LS Tractor Sizes
/ LS Tractor Sizes #1
bsekf
Gold Member
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
The XU is the biggest Open Station LS Tractor? And it only has 24 inch tires? Is that correct?
/ LS Tractor Sizes #2
XP series is the biggest up to 100hp. Tire sizes are 24” front, 34” rear per LS website.
/ LS Tractor Sizes
But the XP is a cab tractor, I am only interested in open station.
Bill
/ LS Tractor Sizes #4
Yes, the XU6168 68hp tractor is the largest tractor LS makes that is open platform. It has a 24in wheel. Why is this shocking?
The XP8101 100hp (the largest) tractor has a 34in wheel.
The 24in is still a pretty big tire, for a utility tractor.
/ LS Tractor Sizes
I always equate bigger rubber to more rubber on the ground to more traction. My old 47hp compact Long LandTrac has 16.9x28 rears. Can't get as much beet juice in a 24 inch tire.
/ LS Tractor Sizes #6
Sounds legitimate, but, the patch that is actually contacting the ground is actually quite small. Even for large tires.
I have 17.5l - 24 tires on mine, smaller than the 19.5. We put 55 gallons of beet juice in each tire, thats 589lb per tire = 1178lbs of ballast! Beet juice also helps to 'squish' the tire creating a larger patch, which is great for traction.
I have no issues with traction with my tractor.
Replacing the tire when it gets worn out will be cheaper, filling with beet juice is cheaper, buying chains is cheaper... just things to consider.
/ LS Tractor Sizes #7
XP8084 can be had in open station
Front - 12.4-24
Rear - 18.4-30
Kuhn GMD 600 (A64127)
1994 Aeromax Semi Truck (A66285)
1994 Aeromax Semi...
2001 WESTERN STAR  4900E (A65643)
2001 WESTERN STAR...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
8" Mini Excavator Bucket (A66285)
8" Mini Excavator...
