Plasma issue...
/ Plasma issue... #21
I Totally messed up the tip of my Hypertherm 800 by trying to put some holes in a railroad track for use as a drag. I didn't predrill a hole either.
/ Plasma issue...
As mentioned, I did predrill a hole knowing (by reading) the challenge of piercing. That flat stock was all drilled with a drill press and was just used as a compass to make a smoother arc/circle. In fact, after going back to it later that day I did, freehand without the 'compass', manage to pierce through it. That hole is about the8 o'clock position. The predrilled hole was around the 1 (or 2) o'clock position. I did replace all consumables before doing that, by the way. The only coating on that steel plate was the bluing used to scribe/mark where to cut. I did pick up a valuable comment about being too slow. I think that's where the issue may be. I was too fast and need to be too slow.
Still learning. And, as I mentioned about practicing on the diamond plate, it is 1/2 inch, starting from a raw edge, this machine made a clean and even slice with tolerable edges. used a plywood stick for a straight guide. I was happy. I then made a large circle in some 3/4" ply to run the torch around the inside of that. It smoked the wood, burnt the torch, and just arbingated the whole test. Was disappointed.
Will do some more testing. Some more learning. Some more slowing down.
I really appreciate the help you all are giving me.
Oh yeah...a 3k machine is not in my retirement budget. But I can dream!
Thanks again.
/ Plasma issue... #23
Used in a CNC application, they don't drill a hole either.
/ Plasma issue... #24
Captain you may need a little practice with your plas., but your layout :thumbsup:
By the way, whatcha making?
/ Plasma issue... #25
Victor Cutmaster 42 will cut 1/2" pretty well but would struggle to pierce. Not quite like the Powermax 45 will though. Back to the Killowatt thing again. I have a 42 and enjoy the low air consumption compared to my 82.
You got me wondering. I don’t think I ever had to pierce 1/2” so I tried it with my 40 amp Miller.
EZ PZ
/ Plasma issue...
Fabbing a pump bracket for the fel. Along with that are the makings for new steel axle housings to replace the corroded aluminum ones for the Gator. Prefer to swing all the round stuff while in plate form, then cut the straight stuff.
/ Plasma issue... #29
mrcaptainbob. YES. The toughest part was finding 1/2” material to try.
I’m so cheap I like to keep every little piece of scrap.
/ Plasma issue... #30
A friend just showed me how he punched a one inch hole through 3/4" with his new iron worker. MUCH, MUCH nicer holes. lol
/ Plasma issue... #31
In that case cut the circles freehand. It may be less awkward than using your homemade circle guide. Dress the circumference with a grinder before doing the lathe work.
/ Plasma issue... #32
If possible to use a hand or bench mount punch, iron worker or punch press , PUNCHED holes absolutely RULE every time.
/ Plasma issue... #33
Also cost as much as a new truck! It did deform the 3/4" a wee bit.
Had to think of when a customer allowed me to use their Piranah Iron Worker to open up the holes in some mower blades. Like a gun going off!
/ Plasma issue... #35
Don't know if it has been mentioned or not. But did you take a reading at the outlet it's self, for amperage / volts? I have most likely over did the wiring on the outlet i use for my Plasma 50 Eastwood, i used #6. Only because my local hdwr. store had #10 or #6, no #8 unless sp. order. Ran 48' one way, has plenty of amps/volts. Also in the pic, it seems like the air isn't up enough to blow slag out of the way to be able to travel, just sayin. Inside of some cutters is a water seperater, does yours have this and is it clear of any obstructions, etc..? I have only cut up to 3/4", says can cut 7/8" but haven't found any metal that thick layin around here. Like Big Barn, i don't throw metal away much. Good Luck
/ Plasma issue... #36
Nothing wrong with 6ga wire. Except for my air compressor all my 230v is 6ga. As stated above it could be a bad ground to the work too.
/ Plasma issue...
There is a water separator in the unit. I added a larger one on the back, figuring two is better. The voltage at the plug is 120 each leg. Verified that when I installed it special for this. As for amps, I'm just going by what the machine display shows. Static and when in use. Air pressure is around 120 at the compressor, and it's recovery is, well, sorta good. The machine pressure is controlled by the user with the air gauge and pressure control knob.
I have the amps and the machine air pressure set to max for cutting the 1/2" stuff. Sunday's coming up and I plan on doing a bunch of testing on the diamond plate again. Circle cutting, freehand, guide, straight. Will see where tomorrow takes me.
Again, I really do appreciate the guidance.
/ Plasma issue... #38
I don’t know about Hypertherm, but I don’t drag on 1/2” material with my Miller 625 Extreme.
I drag on 1/2” and 3/4” with mine, no issues. I used to have pics of some 1/2” I pierced then cut. Had a pic somewhere of two 1/2” plates stacked and (roughly) severed from an edge start. I don’t recommend that, it’s messy, slow, and pointless.
/ Plasma issue... #39
I will definitely have to rethink what I do. Maybe I do drag with the stand-off tip if using a guide.
I know for certain I DON’T drag when NOT using a guide as I make a smoother cut without the friction.
I haven’t done much cutting in awhile. That’s my story and I’m sticking to it!
This is the only plasma cut pic I have.
/ Plasma issue... #40
I pretty much always drag and also use a guide/template. Only times I don't, it is for a creative something yard art. And I'm not that creative!
Deere 50D (A60462)
Deere 50D (A60462)
2021 CATERPILLAR 279D3 SKID STEER (A59910)
2021 CATERPILLAR...
Sullair 185DPQ 100psi Towable Air Compressor (A61572)
Sullair 185DPQ...
Sundowner Rancher Express 20FT Livestock Trailer (A63118)
Sundowner Rancher...
2014 KENWORTH T800 MIXER TRUCK (A63569)
2014 KENWORTH T800...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
