L3560 12volt Power Supply
/ L3560 12volt Power Supply #1
kubotacres
Gold Member
Louisiana
Kubota L3560 HST
From what I've read, the L60 series comes with a 12 volt harness behind the seat. I'm assuming that this is the cab only tractor since mine didn't come with one. I'm wanting to add a few small accessories and will need a 12 volt source. On my l3200 the power tap was under the rear fender. Can anybody with a cabbed l60 series tell me where the 12 volt harness runs to. I'm assuming that Kubota may have possibly have it hidden somewhere and this will give me a "head start" on where to look at. Notice "I" on the attached brochure. Thanks,
update.
It's connected to Wiring Harness B50703.
/ L3560 12volt Power Supply #3
I recently purchased a L3560 and would like to add the 12 volt power supply.
Is there an easy way to add this?
Is there a wiring harness that could be tapped into ?
i appreciate any information you can share with me.
Thank you
/ L3560 12volt Power Supply #4
Thank you
On my L3200 it was under the fender basically under the cup holder in the above photo. Same connector on my L4060hstc under the trim for a pillar on the left side in the cab. Ignition switched & I presume good for maybe up to 10@, although I've never bother checked fuses.
Thank you
On my l3560 it was under the seat. Just used some male taps.
/ L3560 12volt Power Supply #6
My L3560 is like Fallon's, under left column on the back side. IMG_20190929_105830.jpg
/ L3560 12volt Power Supply #7
So that is what that why is for, I have one on mine, but never taken the time to figure out what it was for.
/ L3560 12volt Power Supply #8
I wondered to until I saw this thread and Fallon's response. I checked it and t is keyed.
/ L3560 12volt Power Supply #10
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2017 Chevrolet...
2016 Ram 1500 Crew Cab Pickup Truck (A61568)
2016 Ram 1500 Crew...
2018 TAKEUCHI TB260 EXCAVATOR (A62129)
2018 TAKEUCHI...
6055 (A61165)
6055 (A61165)
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
