Backhoe John Deere backhoe ,Help finding what model it is.
/ John Deere backhoe ,Help finding what model it is. #1
Tectal
Mountain City TN
MF 50A JD backhoe model unknown
I just bought a John Deere backhoe. It is close to a 301,A,B,Etc model. But all the documents I can find shows a wet break system. This JD has outboard dry disk brakes. like a car or truck just bigger.
Thanks all for any help.
/ John Deere backhoe ,Help finding what model it is. #2
If u can give me the #'s off the name plate on the inj. pump.. I can tell u the model & engine..
From top to bottom. model JDB331AL RPM. 2405
1507694 AR-49899
Thank you very much !
/ John Deere backhoe ,Help finding what model it is. #4
I've NEVER SEEN 1 PUMP FIT SO MANY DIFFERENT APPLICATIONS..
The engine is a>> 3152D
The applications are>> JD350 Crawler, JD300 THRU 700 Tractors { 300-400-500-600-700-301A}.. & a 1020 Tractor..
That's the best "I" can do.. Good luck.
/ John Deere backhoe ,Help finding what model it is. #5
My guess is your JD TLB with 152 cid engine,dry brakes is a model 510 tractor with added BH.
Thank you so much for trying Sir. That information will really help me should I need to replace the pump. Again Thank You.
Thank you very much. The motor is a 4 cylinder, And I think the 152 is the 3 cylinder?. It's an odd Tractor for sure. Again Thank you for the help.
TANK MANIFOLD (A55745)
JOHN DEERE 6130M TRACTOR (A60430)
JOHN DEERE 6130M...
1986 KUBOTA R-400 WHEEL LOADER (A60429)
1986 KUBOTA R-400...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
GALVANIZED DOUBLE JETSKI TRAILER (A60432)
GALVANIZED DOUBLE...
2005 Nissan Frontier Crew Cab Pickup Truck (A59230)
2005 Nissan...
