Buying Advice Advice for first time tractor buyer
/ Advice for first time tractor buyer #1
Ecreps
looking to buy
Hello all, I hope you are doing well. I have come to the conclusion that I need a tractor to do some tasks around my new house, but I am having trouble deciding which direction to go. My main uses will be moving/grading/spreading both dirt and Gravel. I would like to use it to dig a foundation for a barn, but I can hire that out with the concrete work. Secondary use will be Brush hogging, as well as removing stumps, and planting trees. I am located in Ohio, with primarily Clay soil, so I wasn't sure if the smaller tractor would struggle with the tougher clay. I have roughly 5 acres. I have never owned a tractor before.
Originally I was pretty set on a LS MT125 with a FEL and Backhoe. The best price I have gotten on that is $15,500 delivered, or $12,200 delivered without the BH.
I went to look at them at a local dealer, and I also tried out the XJ 2025. It seemed more capable, which the FEL is. Best price there is $19,000 delivered, or $14,200 without the BH. I like that it has a larger frame, and more capable Front end loader, but unsure if it is actually needed for me.
I also went and looked at the Kubota Dealer as well. I looked over the BX2380, which seems roughly the equal of the MT125, but is about $2500 more. I like that the dealer is closer, parts availability may be easier, and resale will likely be higher (unsure if I will ever actually sell it though). The KKubota dealer also had an L2501 marked down to $16,900, which I would have jumped on, but it a GST and not an HST transmission. Does anyone have any thoughts one way or another on this? If I were just doing a bunch of brush hogging or tilling, this wouldn't worry me so much.
My initial thought is to get the XJ2025 with FEL, 5' rotary brush mower, and a rear blade. Wait on the backhoe until I really need it. I originally wanted to buy used, but it seems like most used small tractors are either really beat up, or almost the price of new. I know this has been asked 1000 times, and I appreciate any input.
Thanks.
/ Advice for first time tractor buyer #2
How many acres will you be tending, how many are in grass/pasture and do you have any steep hills you need to navigate/mow? A subcompact tractor is very sub and very compact and not particularly well suited to larger estates/fields. Ground clearance becomes an issue. I like to think of my bx as a riding lawn mower on steroids. It does a great job mowing and is marginal at everything else. A B series size gets you real tractor ground clearance and is much better around the farm but doesn't mow the lawn as well because it is not as nimble and is heavier plus it starts to lack in power. A L series is a nice small farm tractor but not good in the yard. The mx and m series are much better suited to farming work where weight is your friend but you don't want them in your yard. I mowed food plots this weekend with my b and was really, really missing the bulk, power, and ride of my grand L.
/ Advice for first time tractor buyer #3
Dealer and parts availability should play into your decision. I paid about $16000 for a Kubota L2501 new last July and added the FEL for another $4000. I mow ten acres with a five foot mower. The LS dealer is a lot closer but I've dealt with him in the past and found lots of promises but no support. I paid more for the Kubota and thus far am loving it. I did not get more power and thereby avoided the diesel particulate filter. My tractor is four wheel drive which is handy but not used often. It is also HST which I'm getting used to as my old tractor had a regular clutch and gearshift. My Kubota dealer provides excellent support though I understand not all do. Factor the dealer into you decision. That's where the support comes from. My LS dealer sells pet supplies - tractors are kind of a sideline. My Kubota dealer sells farm equipment and supports it.
All 5 of my acres are either yard or pasture, but I will not be doing any finish mowing the the Tractor. I have roughly 2 acres that needs managed. It is currently very overgrown, with small trees (3-4 ft tall), as well as similar height grass and bushes.
Can you compare and contrast the HST vs GST for things such as loader work, or tending driveways and snowplowing?
/ Advice for first time tractor buyer #5
For frequent direction or position changes, Hydro will work out better. Gear is better for long runs at near constant speeds where you need more guts.
If you want a BH, it's better to get it with the tractor so they're manufacturer matched. Adding one later will be more expensive also.
/ Advice for first time tractor buyer #6
My advice would be get one with hst vs geared.
I had a Kubota B7500 hst for my 7 acres; did about 5 acres of finish mowing, some loader work, and tilling. Was also my primary snow removal equipment with a front blower.
Later bought 7 acres of contiguous field acreage; too much for the B7500. Bought a MF1540 and decided to not get hsr to save some money. Big mistake. Hated it. Ended up trading it in for a hst model.
/ Advice for first time tractor buyer #7
I bought the HST even though it was $1000 extra as Kubota has NO warranty on the clutch. Then I learned the HST has a clutch, too. I do like the way I can set the RPM for PTO and get more or less travel speed via the HST. My terrain is not all level and it's nice to vary speed while mowing. With my old tractor I set the engine speed for PTO then picked the best gear combination for desired speed. I couldn't speed up or slow down without stopping and changing gears. HST works well for loader work as you needn't continually shift from forward to reverse. I got the tractor in July and have not seen snow yet but think HST would work well at that, too.
/ Advice for first time tractor buyer #8
I have never owned a tractor before. I have roughly 5 acres.
I went to look at them at a local dealer, and I also tried out the XJ 2025. It seemed more capable, which the FEL is. Best price there is $19,000 delivered, or $14,200 without the BH. I like that it has a larger frame, and more capable Front end loader.
XJ2025/FEL/HST is a subcompact tractor. Subcompact tractors are best regarded as wonderful lawn/finish mowers with the ability to do light landscaping tasks. However, finish mowing is not among your contemplated tractor applications. Nor is moving/grading/spreading dirt and gravel light landscaping. Some find a subcompact tractor enough for five acres, others want more tractor. I believe you will be happier with a 2,600 to 3,000 pound bare tractor weight machine, rather than a subcompact. Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a new, heavier tractor requires a lot of time. Depreciation on implements is worse than depreciation on a tractor.
You can use a FEL Bucket Spade attachment on a 2,600 to 3,000 pound bare weight tractor for tree planting.
MORE: https://www.tractorbynet.com/forums/attachments/328798-bucket-spade-today-fel-bucket.html
Digging tree stumps >3" is not work for a subcompact nor compact tractor. When you negotiate the barn foundation contract, include stump removal.
The small wheels and tires on a subcompact tractor will give you a rough ride mowing pasture.
Five reasons owner/operators trade up from Subcompact Tractors:​
More tractor weight increases tractive power pulling ground contact implements and logs, pushing a loader bucket into dirt and pushing snow.
More FEL lift capacity.
More ground clearance.
Three-range (3) HST (Lower LOW, Higher, HIGH) ~~ rather than two-range (2) HST.
Larger wheels and tires permit heavier tractors to bridge holes, ruts and tree debris with less operator perturbation.
New tractor operators are often intimidated by how unstable tractors with small front wheels and large rear wheels feel therefore tend to buy too light, too small as a result. ((Tractors seem to shrink after about twenty hours of operating experience.))
90% of new subcompact and compact tractors are sold with HST transmissions. HST excels where there will be a lot of maneuvering or when precise speed control is important, as in dumping gravel in a particular spot or mounting tractor implements. Other family members can be taught to operate HST tractors fairly easily.
GST and other gear type compact tractor transmissions are more suitable for long pulls, which would normally be in fields.
MORE: Advantages HST transmission tractor - Google Search
/ Advice for first time tractor buyer #10
Dont expect a lot with a small tractor and a small backhoe.
If its something you can dig with the reach and capacity of a shovel a small backhoe would make it so much more enjoyable.
Dont expect much reach. Even a mini excavator with a 12-14' reach gets to seem pretty small at times. But either would be a lot of fun!
/ Advice for first time tractor buyer #11
Have the backhoe work quoted. You can then decide if you want to invest in a BH. A good operator will be two or three times faster than you are. Renting can be an option but there is a learning curve so factor that in.
I have spent $500 in the past 6 years for BH work on my 20 acres. YMMV.
Also, the BH needs to be stored. Some are easier to connect than others. Have the dealer show you how to connect and remove the back hoe.
/ Advice for first time tractor buyer #12
/ Advice for first time tractor buyer #13
Several of us have proven (with pictures) Doktor Orange wrong on that point.
Sure you can do it, but it takes hours and beats up your machine. My backhoe alone weights 700 lbs more than your entire tractor and I dont dig them unless I absolutely have to. Advising someone not to buy a backhoe to dig up stumps is sound. Of course it can be used here and there for it...but that is not a reason to buy it in my opinion.
/ Advice for first time tractor buyer #14
For what the OP wants to do a tractor similar to my JD4200 with backhoe would work well. Some feel the small backhoes are useless but used in perspective they can be a great addition. Industrial backhoes come in different sizes with the small ones being toys compared to the large ones. It should also be noted that digging beyond five feet requires shoring or a cage which moves the job into a different category. Of coarse there are those who claim they can tell when deeper trenches may collapse. They have a tendency to make news.
Previously my B 7100 preformed most of the tasks the OP has listed other than having a backhoe. Chains add an unbelievable amount of traction. Load the bucket and put a little down force on the three point and pulling ability is greatly increase.
On ice and wet snow conditions you may find weight does not help traction.
Digging Rocks & Pulling Maple Log. It came up a twenty degree driveway slope. I do believe it weighed more
than the tractor.
/ Advice for first time tractor buyer #15
I always think that when I知 moving dirt or snow, then I get out to manually move what seems to be a small clump of dirt, or rock, or chunk of snow and I can稚 budge it.....
/ Advice for first time tractor buyer #16
I had a Kubota BX before I got a Jd2025. To a first time tractor owner and operator, a little bit bigger tractor can seem intimidating. BX tractors and there equivalent are great little machines, I owned one for 10 years but for the uses you list, I'd go bigger. I've attached a picture of a pine stump I dug out with my BX, filling the hole in and getting it out took me probably 4 hours and the BX wouldn't pull it out, I did that with my truck. They work for digging out a stump but not the most efficient, but if that's all you got......
/ Advice for first time tractor buyer #17
I had a Kubota BX before I got a Jd2025. To a first time tractor owner and operator, a little bit bigger tractor can seem intimidating. BX tractors and there equivalent are great little machines, I owned one for 10 years but for the uses you list, I'd go bigger. I've attached a picture of a pine stump I dug out with my BX, filling the hole in and getting it out took me probably 4 hours and the BX wouldn't pull it out, I did that with my truck. They work for digging out a stump but not the most efficient, but it that's all you got......
agree with this. You can dig stumps out with a small tractor backhoe but it takes a lot of time and is hard on the equipment. Here you can get a guy with a huge Kobelco tracked excavator hoe for a day for under $1,000 and they can do a stump like that in 10 minutes, dozens in a day, and fill and compact all of the holes.
Thanks for the input everyone, I have decided on getting the XJ2025H without the backhoe.
What brand rear blade and rotary cutter do you all reccomend? I assume the rear blades are all about the same?
/ Advice for first time tractor buyer #19
Yeah! Have fun and enjoy that new machine feeling!
/ Advice for first time tractor buyer #20
I just joined this site yesterday; looking for first ever tractor purchase now that I am retired. I have 54 acres but over 40 of it is mountain desert and natural with unworkable grades. I am concerned with defensible fire space so I wouldn’t old basically look to pull out low junipers and thick sage brush plus snow removal, small rock scooping, gravel-driveway maintenance and clearing trails for our ATVs. I have been looking at the Deere 3032 E, Kioti CK3510 or the Mahindra 2638 (all HST). Looking to stay under $25K with some implements. Not looking for a backhoe at this time. Any guidance would be appreciated. I don’t want anything huge but I don’t want to buy anything underpowered. If I don’t use it my wife will kill me for wasting money.
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
