Backhoe John Deere backhoe ,Help finding what model it is.
/ John Deere backhoe ,Help finding what model it is. #1
Tectal
Mountain City TN
MF 50A JD backhoe model unknown
I just bought a John Deere backhoe. It is close to a 301,A,B,Etc model. But all the documents I can find shows a wet break system. This JD has outboard dry disk brakes. like a car or truck just bigger.
Thanks all for any help.
/ John Deere backhoe ,Help finding what model it is. #2
If u can give me the #'s off the name plate on the inj. pump.. I can tell u the model & engine..
From top to bottom. model JDB331AL RPM. 2405
1507694 AR-49899
Thank you very much !
/ John Deere backhoe ,Help finding what model it is. #4
I've NEVER SEEN 1 PUMP FIT SO MANY DIFFERENT APPLICATIONS..
The engine is a>> 3152D
The applications are>> JD350 Crawler, JD300 THRU 700 Tractors { 300-400-500-600-700-301A}.. & a 1020 Tractor..
That's the best "I" can do.. Good luck.
/ John Deere backhoe ,Help finding what model it is. #5
My guess is your JD TLB with 152 cid engine,dry brakes is a model 510 tractor with added BH.
Thank you so much for trying Sir. That information will really help me should I need to replace the pump. Again Thank You.
Thank you very much. The motor is a 4 cylinder, And I think the 152 is the 3 cylinder?. It's an odd Tractor for sure. Again Thank you for the help.
