A backup camera for $50!!!!!!!!!!!
/ A backup camera for $50!!!!!!!!!!! #482
Backup cameras have a wide field of view. You need a camera with a narrow field of view:
The one I have on the front is 50 degrees and works gooder :D.
Correct Xfax. I think mine is 50° maybe 60°. I'll have to look at the book. The original camera, I bought was way too wide to be of much use.
/ A backup camera for $50!!!!!!!!!!! #483
Fallon, I started an FEL camera installation on my cab tractor a couple of years ago following your lead, but got sidetracked and never got back to it. From your post, it sounds like procrastination may be rewarded. Curious why you didn't use it much.
Screen brightness was always an issue, even with the hood on it was hard to see. The resolution ends up being pretty low, even the ones advertised as HD are pretty low. When you combine that with a little dirt it ends up being really bury.
/ A backup camera for $50!!!!!!!!!!! #484
I too switched to a better camera with a narrower field of view for the front. Mine is mounted on a pole off the loader, that another member (Waxman) did.
/ A backup camera for $50!!!!!!!!!!! #485
Which one do you use and do you have some screen pics from the seat?
I have one from Rearview Systems: Backup Camera Safety Kits & Accessories Paid more but it had a 5 year warranty. Installed it on 9-2-2012 and it is still working great.
The monitor is right of the steering wheel, low enough to see out the windshield over it. The camera is over the right front wheel, pointed down to see what is out there and see the the SSQA plate when changing attachments:
The view from the seat, moving a big round bale and the monitor showing what I can't see:
Looking up I see a tree trunk ahead. Looking at the monitor I see that I will miss it:
Approaching the cattle guard:
And a picture from behind, showing the clearance:
/ A backup camera for $50!!!!!!!!!!! #486
This is what I posted about 4 years ago.
I have to say that I am still disappointed with my system. The screen is just too small for working. I have a 7" monitor. And, I'm in a cab, but the sunlight is still too much for me to see enough detail.
I've put about 40 hours on my tractor in the past week, about half of that with the tiller and the other half with my blade doing some laser leveling. I find myself looking at my mirrors a lot more than looking at my monitor. Oh well....
For those without a cab, is this actually worthwhile doing?
After using it for a few months, and then having problems, I have not repaired it and have completely removed everything. It just was not worth the effort and money for me. I could never see enough detail in the monitor during daylight hours. And I have a cab tractor.
/ A backup camera for $50!!!!!!!!!!! #487
No sun problems with mine. You can see the sun on parts of the screen in some of the pictures, above.
/ A backup camera for $50!!!!!!!!!!! #488
LOL, my only problem is that my flashing strobe tints the blown snow a bright yellow.
Must say that for $50.00 I sure have gotten my money's worth.
Perhaps being cabbed is to my advantage.
I will admit when I do get very close to an obstruction (like wife's car I look back just to be sure I don't dent it)
/ A backup camera for $50!!!!!!!!!!! #489
I have had all the pieces for a couple of years, but haven't yet gotten around to doing an installation. My intended mounting method for the front camera is a Nootle ( [URL="http://www.grifiti.com/nootle/grifiti-nootle-magnetic-mini-ball-head-camera-stand.html"[/URL] ). My primary interest was in being able to monitor the tip of my hydraulic auger, but seeing the exact positioning of the grapple teeth will help with ripping up roots and stumps. Now, I just have to get off my rear and actually do the install!
/ A backup camera for $50!!!!!!!!!!! #490
Thanks! I think that offset cab works to your advantage with the camera setup, being able to eyeball the left while viewing the right on the screen.
/ A backup camera for $50!!!!!!!!!!! #491
You're welcome.
Yep, this shows the view and what the camera sees:
The offset cab works well with seeing the 42" forks also:
But the biggest advantage for this old man is the step-in cab:
/ A backup camera for $50!!!!!!!!!!! #492
Looking into getting the cheap setup to try out.
Where are you guys getting cheap narrow angle view cameras for the front. Tried searching amazon but most cameras are wide angle.
I think I will start with a rear view camera for hooking up attachments then set up the front one later.
my plan is to suction mount the monitor to the top right corner of the windshield and run the wiring through the roof. Seems like going through the roof is less complicated than down under the tractor, especially since I want to mount the camera high up to get a better view of the implement beyond my quick hitch.
/ A backup camera for $50!!!!!!!!!!! #493
one more question does the cheap monitor have the 1/4-20 female nut in the monitor or is it in the frame that clips onto the monitor.
/ A backup camera for $50!!!!!!!!!!! #494
/ A backup camera for $50!!!!!!!!!!! #495
Johnsstihl,
I've recently learned that cheaper isn't better. I'm by no means an expert but I'll tell you what I did and what I learned. I bought a set with monitor and 2 wired cameras on Amazon. $75-ish. I installed the rear in a fixed position on the back of the cab. The front I mounted to an industrial magnet so I could use it on the forks or the bucket. The wire connections on the front were an issue from day one and both cameras had problems in varying light conditions. Because it was video cable I didn't want to try shortening so I was left with a couple of fist sized balls of extra wiring just waiting to get snagged. I think it was the price point I went in at but my monitor didn't have good mounting options.
I just purchased a wireless system (it's not really wireless, the cameras need power but they transmit wirelessly) I went with a higher price point and the monitor looks much more versatile in mounting.
That's my .02¢. if you have any specific questions I'd be happy to help if I can. For the record going after a pallet on the ground if you can get the front camera working is sooooo easy.
/ A backup camera for $50!!!!!!!!!!! #496
I know not a new thread, lots of experiences and links that no linger work.
Looking to install both a front and rear camera, wireless, preferably IOS that I can use ipad as monitor. Would be great if both are on screen same time but selectable.
Anyone with good links or suggestions?
Thanks
/ A backup camera for $50!!!!!!!!!!! #497
Has anybody tried to put one on an open station tractor? Realize this is an very old discussion. I wanted to mount the camera and screen on a board attached to the fender, but was warned the picture would wash out. I thought about making a hood around the screen. Wonder how deep it would have to be?
Bill
/ A backup camera for $50!!!!!!!!!!! #498
Yea, mine is open station as well. Was thinking perhaps a hood, like for a drone screen, but possibly has to be a moveable mount that can be tilted/turned.
/ A backup camera for $50!!!!!!!!!!! #500
I would love one to see what's coming out the back of my top dresser. Being in the security business for thirty years or so, my only criteria is that it have a SONY CCD (Chip). That seems to make a world of difference in quality. I know people that bought cheap cameras and one by one they all slowly lost picture quality and then died. I don't like throwing money away, no matter how little.
2007 Gravely 260Z 60in. Zero Turn Commercial Mower (A61567)
2007 Gravely 260Z...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL4DL295841 (A61165)
INOP/NON-RUNNING...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2018 John Deere 310L EP Backhoe (A63109)
2018 John Deere...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2017 Chevrolet...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
