Engine Warm up?
/ Engine Warm up? #1
melvinhatcher
Maryland
1948 John Deere M and 2016 Kubota L3301
I have a L3301 Kubota with a DPF exhaust filter. It is recommended not to idle the engine. My question is; how long do you warm up the engine on the L3301 and what rpm? :confused:
/ Engine Warm up? #2
I let my equipment warm up a minute or two unless the temp is below 40, then I go about 5 minutes at the most. Opinions will vary.
/ Engine Warm up? #3
THATS probably a DEALER question.. That way. when the DPF starts acting up you can say, "Bobby" told me to do it THAT way..
I think that info would be in the owners operating book.??
Personally I would go 3 minutes before moving on w/ the days chores..
What does the machine idle at NOW..
I think the regen will take place no lower than 1800 rpms.. U should keep your machine at or above THAT at all/most of the time..
Its also recommended that it be COOLED before shut down.. Let it idle for another 3 minutes before ending the day.. or just shutting it down for lunch.
You know what I mean..
/ Engine Warm up? #4
I don't strictly follow the manual's recommendations, but here they are for an L3301 (same as my L4060 and previous L3410) .
HST warmup is likely much more important in even moderate cold temps.
/ Engine Warm up? #5
'Above 32F' includes a pretty wide range of temps! Does Kubota seriously feel that tractors should be warmed up for 10 minutes in the summer time?
I usually go with a flexible 'few minutes', as suggested above, but then I'm fairly new to tractor ownership, so have no experience with failures yet. I want to take care of my tractor, but I don't want to rack up unnecessary hours. Taken literally and prescriptively, it could add a couple hours per week.
/ Engine Warm up?
My L3301 idle at 900 rpm at start up with the throttle close.
In warm weather I will let it idle at that for two to three minutes then move the throttle up to 1500 rpm for a minute or two while I slowly raise and lower the 3 pt. lift and front end loader.
I generally work the tractor around 1800 - 2000 rpm unless I am doing PTO work or heavy loader work.
After working starts engine speed is never lowered below 1800 rpm generally at 2000 rpm.
/ Engine Warm up? #7
I hear you... I believe the intent of the HST warmup chart is AT 32 deg f the machine should warmup for 10 minutes. I know it says something different. I generally idle for maybe 30 seconds, move the machine outside, then run it at 50% (1500rpm) for another few minutes in anything above freezing.
/ Engine Warm up? #8
To Melvin Hatcher,
Don't become too concerned about idling. When you idle a diesel engine with a DPF, the low engine temp produces more soot in the exhaust, which the DPF captures. Obviously, when the DPF reaches near max capacity, it needs to perform a regeneration burn to clear all the soot and start over fresh. So if you idle more, your DPF fills up faster, and you need more DPF regen cycles. More regen cycles is worse for your tractor from a couple of standpoints...much worse fuel economy during a regen, engine oil being diluted by fuel during the regen, and the finite lifespan of your DPF getting a little shorter with each one.
All these things can make one overly worried about how they use the machine. I have a Kubota L2501 (same machine as your 3301 but less horsepower and therefore no DPF). I also have a Kubota MX4800 which is obviously equipped with a DPF. Last fall I needed light for an outdoor project. I let my MX idle for well over an hour just to run headlights and aux lights. No concern whatsoever. Most Kubota owners with a DPF will never put enough hours one their machine to need any sort of DPF service or replacement. And as far as fuel diluting the crankcase oil, DPF tractors have a larger oil capacity than needed.
The Kubota regen process is automatic and seamless. If you are running your RPMs too low when the machine needs to regen, a warning light appears telling you to raise your RPM. The light goes out when they are high enough. I'd just go straight to full throttle. You also get a warning light when a regen is occurring, which goes out when it is finished.
If you need to shut your machine down during a regen, so be it. Don't worry about it. And you can always trigger one manually if need be.
My diesel pickup has a DPF as well, and I idle it as much as I please even though the same issues apply to the pickup as the tractor. If it's hot in the summer or cold in the winter, I idle away.
Just run your machine as if it didn't have a DPF and you are all set. I don't warm my tractors up in the summer, but I do in the winter.
/ Engine Warm up? #9
I usually let the 3301 warm up for a couple minutes and I very seldom run the tach below 2500rpm. Going on 5 years and very little regen cycles.
I have 3 kubotas and I'll let them all but the 3301 idle for a little bit. I don't like the fact that the oil is fuller after a regen. Can't be a good thing but everyone has their own way of doing things.
Dan
/ Engine Warm up? #10
I have a pre Tier 4 2009 Kubota M6040. One way or the other - fully warmed up before any hard jobs. About five minuets at 1200 rpm. Then drive to the job site. It will always be fully warmed up before any tough stuff. That's been the way I've done it - 38 years, two tractors.
/ Engine Warm up? #11
What was that bit about diluting crankcase oil with fuel? How is the lube oil involved in the exhaust system?
/ Engine Warm up? #13
Some common rail engines will inject fuel on the exhaust stroke to burn in the exhaust manifold and dpf to "clean" the system.
At times some of that fuel will migrate to the crankcase, I have not seen an engine that dumped enough to raise the oil level.
I have seen engines that had a small amount of fuel contamination in the oil that would mostly get cooked out when the engine got to temperature.
I have seen fuel dilution on older engines that where run to cold and not worked hard enough.
/ Engine Warm up? #15
I'm of the same mind as Oosik. Start, idle for 20-30 seconds, then move it out of the garage.
Bump the idle up to about 1200 and let run for 5-10 minutes depending on how cold it is outside. Once the temp needle stops rising it's ready to work.
/ Engine Warm up? #16
In the spring summer and fall, I'll start them, give'em 30-40 seconds to smooth out get the oil circulating then drive either to the implement thats going to be hooked up or if ready to go to the fuel tank to be topped off then just drive them easy for a few minutes.
In the winter it's a tad bit different, I park one close to the house and plug in the block heater.
I'll go out and get it started and running smooth bump the throttle up a bit 1200-1500 rpm then go back in an finish some more coffee before I climb back into the heated cab to start working it,.
/ Engine Warm up? #17
My regimen as well minus the block heater. Mine stay in the hay barn.
/ Engine Warm up? #19
Mine has a sticker on the window. At start up idle for 'at least one minute' at shut down idle for five minutes. This has to do with turbocharger.
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2021 Chevrolet...
2021 Chevrolet Silverado 2500HD Service Truck, VIN # 1GC2WLE77MF197329 (A61165)
2021 Chevrolet...
8086 (A61165)
8086 (A61165)
UNUSED WOLVERINE TDB-11-78W 78" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A61568)
2020 Broyhill Load...
