that & the knives would just bounce. It would get noisy & just strip the bark off.
The Peruzzo & hammers will eat trees & branches up to wrist size easy if I have the HP. The hammers do fine on grass too. Again I could probably even do a decent job on a lawn if the whole setup weren't 8,000lbs. I thought my hammers were getting a bit dull & needed spares anyways, so just got them in. The new ones are pretty dull as well, guess I never paid attention to the original ones sharpness when new. They still cut well.
/ Let's talk flail mowers #6,399
My advice would be to go with the Alamo for parts availability.
I had a 5 foot Ford 917 (not the "H" version) and I now have an Alamo SHD88. I ran the 917 with course cut blades on a 40 pto HP machine and it cut 3 foot tall grass just fine. I went a little slower, but didn't really bog down much. I now run the 88 on a 52 pto HP machine (dyno'd at the dealer) and can cut 3 foot grass without problems. I only slow down because of the rough terrain and to make sure I cut everything.
You should haven no problem cutting 16" grass with 40hp on the Alamo. You may need to run a bit slower, but you probably won't notice much bogging as long as it's not super lush grass. If the grass is thick you will want to slow down to make sure everything gets fully cut and mulched.
I ran my JD 390 (either 7 or 8 feet, I do not remember) behind my JD 4105 (41 engine HP) ONE TIME!
That combo would cut light grass,, but, I would not try tall or thick grass,,
I normally pull the JD 390 with my IH 584 which is 50+ PTO HP,,,
Oh, yea, with any 7'+ mower, expect to need front end weights,,,:D
Well I found a very nice shape Ford 917 88" near me and got a good deal on it I believe.
It's definitely too much for my tractor. The 3 foot high weeds it struggled at times in 1L. The 16-18" stuff was a little much for it in 2L. The shorter stuff like 6-8" was no problem tho.
I planned to replace the tractor anyways, it's not in the greatest of shape. So I guess now I'll be looking for a larger machine. I just need to be triple sure I buy something with enough power.
Both y'all's tractors are 50-52hp at the PTO. So of I find an older Ford 4000 or Massey 165 or David Brown 990, for example, those are right around 50-55 HP at the PTO. There's also an older Kubota I'm seeing locally with 49 at the PTO.
Think I'm safe with anoy of those machines?
/ Let's talk flail mowers #6,400
Anything over 40 PTO HP should be enough to run that 88". Hydrostatic drive is nice so you can vary your speed as you go.
It wouldn't be a bad idea to sharpen or replace the blades. That should help reduce the HP draw. If it's a course cut model you can replace the airplane wings with Y shaped blades if desired. If you have a fine cut model you can keep it fine cut or change it to course cut by getting different mounts, hangers, and blades if you want. Or just keep it fine cut. The Ford 917 is flexible like that.
Pictures or you don't really have it! :dance1:
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
HE WASHING MACHINE & DRYER (A62131)
HE WASHING MACHINE...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2017 Ford F-550 3yd. Mason Dump Truck (A61568)
2017 Ford F-550...
