What is this called?
/ What is this called? #1
Atchuuu
Gold Member
Kubota L4330 HSTC
Looking for one of these but don't know what it's called.
Thanks,
/ What is this called? #2
Where does it go, what does it do, and what does it attach to? Some will probably recognize it as is, or you may need to add another pic of it attached where it's used.
I ordered a new hydraulic cylinder that has the clevis pin on both ends and it won't fit. The old cylinder that I am replacing (as shown in photo) had a adapter that connected to the cylinder and then slid into the bracket on the rear of the tractor. The area circled in red is the part I am looking for.
I think it may be called a Clevis Knuckle
/ What is this called? #7
Not sure what it is called but there are many cylinders that are that design. Can you take it off the old cylinder and install on the new cylinder with out any length issue.
/ What is this called? #8
Kinda like what your looking for, just trying to help, Clevis panhard bar mount.
I will have to take it off the old cylinder and add another if I am going to use the new one. It will make the length a couple inches longer than the old one which should be okay. The photo of the cylinder on the Majester website looked it was the same as the old one. Clevis on one side and eye on the other but it had the Clevis on both.
Thanks for helping.
Thanks Imold-
That is the same concept. Now I have a name for something similar which may help me search for it. The bolts and mounting holes will keep this from working.
May have to just send the new cylinder back if possible and get a new one.
/ What is this called? #11
Thanks Imold-
I made something to do something similar from a weld on 3 point lower link and some scrap steel:
Aaron Z
Have your local machine shop make one.
I took my old cylinder to a hydraulic shop and they are rebuilding it. I asked them what the part was called and they said they did not know but were not aware of anyone selling it separately.
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2019 KENWORTH T680...
CAT 140M Motor Grader (A64047)
CAT 140M Motor...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
1977 FURNAS BANDSAW W/AUTOMATIC SHARPENER (A62131)
1977 FURNAS...
