Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #6,361
I hadn't even considered the possible lack of a QC loader. Yep that does make it more difficult.
/ Let's talk flail mowers #6,362
Me either, 1st requirement when looking at a new tractor. All my tractors have had them. I use my pallet forks as much or more than the bucket.
/ Let's talk flail mowers #6,363
Not sure if it was luck or TBN wisdom, but I got SSQA on my L3200s loader. Wouldn't get a machine without now. Forks are on my new L4060HSTC more than the bucket or snow plow.
/ Let's talk flail mowers #6,364
I do not have a SSQA. But do have a pin adapter for all my FEL attachments. Only takes a couple of minutes to change attachments.
/ Let's talk flail mowers #6,365
So I found a 7 foot offset Ford 917H and a 7 foot Alamo.
The seller of the Ford says "55 hp will handle 6inch tall stuff no problem will bog down in taller grass. 30 hp when just like mowing a lawn about 4 inches tall"
The seller of the Alamo says "I ran it with a 50 hourse tractor 40 at PTO. And yes it is more of a rough cut mower for high grass in fields. cut good was over 5 feet"
I'm getting wildly different advice on the amount of HP required to run one of these mowers. One guy can cut 5 foot grass with 40 horse but another need 55 to cut 6"?!?!?!
I have 40 at the PTO and want to cut 16" high grass down to 4" or so. Driving 4 mph or so. What do I need to turn a 7 foot mower?!?!?!
/ Let's talk flail mowers #6,366
I run a 917 on an XR4155HC-can’t recall exact PTO HP but it is around 45-50. Don’t have any real problem cutting meadows here at around 2ish feet tall, dry. Haven’t had a bogging/ stalling issue running in low gear at around 3-4mph.
/ Let's talk flail mowers #6,367
L3200, 25hp PTO (actually probably 20% less due to my 7,000' altitude) & the 7' 917... I was going pretty slow in this grass, but covering about the same acres per hour as with the 5' rotary.
I rarely go 4mph with my new L4060HSTC (32.5hp PTO, actually probably 20% less due to my 7,000' altitude) & 8' Peruzzo. Even when its light material not taxing the machine the fields I mow get to rough at 3-4mph. Sometimes I'll kick it into M-high & 5mph or so on smoother light stuff.
Grass is the biggest HP requirement to cut, way more than writs sized woody material at times. 8" of thick green grass is a lot more mass than a few feet of tall thin dryer material.
Your real 40hp PTO vs the grass in my photos might be able to keep up 4mph with a 719. May need to drop a gear to 3mph or so, but it should be pretty doable. IMG_20150626_200301-1.jpgIMG_20150614_130149.jpg
/ Let's talk flail mowers #6,368
hello thoner,
When you want to cut your grass down to 4 inches your going to lose a huge amount of pressure gradient/suction to lift the grass/brush and then the clippings up and over the flail mower rotor.
The smaller the flail mowers cutting width the more power and torque you can supply to the drive train and then through the V belt drive to the flail mower rotor.
Is there any reason you would not consider investing in a used flail chopper with the auger and blower? That is about the only way I can see you doing this as 4 inches of cutting height is too high UNLESS AND ONLY UNLESS you have a flail crop shredder with cup knives like the Hiniker 6 foot flail shredder or flail chopper.
A used small flail silage chopper with the wide throat chute would work too.
/ Let's talk flail mowers #6,369
I use to mow with the 719 & currently mow with the Peruzzo at 4-6" all the time. Not as clean of a cut & tire tracks pop up more cutting higher. But it works well for my customers on rougher fields who are going for fire & pest control more than looks.
/ Let's talk flail mowers #6,370
hello thoner,
I'm not sure I know what you mean when you say "4 inch of cutting height is too high". Are you saying I should actually cut the grass shorter? I'd have no problem doing that, I just figured it would be easier to cut it to a longer finish height.
This is essentially a "lawn" which is why I'm not looking at shredders.
/ Let's talk flail mowers #6,371
Your real 40hp PTO vs the grass in my photos might be able to keep up 4mph with a 719. May need to drop a gear to 3mph or so, but it should be pretty doable.View attachment 623844View attachment 623845
Thanks for the explanation. I don't think I'd let the grass get quite that long either.
I'm wondering tho if different makes of flails need more HP because they are less efficient I. The gearbox, rotor, knives, etc
/ Let's talk flail mowers #6,372
Mowing at 2 inches of cutting height is fine and no problem for a flail mower.
I have to go
/ Let's talk flail mowers #6,373
Most flails throw material up & over the rotor. Lifting the material & recutting it a few times as it goes over results in better mulching & even clippings distribution. But that takes a bit of extra HP compared to a rotary. Duck foot & hammers especially are going to have more surface area & drag. I assume between the belts & couple of extra bearings, not to mention the aerodynamic drag of all knife options while spun up & cutting nothing a flail will use a bit more power than a rotary in the same state.
I find the benefits outweigh the costs, even perpetually getting a bigger flail than I should compared to my HP.
/ Let's talk flail mowers #6,374
My advice would be to go with the Alamo for parts availability.
I had a 5 foot Ford 917 (not the "H" version) and I now have an Alamo SHD88. I ran the 917 with course cut blades on a 40 pto HP machine and it cut 3 foot tall grass just fine. I went a little slower, but didn't really bog down much. I now run the 88 on a 52 pto HP machine (dyno'd at the dealer) and can cut 3 foot grass without problems. I only slow down because of the rough terrain and to make sure I cut everything.
You should haven no problem cutting 16" grass with 40hp on the Alamo. You may need to run a bit slower, but you probably won't notice much bogging as long as it's not super lush grass. If the grass is thick you will want to slow down to make sure everything gets fully cut and mulched.
/ Let's talk flail mowers #6,375
Actually from what I've discovered it's about half and half for the rotation direction. The Ford 917, Most Alamo, and all the JD 25A units I looked at spun the same direction as the tires. Most imported seem to spin opposite of the tire rotation. Alamo comes standard with "forward" rotating rotor. You can get them reverse rotating, but it seems quite rare.
The benefit of forward rotating is you only cut the material once and it also lifts up grass that was mashed down by the tires. You will still end up with tire tracks when cutting really long grass, but they're not as bad as the reverse rotating mowers. If you go slow this seems to help as well. I just mow it again a few days later to get rid of the tracks.
Revers rotating will mulch the grass more, using more HP, but leaving smaller clippings for nature to deal with.
/ Let's talk flail mowers #6,376
Flails actually have an easier time cutting shorter than longer because the grass is stiffer the closer to the ground you get making it easier to cut. If you are cutting for lawn and you intend to keep it short then look for a fine cut unit. If you want to just let it grow to 16" before cutting then the course would use less HP to cut that length grass, but will not leave as nice of a finish. I use a course cut on my lawn and I see the "V" shape from the cutters after mowing. It goes away in a few days, but it looks like freshly groomed ski hill right after cutting. If that bothers you then I would suggest the fine cut. You can get the Alamo in a fine cut. The standard Ford 917 can be easily changed to a fine cut, but I'm not sure about the 917H. If it has the same rotor then you're good to go.
/ Let's talk flail mowers #6,377
Reasoning I've heard is the highway mowers need to reject trash better. Forward rotation would try to bounce over junk as opposed to driving it into the hood.
Both my flails are absolutely worthless mowing in reverse. I'm sure most of that has to do with the roller pushing all the material down. But I've never investigated & just planned on driving forward over anything I back over.
/ Let's talk flail mowers #6,378
I ran my JD 390 (either 7 or 8 feet, I do not remember) behind my JD 4105 (41 engine HP) ONE TIME!
That combo would cut light grass,, but, I would not try tall or thick grass,,
I normally pull the JD 390 with my IH 584 which is 50+ PTO HP,,,
Oh, yea, with any 7'+ mower, expect to need front end weights,,,:D
/ Let's talk flail mowers #6,379
I'm confused as to why rotating in the same direction as travel would lift the grass better than when the flail runs opposite. Seems like since the grass was flattened by the tires, it would be laying with the top toward the back of the flail. Cutters would be following that direction, reverse would be "blowing" against the top of the grass and more likely to pick it up. What am I missing?
/ Let's talk flail mowers #6,380
When the tractor rolls over the grass while driving forwards, the grass is pushed over forwards (top towards the front of the flail). So the rotor turning the same direction as the tires will pick up the grass.
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
2016 Ford Transit Van, VIN # 1FTYE1ZG8GKB07239 (A61165)
2016 Ford Transit...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63118)
2004 Cadillac...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
