Changed Hydraulic Hose. Now only Reverse No Forward.
/ Changed Hydraulic Hose. Now only Reverse No Forward. #1
Axl2011
Member
East Liverpool, Ohio
John Deere 300B
Tractor is a 1970's John Deere 300B.
So a hydraulic line underneath the tractor had a pinhole and was spraying fluid out. I replaced the line and bought hydraulic fluid. Replaced the line and filled up fluid. After repairing that I started up the tractor and the backhoe was working fine. When I went to move forward it feels like it goes in gear then the tires move slightly but then will not move but backing up works good. What could have happened???
/ Changed Hydraulic Hose. Now only Reverse No Forward. #2
I doubt the hose replacement has anything to do with the problem. I suspect the reverser linkage is not totally engaging forward.
/ Changed Hydraulic Hose. Now only Reverse No Forward. #3
I'm thinking possible air trapped somewhere. I had that on my loader with a hydrostat and I realize it's probably totally different. Trouble cleared itself in the course of trying to take pressure readings.
I dont think because when I put it in forward the tired move slightly but goes nowhere like no power
How would I bleed the air? I thought they self bleed through cylinders?
I was only on for maybe a minute when I realized the line was spraying and shut it right off.
How much oil did you lose and how long did you run it when it was low on oil?
/ Changed Hydraulic Hose. Now only Reverse No Forward. #8
I don't know how complex hydraulic systems work. I just got lucky.
I dont know either but you must have been correct! I had my dad come over to try and help me figure it out and when i went to show him it went forward. Now that is fixed but my radiator is cracked. Got to love how these things go. Haha
/ Changed Hydraulic Hose. Now only Reverse No Forward. #10
always something, that's my way of life
/ Changed Hydraulic Hose. Now only Reverse No Forward. #11
Thatç—´ the quickest way to get something to work right......bringing it in for repair or getting someone to come over to help you so that they think youæ±*e nuts.....
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2019 CATERPILLAR 316FL EXCAVATOR (A65053)
2019 CATERPILLAR...
Deutz 4-Cylinder Air-Cooled Industrial Diesel Engine (A63689)
Deutz 4-Cylinder...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
White 5409 9ft. Disc Mower (A65640)
White 5409 9ft...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
