Water Trough Algae - Pool Shock?
/ Water Trough Algae - Pool Shock? #22
Maybe ask around on some horse boards. :confused3:
Will a chat over a chess board do?
/ Water Trough Algae - Pool Shock? #23
I think the best way to treat your tanks is with liquid bleach I know you don’t want to use liquid but what if you used a self measuring bottle see attached link Tip n Pour Measuring Bottle, Tip n Pour Bottle for Pest Control then basically all you need to do is measure out your ounce or 2 ounces depending on the size of the tank. This would keep the process pretty simple. Ideally you will want to keep the chlorine level at 4 parts per million (which is safe for humans to drink) and still prevent algae growth. The down side is this would be a daily affair.
Maybe a livestock board. Horse boards are utterly dominated by complete whack-jobs. If I asked this question on one, I would have a hundred irate replies in a hour.
I think the best way to treat your tanks is with liquid bleach.
Like you, we live in Texas. Imagine transporting bleach in any spray, squeeze, tilt-dose, etc bottle in your vehicle, every day, 365 days a year, and employing it 2500 times a year. There will be accidents with liquid bleach, and accidents with liquid bleach are expensive and dangerous.
/ Water Trough Algae - Pool Shock? #26
I can only imagine. We were involved in 4H for 15 years with out kids. We always joked that there are two 4H fairs; one for the horse people, and one for everyone else. :laughing:
I'm not sure just chlorine will solve your algae issue. We always use an algaecide along with chlorine. Don't know how safe that stuff is for animals to drink. I mean, yeah, people might swallow a bit of water in a pool, but it's not like we're drinking gallons of it every day like a horse would.
/ Water Trough Algae - Pool Shock? #28
/ Water Trough Algae - Pool Shock? #31
algae can't grow without sunlight, so shading the troughs is the easiest maintenance free way. in my pool, I use chlorine tablets which has a chlorine stabilizer, and I never had a problem all summer with algae. in my pond, I use a UV sterilizer light, which gets fed by the waterfall pump. that works too, but then you have to have a pump system along with the sterilizer light, which gets plumbed into the pump..
/ Water Trough Algae - Pool Shock? #32
When I was a kid, we had a concrete trough for the cow and horse and we put a catfish in there that Dad said would keep it clean. I know we never emptied or cleaned it.
/ Water Trough Algae - Pool Shock? #33
The shade works. We have two troughs In the shade and one in direct sunlight. The one in the sunlight always has algae. When we head down to the barn we let the water run over. The horses have never had an issue drinking out of the water with algae in it. They usually shake their upper lip/muzzle around to move the water and get to the cleaner stuff below the surface. Adding a chemical to the water in my opinion is a vet bill waiting to happen.
/ Water Trough Algae - Pool Shock? #35
Am I the only person who uses vinegar? Cheap white vinegar. A little bit in my dog's water bucket, a little bit for the chickens, a little in the horse water trough. It changes the ph factor and helps keep algae from growing. I even drink a little vinegar in water often for health purposes. My horses actually seem to like the water better with vinegar in it. I keep a few goldfish in my water trough to eat the mosquito larvae and they all seem to be healthy also. Horses contaminate the trough so badly that it will need to be cleaned out on a regular basis anyway, but not quite as often, and it is easier to clean out any algae that does grow in there.
Also, to slow algae growth, limit the amount of light in the trough. Putting a roof over it to keep direct sunlight out helps a lot. One of my troughs is an old bathtub and I made a cover for it that covers about 2/3 of the tub keeping light (and leaves) out, but allowing enough room for an animal to drink from it.
/ Water Trough Algae - Pool Shock? #36
It was my job to treat the drinking water on a US Navy ship (in 1972)
The medical staff would sample the water, analyse it , and tell me how much chlorine to add to each of the 2,500 gallon tanks of water.
When we pulled into the Mediterranean Sea, the water that the ship made was so contaminated, I had to add 20X the usual amount of chlorine,,
All the guys would complain TO ME about the strong smell of the drinking water at the water fountains,,, :laughing:
So, in 1972, the correct answer to the question of what to use to treat the water was CHLORINE,,,:thumbsup:
/ Water Trough Algae - Pool Shock? #38
don't know how horses would react. I use Clorox in my cattle trough
/ Water Trough Algae - Pool Shock? #39
We have two 100 gallon troughs in our pasture. Both have had goldfish and I probably only clean them out once per year. One is on a fence row under some trees so it does a little better than the other which is in full sun. Horses, cows, and donkeys drink from them so there is frequently water moving. Maybe get rid of the goats? :D
/ Water Trough Algae - Pool Shock? #40
Algae in stock tanks is a constant problem. It's not a huge time waster to clean, but it would sure be nice if it didn't form in the first place. I have researched treating the water with bleach, but that requires 2-3 oz of household bleach per 50 gal trough, and the transport/handling/measuring and long term expense seems like it would be worse than just cleaning the troughs twice a week. A concentrated powder based product, however, might solve those problems as long as it dissolved and dispersed quickly enough to not harm any livestock that used the trough shortly after treatment. I looked into copper sulfate, but there are some sheep that drink from these troughs, so that is a non starter. The other species that use the troughs are horses, goats, dogs, and donkeys.
Has anyone used pool shock or other pool products successfully for this purpose, or anything else for that matter?
Our tank is under a roof, so it never gets direct sunlight. We put a couple goldfish in it and they keep it clean. I don't know how well they would do if they tank was out in the sun because of how hot it gets here, but where they are at, they live for years and do well without any feed from us.
KANDI KRUISER GOLF CART (A67714)
KANDI KRUISER GOLF...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
CAT 930 60" Forks (A68134)
CAT 930 60" Forks...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2015 WINSTON AP22024-DC 24FT EQUIPMENT TRAILER (A66091)
2015 WINSTON...
