Phase Converters
/ Phase Converters #11
Visit something like automationdirect.com and look at their VFD (variable frequency drives). Many can take single phase 120 or 240 (depending on HP) and output 3 phase, 240 or even 480vac. As bonus you get softstart and variable speed capabilities. You will be limited to less than 2hp (120vac) or 3 hp (240vac) but pricing is typically below $250
/ Phase Converters #12
Have a vfd from Automotiondirect on my mill. The Grizzly electrics crapped out so I purchased a 3 ph motor and vfd. Works great, can still tap holes with the instant reverse.
/ Phase Converters #13
Most? VFDs expect 3 phase input. They will usually work perfectly fine off single phase input, but if you do that you have to derate them by a third or so. You can still get full power to your tool, you just have to spec out a bigger VFD to make it happen. It's usually speced out in the VFD manual.
A VFD also needs to be connected directly to the load & controlled at the VFD. You cant just turn off power between the VFD & motor or you'll kill the VFD. So they dont really work for powering multiple machines like you can with a rotary phase converter.
The ability to control frequency & motor speed is absolutely killer though. It's more of a project to properly wire in & configure a VFD than a rotary phase converter for stuff just expecting 3 phase in.
/ Phase Converters #14
I use three vfds to power 1 to 2.5 hp machines. each machine should have separate vfd. If you buy the right vfd for single phase input, there is ZERO derating. size for amps of your motor.
static converters can definitely harm some motors and should be last resort. rotary phase converters are great if you have multiple fixed rpm motors to run.
But don't overlook VFDs
/ Phase Converters #15
I have never seen a VFD that did not have to be derated from it's 3 phase rating to be fed with single phase. It's simply not possible as you are only feeding it with a fraction of the power.
/ Phase Converters #16
Rotary phase conversion (RPC) is what people used for home shops before the flood of cheap Variable Frequency Drives (VFD) that make them no longer the go-to option of choice. RPC use an idler motor to generate a wild leg that must be balanced for the design load using capacitors and even then the wild leg won’t be exactly the same as line voltage on the other two legs, but likely close enough for regular motors.
VFD create a three phase power that is much closer to spec than an RPC and allows cool features like variable speed, reverse, soft start, electronic braking, etc. Older VFD often relied on three phase input but could be de-rated if fed with single phase only and still produce a three phase output.
Newer VFDs are often designed for single phase input and provide three phase without derating. I have a source for VFDs that are single phase input vector drives up to 15 hp output and are blue tooth capable, and optimized for wood workers and machine operators. For a room full of three phase machines a large RPC will be cheaper than a VFD per machine, but for a home user that may have a lathe, Drill Press, TS, mill, etc I would recommend a VFD solution for all of the cool features they provide. I have a 15 hp RPC and a half dozen VFDs in the shop.
/ Phase Converters #17
Commercial units for HVAC are mostly three phase input as you note, however, there are many drives now that are designed for single phase input.
/ Phase Converters #20
YES, many work very nicely on single phase, some won't BUT YOU HAVE TO DERATE THEM. Call AC-TECH (Lenze) or A&B support if you don't believe me.
2007 MACK CTP (GRANITE) WINCH TRUCK (A60736)
2007 MACK CTP...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2011 TROXELL...
Kuhn FC400RG (A60462)
2006 TAKEUCHI TB135 EXCAVATOR (A62129)
2006 TAKEUCHI...
RoadTec RP190 (A61307)
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A60352)
2019 Allmand...
