Need ideas to build a "stone boat"
   / Need ideas to build a "stone boat" #61
No stone boat is needed when the ground is dry, we have had no rain in over three weeks,,
I chained the stone to the IH tractor,, and off we went,,
I actually think a stone boat would have been a negative as far as this move is concerned,
You can see that neither the tractor ,, or the stone tore up the grass,, (much,, :laughing:)
The stone is now at my shed,,,
   / Need ideas to build a "stone boat" #62
How do you use a stone boat,, when the rock weighs over 7,500 pounds,, and it is in a hole,,??
That stone is over 5X5 feet square,, and 28 to 34 inches thick.
You can use a stone arch if its built strong enough!
   / Need ideas to build a "stone boat" #63
Also if you manage to get it on its flattest side and a chain around it you can slope the dirt in the hole and drag it out then log arch or sled !
   / Need ideas to build a "stone boat" #65
Perhaps - - an ARK.
   / Need ideas to build a "stone boat" #69
The one that we have is about 3x8 feet, if memory serves me correctly, made from 3" oak planks, tapered on one end. It was made to pull behind a horse, and loaded with pry bars and sweat... lots of sweat.
   / Need ideas to build a "stone boat" #70
DANG, I would build that in a heartbeat,,, IF I had the tractor big enough to pull it,,, :eek:
:thumbsup:
You dont need that big a tractor, let the hydraulics do the prying. And of the drawbar lifts the rear end of your tractor, just use a longer drawbar. Wasnt it Archimedes who said "with a long enough lever, and a fulcrum, i can move the entire world" 😉
TANK MANIFOLD (A55745)
2017 HAMM HD+140I DBL DRUM ROLLER (A60429)
2017 HAMM HD+140I...
2005 FREIGHTLINER WESTERN STAR DUMP TRUCK (A60430)
2005 FREIGHTLINER...
Utility Cart (A59231)
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2024 JCB 35Z (A60462)
