Changed Hydraulic Hose. Now only Reverse No Forward.
/ Changed Hydraulic Hose. Now only Reverse No Forward. #1
Axl2011
Member
East Liverpool, Ohio
John Deere 300B
Tractor is a 1970's John Deere 300B.
So a hydraulic line underneath the tractor had a pinhole and was spraying fluid out. I replaced the line and bought hydraulic fluid. Replaced the line and filled up fluid. After repairing that I started up the tractor and the backhoe was working fine. When I went to move forward it feels like it goes in gear then the tires move slightly but then will not move but backing up works good. What could have happened???
/ Changed Hydraulic Hose. Now only Reverse No Forward. #2
I doubt the hose replacement has anything to do with the problem. I suspect the reverser linkage is not totally engaging forward.
/ Changed Hydraulic Hose. Now only Reverse No Forward. #3
I'm thinking possible air trapped somewhere. I had that on my loader with a hydrostat and I realize it's probably totally different. Trouble cleared itself in the course of trying to take pressure readings.
I dont think because when I put it in forward the tired move slightly but goes nowhere like no power
How would I bleed the air? I thought they self bleed through cylinders?
I was only on for maybe a minute when I realized the line was spraying and shut it right off.
How much oil did you lose and how long did you run it when it was low on oil?
/ Changed Hydraulic Hose. Now only Reverse No Forward. #8
I don't know how complex hydraulic systems work. I just got lucky.
I dont know either but you must have been correct! I had my dad come over to try and help me figure it out and when i went to show him it went forward. Now that is fixed but my radiator is cracked. Got to love how these things go. Haha
/ Changed Hydraulic Hose. Now only Reverse No Forward. #10
always something, that's my way of life
/ Changed Hydraulic Hose. Now only Reverse No Forward. #11
Thatç—´ the quickest way to get something to work right......bringing it in for repair or getting someone to come over to help you so that they think youæ±*e nuts.....
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
Used 20' Container (A62679)
Used 20' Container...
Dueling Tree (A65640)
IH Farmall B Tractor (A66285)
IH Farmall B...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2021 CATERPILLAR...
Pallet of 3 Large Electric Motors (A62679)
Pallet of 3 Large...
