Chains and binders for trailering a compact tractor?
   / Chains and binders for trailering a compact tractor? #1
Blackgreyhound
Kubota L3719 HST with LA681 loader
What size/grade chains do I need to trailer my Kubota L3710 HST + FEL? It should be about 5,000# +/-. I just picked up a 16', 10K, CAM Superline Warrior trailer. No rush, but I want to be prepared when needed.
   / Chains and binders for trailering a compact tractor? #2
It's overkill for what you are hauling but I would go with 5/16" grade 70 chains, that way you are covered for future projects.
   / Chains and binders for trailering a compact tractor? #3
   / Chains and binders for trailering a compact tractor? #4
That’s the same I would do. There’s not much cost or weight savings going with a smaller chain so I don’t see any good reason to use smaller chain. And you won’t hurt that chain pulling with the tractor.
   / Chains and binders for trailering a compact tractor? #6
Get 5/16” chain and use 3/8” binders. That way, if you ever need to secure more weight you just need heavier chain.
   / Chains and binders for trailering a compact tractor? #7
Legal requirements is a WLL of at least half the actual load weight. You only need 2,500 lbs of securement. Four 1k ratchet straps is more than adequate.
Grade 70 1/4” chain has a WLL of 3,150. Two 1/4” G70 chains would be much more than your entire load.
I prefer to have more securement than required and only like having to run as few individual pieces as possible, for the most options.
   / Chains and binders for trailering a compact tractor? #8
Most binders cover 2 sizes. 5/16-3/8 binders would be fine. I don’t advise using 3/8-1/2 binders. I’ve done it and it works but the hooks are really too big.
   / Chains and binders for trailering a compact tractor? #9
I prefer the ease of use of ratchet straps to chains & binders. But after cutting a 15k rated strap on half with a very dull bumper I moved to something safer. Steel can cut nylon surprisingly quick but won't cut chain. I run 5/16" grade 70 & ratcheting binders. I have some of the over center binders but only use them if I'm stuffing a 2nd impliment on.
16' of trailer is going to be a bit tight for a Grand if you have a loader or impliment on. My 22' trailer can be tight for my L4060, loader & an impliment. You also need room to ballance things properly.
   / Chains and binders for trailering a compact tractor? #10
The part about having enough trailer to balance the tongue weight by moving the load fore or aft is often overlooked.
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
Hilti TE 2000-AVR Electric Jack Hammer (A49461)
Hilti TE 2000-AVR...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
PALLET OF SQUEEZE OFFS (A50854)
PALLET OF SQUEEZE...
