L3560 12volt Power Supply
/ L3560 12volt Power Supply #1
kubotacres
Gold Member
Louisiana
Kubota L3560 HST
From what I've read, the L60 series comes with a 12 volt harness behind the seat. I'm assuming that this is the cab only tractor since mine didn't come with one. I'm wanting to add a few small accessories and will need a 12 volt source. On my l3200 the power tap was under the rear fender. Can anybody with a cabbed l60 series tell me where the 12 volt harness runs to. I'm assuming that Kubota may have possibly have it hidden somewhere and this will give me a "head start" on where to look at. Notice "I" on the attached brochure. Thanks,
update.
It's connected to Wiring Harness B50703.
/ L3560 12volt Power Supply #3
I recently purchased a L3560 and would like to add the 12 volt power supply.
Is there an easy way to add this?
Is there a wiring harness that could be tapped into ?
i appreciate any information you can share with me.
Thank you
/ L3560 12volt Power Supply #4
Thank you
On my L3200 it was under the fender basically under the cup holder in the above photo. Same connector on my L4060hstc under the trim for a pillar on the left side in the cab. Ignition switched & I presume good for maybe up to 10@, although I've never bother checked fuses.
Thank you
On my l3560 it was under the seat. Just used some male taps.
/ L3560 12volt Power Supply #6
My L3560 is like Fallon's, under left column on the back side. IMG_20190929_105830.jpg
/ L3560 12volt Power Supply #7
So that is what that why is for, I have one on mine, but never taken the time to figure out what it was for.
/ L3560 12volt Power Supply #8
I wondered to until I saw this thread and Fallon's response. I checked it and t is keyed.
/ L3560 12volt Power Supply #10
New Holland 3930 (A60462)
New Holland 3930...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63118)
2019 Takeuchi TL8...
Electric Concrete Mixer (A61166)
Electric Concrete...
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
2013 Ford F-350 Pickup Truck, VIN # 1FT8W3BT5DEA61959 (A61165)
2013 Ford F-350...
(2) UNUSED 9.5L-16 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED 9.5L-16...
