Electrical Wiring Question, - Ring Circuit?
/ Electrical Wiring Question, - Ring Circuit? #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
We are going to wire my SIL's office, and I was reading on the internet (yes, I know how dangerous that is , LOL! )
Anyways, I read about the "ring circuit" basically a circuit fed from both ends, typical in the UK,,
Is that against code in the USA?
I could see the advantage of that for a home office, having a much more stable voltage for an office setting.
A little extra wire for the office would be insignificant, if the outlet voltage was more stable,,
Hmmmm,, am I barking up the wrong tree even considering a ring circuit in the USA?? :confused:
Our home is located on a power grid ring circuit, basically 10 miles of distribution makes a loop, and both ends are fed.
If a branch falls, damaging a wire, only a few homes loose power, the other direction feeds the remaining part of the loop.
When they changed from a branch to a ring loop, our home voltage really stabilized,,,
/ Electrical Wiring Question, - Ring Circuit? #2
Seems like if the wires were not upsized you could burn up wires?
/ Electrical Wiring Question, - Ring Circuit? #6
further, if you have voltage problems on a regular branch circuit in a home, then you have other issues that need to be addressed.
/ Electrical Wiring Question, - Ring Circuit? #7
To keep voltage consistent, go with larger gauge feeding circuit. Used to have a hum in ceiling fans with 14ga. Changed to 10ga still on 15 amp circuit and hum is much less noticeable.
/ Electrical Wiring Question, - Ring Circuit? #8
Probably not what I was thinking of, but I had something conjured up in my meek little mind one time. Never even got to the point of asking if it was legal or would work.
Concept was to run a single larger AWG wire each for ground and neutral that would literally encircle or 'ring' the house basement. Each outlet or switch would tap those loop lines at pre-installed junction boxes. The only thing that would go back to the panel was the hot for each circuit. Concept was to save on the amount of wire needed overall.
/ Electrical Wiring Question, - Ring Circuit? #10
this is common on utility poles only. the idea is to ensure power to the pole in the event one feed goes down, the other feed then takes over.. it would be disastrous to do this inside a Building..
/ Electrical Wiring Question, - Ring Circuit? #11
They are prohibited for a number of reasons, the prohibition against parallel wiring being one.
Would you mind clarifying what you mean by parallel wiring?
I’m not an electrician, and I’ve done very little electrical work. I’m mostly just curious.
/ Electrical Wiring Question, - Ring Circuit? #12
I never heard of such a thing. My neighbour who got his electical engineering degree while working for Ontario Hydro (His Boss Didn't know, or I guess care what he did with his time) once complained during a power outage, why he can't be connected to two sources as there is another coming close to him from the other direction. I couldn't believe he would suggest that. Goes against so many basic electrical circuit rules.
/ Electrical Wiring Question, - Ring Circuit? #13
The British ring circuit is the best example. It is a circuit where the devices are fed from more than one direction. There is not an upstream or downstream
/ Electrical Wiring Question, - Ring Circuit? #14
I once scratched my head for hours not being able to turn a circuit off in a new house, by going through breakers, "one at a time".
/ Electrical Wiring Question, - Ring Circuit? #15
The way I see that if there is a break in the wiring you do not lose continuity as active and neutral are fed from both ends from the same source.
/ Electrical Wiring Question, - Ring Circuit? #16
Thank you. I don’t really understand, but maybe that’s OK.
/ Electrical Wiring Question, - Ring Circuit? #17
Sometimes telephones are connected in a ring circuit. There are also star and daisy chain configurations. I've never heard of house wiring done in a ring, and anything "out of the ordinary" will be a surprise to someone working on it. A "surprise" is not recommended for electrical wiring.
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2005 FRAC TANK 500BBL WHEELED (A68842)
2005 FRAC TANK...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
525 GAL WATER TANK (A68842)
525 GAL WATER TANK...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2012 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FORD F150...
