Fuel Station Build
/ Fuel Station Build #21
I used to drive down the road 3 miles to fuel up the tractor and then haul cans for the mower and RTV, but I was doing it so often. We already had a bulk fuel account for our generator, so went ahead and got two bulk tanks, one diesel and one gas. GREATEST choice ever. It is so nice having an "endless" amount of fuel on tap, like my own private gas station :laughing:
/ Fuel Station Build #22
Approx how long will each, gas and diesel, stay usable in a tank?
/ Fuel Station Build #23
Years on diesel with nothing added. Gasoline, I add PRI-G and it extends to years also.
/ Fuel Station Build #24
We use it fast enough that we don't have to worry. We have 300 gallons of both, and I do add stabilizer to the gas (NOT ethanol free) which we use mainly in our cars but also in our small engine stuff. The other tank I have on road diesel in (dyed is only 15-20 cents cheaper in my county), which we use in the tractor and mower and I put in my truck when I don't feel like going to the fuel station. The neighbor fills his 30hp tractor sometimes. It is also a backup for during a very long power outage and our generator needs fueling and the fuel truck can't get to us.
We get fuel delivered every 3 months or so
/ Fuel Station Build #25
Thanks for the info!
If my gas is going to sit for six months or so, is it worth it to find ethanol-free gas?
/ Fuel Station Build #26
Keep moisture out of your tank and you will have no issue with ethanol. The problem is you have to keep water away, you can't decant water off the bottom of the tank the way you could with E0.
Don't know what is available but would consider charcoal evaporation control plus any option for stopping moisture before it gets in the tank. I find E10 lasts longer in modern EPA-laden evaporation controlled automobile gas tanks than in motorcycles or small engines with simple vented gas tanks.
The problem is that ethanol-laced gasoline will carry water, and that no matter dissolved in solution or binary, water is bad for engine. Corrodes sensitive parts either way. There is no additive or magic elixir to change this fact. Those claiming to remedy ethanol problems only increase the ability to carry water in solution.
Diesel has a similar problem with bacteria and fungus. Once again the key to keep moisture out of the fuel.
Finally wrapping up this small project. Was able to build most of my shelter from leftovers from a fencing project I just finished. Used the leftover cedar pickets for trim and cut offs for shingles. Only had to buy a couple of pieces of siding. Makes good place to store extras such as def fluid for the loader, grease gun, tractor pins, chains, etc and keeps things looking decent next to the house. Pallet makes it easy to load on the trailer and take with me for off site projects or to refill.
2019-08-28_11-48-12
2019-08-28_11-58-53
/ Fuel Station Build #29
Ethanol attracts water like a sponge, if using ethanol it’s best to keep a full tank or a empty tank if it’s going to sit around for awhile, in the boat business we deal with a lot of water issues with folks who use ethanol and leave their fuel tanks half full or so and leave for a few weeks and come back only to have running issues or no start issues if not treated, about 15 years ago we started putting water separators on all boats and pontoons that get sold to help eliminate this problem.
Diesel on the other hand can sit for a long time if treated and kept in a dry environment before a person would need to worry about it going bad, I have used diesel in my 7.3 that’s close to two years old.
/ Fuel Station Build #30
2019-08-28_11-48-12
2019-08-28_11-58-53
Nice looking fuel station. Do you have any idea how much your set up weighs? I get tired of hauling cans to fuel my B26TLB. It doesn't leave the property very much. The BX2230 goes into town to mow and snowblow, so I can fuel it up at the station. Thanks. Jon
Not much empty. My pallet prob weighes more than the tank. Maybe 100-110 lbs both combined if I had to guess. Adding 60 gallons of diesel would bring it to about 520lbs total when full.
This picture confuses me. Why did you take your pallets off with the tractor chained down on the trailer?
Because this was about trip #9 or 10 to the Case dealer for repairs and I did not plan to bring it back home. The new Kubota should be ready next week if all of the add on options show up for install.
/ Fuel Station Build #34
I will never store ethanol gas in a bulk tank again. It has caused problems in three Polaris SxS’s, and a Jeep. Treating with Stabil and SeaFoam did not solve the water issues.
I now purchase non-ethanol and store in non vented cans.
Diesel is stored in a reefer tank and is treated with three additives. 50 gallons last about 3-4 months.
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
KUBOTA B3300SU TRACTOR (A64280)
KUBOTA B3300SU...
2008 Bush Hog 3715 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
2008 Bush Hog 3715...
GAS POWERED 6" AUGER & STAND UP 24" SHOP FAN (A64281)
GAS POWERED 6"...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
