Chains and binders for trailering a compact tractor?
/ Chains and binders for trailering a compact tractor? #1
Blackgreyhound
Kubota L3719 HST with LA681 loader
What size/grade chains do I need to trailer my Kubota L3710 HST + FEL? It should be about 5,000# +/-. I just picked up a 16', 10K, CAM Superline Warrior trailer. No rush, but I want to be prepared when needed.
/ Chains and binders for trailering a compact tractor? #2
It's overkill for what you are hauling but I would go with 5/16" grade 70 chains, that way you are covered for future projects.
/ Chains and binders for trailering a compact tractor? #3
/ Chains and binders for trailering a compact tractor? #4
That’s the same I would do. There’s not much cost or weight savings going with a smaller chain so I don’t see any good reason to use smaller chain. And you won’t hurt that chain pulling with the tractor.
/ Chains and binders for trailering a compact tractor? #6
Get 5/16” chain and use 3/8” binders. That way, if you ever need to secure more weight you just need heavier chain.
/ Chains and binders for trailering a compact tractor? #7
Legal requirements is a WLL of at least half the actual load weight. You only need 2,500 lbs of securement. Four 1k ratchet straps is more than adequate.
Grade 70 1/4” chain has a WLL of 3,150. Two 1/4” G70 chains would be much more than your entire load.
I prefer to have more securement than required and only like having to run as few individual pieces as possible, for the most options.
/ Chains and binders for trailering a compact tractor? #8
Most binders cover 2 sizes. 5/16-3/8 binders would be fine. I don’t advise using 3/8-1/2 binders. I’ve done it and it works but the hooks are really too big.
/ Chains and binders for trailering a compact tractor? #9
I prefer the ease of use of ratchet straps to chains & binders. But after cutting a 15k rated strap on half with a very dull bumper I moved to something safer. Steel can cut nylon surprisingly quick but won't cut chain. I run 5/16" grade 70 & ratcheting binders. I have some of the over center binders but only use them if I'm stuffing a 2nd impliment on.
16' of trailer is going to be a bit tight for a Grand if you have a loader or impliment on. My 22' trailer can be tight for my L4060, loader & an impliment. You also need room to ballance things properly.
/ Chains and binders for trailering a compact tractor? #10
The part about having enough trailer to balance the tongue weight by moving the load fore or aft is often overlooked.
Thanks for all the feedback. Very helpful.
/ Chains and binders for trailering a compact tractor? #12
Get 5/16 chain and use 3/8 binders. That way, if you ever need to secure more weight you just need heavier chain.
As 45/70Man mentioned, be careful using the 3/8"-1/2" binders as they can slip on a 5/16" chain. I have one 3/8"-1/2" binder, not sure how I ended up with it but I have had it for 40 to 45 years, and I only use it if I have to due to the possibility of it slipping, which it has done.
/ Chains and binders for trailering a compact tractor? #13
Related question:
When are chains, straps, tie downs required?
Is there a weight limit on what loads in a truck or trailer need tie-downs and what doesn't?
Does a garden tractor in a pickup bed need tie-downs?
Garden tractor in a (~dump) trailer with side rails (equivalent to a pick-up box)?
A SCUT in trailer with side rails.
The reason I ask, is I followed a local John Deere dealer from Hudson Falls to 3 towns over with a SCUT in a trailer with <2' side rails. Tractor didn't have a single strap or chain on it. Local reputation is he rips a lot of people off, but is he endangering them too?
/ Chains and binders for trailering a compact tractor? #14
Laws likely vary by state, I would tie down the machine in both scenarios. Even the garden tractor with momentum could crash through the pickup tailgate. The dealer transporting the SCUT unsecured is being lazy and foolhardy. I would not want to have to live with the knowledge that my poor choice cost someone's life.
/ Chains and binders for trailering a compact tractor? #15
Related question:
Everything is required to be secured even a bag of dog food. Two straps or chains are legally good for things up to 10,000lbs over that you need four. Pickup sides, side rails, dump beds etc make no difference. Most cops will use some common sense enforcing the law but per the law even little things should be strapped down in a pickup bed.
/ Chains and binders for trailering a compact tractor? #16
Grade 70 1/4 chain has a WLL of 3,150. Two 1/4 G70 chains would be much more than your entire load.
I have (5) 5/16" chain and 3/8" binders for my 7,700 lb. Kubota L48 TLB.
I use (4) 2" ratchet straps for my smaller Ford 1920 FEL.
I love ratchet straps.
/ Chains and binders for trailering a compact tractor? #17
I have 20 or more 2” ratchet straps that I use all the time. But I usually use chains on equipment. It’s more work to hook a strap to not cut them vs just using a chain. I ruin a few straps a year ago I found them in sale for $7.50 is why I have so many.
/ Chains and binders for trailering a compact tractor? #18
The legal requirement for two up to 10,000 and four from 10,000 and over us for vehicles and machinery, not other loads. Their securement is outlines elsewhere.
I stop a lot of people for improper securement. Mowers and ATV’s, are especially problematic.
/ Chains and binders for trailering a compact tractor? #19
/ Chains and binders for trailering a compact tractor? #20
Straps may be legal but I've witnessed countless of tractors being hauled around here in different configurations.
This machines bounce. Straps will give and stretch. I cringe whenever I see machines bounce with chains much less straps.
2013 29ft. Larson LXI292 Boat with 2007 30ft Loadmaster T/A Boat Trailer (A64557)
2013 29ft. Larson...
INOP/NON - RUNNING 1997 Procraft Fish/Ski Boat (A65579)
INOP/NON - RUNNING...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
Massey Ferguson 461 Tractor (A65579)
Massey Ferguson...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2011 International 4300 Versalift VST60001 65ft. Insulated Bucket Truck (A64194)
2011 International...
