Need ideas to build a "stone boat"
/ Need ideas to build a "stone boat" #61
No stone boat is needed when the ground is dry, we have had no rain in over three weeks,,
I chained the stone to the IH tractor,, and off we went,,
I actually think a stone boat would have been a negative as far as this move is concerned,
You can see that neither the tractor ,, or the stone tore up the grass,, (much,, :laughing:)
The stone is now at my shed,,,
/ Need ideas to build a "stone boat" #62
How do you use a stone boat,, when the rock weighs over 7,500 pounds,, and it is in a hole,,??
That stone is over 5X5 feet square,, and 28 to 34 inches thick.
You can use a stone arch if its built strong enough!
/ Need ideas to build a "stone boat" #63
Also if you manage to get it on its flattest side and a chain around it you can slope the dirt in the hole and drag it out then log arch or sled !
/ Need ideas to build a "stone boat" #65
Perhaps - - an ARK.
/ Need ideas to build a "stone boat" #69
The one that we have is about 3x8 feet, if memory serves me correctly, made from 3" oak planks, tapered on one end. It was made to pull behind a horse, and loaded with pry bars and sweat... lots of sweat.
/ Need ideas to build a "stone boat" #70
DANG, I would build that in a heartbeat,,, IF I had the tractor big enough to pull it,,, :eek:
:thumbsup:
You dont need that big a tractor, let the hydraulics do the prying. And of the drawbar lifts the rear end of your tractor, just use a longer drawbar. Wasnt it Archimedes who said "with a long enough lever, and a fulcrum, i can move the entire world" 😉
2001 VERMEER E550 VACUUM (A60736)
2001 VERMEER E550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2002 POLAR TANK (A60736)
2002 POLAR TANK...
500BBL WHEELED...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
