ERR202 on my 4720
/ ERR202 on my 4720 #1
wango tango
Peoria IL
I'm getting an err202 after letting my 4720 sit for a couple months in a field. Some wires were chewed through by mice, I'm guessing. I'm getting ERR202 which is IAT out of range. I looked and sure enough, those wires were chewed through.
I fixed the wires with male/female connectors as best I could. I'm still getting the error.
Anyone have any thoughts? How can I troubleshoot? There is also a small green wire on the back of the alternator that was cut and still is. I dont know how I'm going to fix that, nor what it is. I dont know how they'd be related but I'm out of ideas.
/ ERR202 on my 4720
/ ERR202 on my 4720 #3
Can't help, but bet a service tech manual for your 4720 would be a big help.
/ ERR202 on my 4720
The local JD dealer was of no help. Anyone have access to a manual or know otherwise?
/ ERR202 on my 4720 #5
Shoot me your email and I can help you out with that
Joe
/ ERR202 on my 4720
Done!
I redid the connection between the cut wires. Same code. Grrr
/ ERR202 on my 4720 #7
Wango....whatever chewed up your tractor, I had chew up my wood splitter. I'm not sad that the critter headed south though. I hope you get some luck fixing your tractor! :drink:
/ ERR202 on my 4720
I cant seem to figure out this ERR202. First off, can someone else verify what that code is? I am thinking it is not what I thought it was. The sensor that i repaired the wires on was I believe the AL150289 - which is a pressure switch for a clogged filter.
So - anyone know what an ERR202 on my 4720 compact tractor is?
/ ERR202 on my 4720 #9
It is in fact the Intake Manifold Temperature error. There are several sub codes that you can access with the display to tell you wether it’s out of range high, out of range low etc. you will have to find the sensor and work backwards to the engine computer verifying the integrity of the wiring and the sensor itself in the process.
Now would be an excellent time to obtain a repair manual.
Find the sensor, and I can give you a few pointers as to where it terminates on the ECU
/ ERR202 on my 4720
It is in fact the Intake Manifold Temperature error. There are several sub codes that you can access with the display to tell you weather it痴 out of range high, out of range low etc. you will have to find the sensor and work backwards to the engine computer verifying the integrity of the wiring and the sensor itself in the process.
Thanks for the help!
I have access to the John Deere TM2137 Technical Manual for the "4000 twenty" series. Unfortunately I cannot find any reference to an IAT, Manifold Temp etc. I'm going to keep pouring through it but I'm good with searching - must be called something else?
/ ERR202 on my 4720 #11
I do not know that you have the correct manual. The 4520 and 4720 have a separate manual since they have a computer controlled engine I think starting at 2009. That sensor goes directly to the engine computer
/ ERR202 on my 4720
I'm sure having a time figuring this out. I've scoured the manual I have and there is no mention of an IAT or manifold temperature sensor. As I said I have access to the "John Deere TM2137 4120, 4320, 4520, 4720.pdf" manual. But I cant seem to find it.
/ ERR202 on my 4720 #15
you have the wrong manual. Check your serial number.
This should get you going in the right direction
  • Binder1.pdf
2021 CATERPILLAR 301.7CR EXCAVATOR (A62129)
2021 CATERPILLAR...
2020 INTERNATIONAL MV607 4X2 26FT NON CDL BOX TRUCK (A59906)
2020 INTERNATIONAL...
CAT Chassis Only (A59076)
CAT Chassis Only...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
