554 PTO height adjustment
/ 554 PTO height adjustment #1
aspg4
texarkana, ar
Massey Fergerson 135, TYM 554
Is there a height adjustment on the automatic PTO setting? When I have the cutter running on auto and raise the cutter only slightly the pto goes off. When on auto have to have the cutter so low that grass builds up in front of the cutter, and makes a big clump grass. I then have to raise the cutter to get rid of it. Then the field is left with big clumps of grass all over. It must be some sort of safety feature, but what does it really do?
/ 554 PTO height adjustment #2
Find the little switch on the 3 pt. Right behind the seat. Should have a bit of adjustment left in it.
It should be located very lose to the rockshaft as it uses just a small metal tab to contact the switch.
Thanks for the reply, but I can not find the switch you are referring to.
/ 554 PTO height adjustment #4
On my 454 the switch is under the cover for the control leavers.
2017 Ford Escape 4WD SUV (A59231)
2017 Ford Escape...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
CASE SV280 SKID STEER (A62129)
CASE SV280 SKID...
SET OF (10) ACE CATTLE PANELS W/CONNECTING JOINTS (A60736)
SET OF (10) ACE...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2014 FREIGHTLINER CASCADIA 125 6X2 MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
