dual grade rotary laser
/ dual grade rotary laser #1
3Ts
Elite Member
East Texas
Case, Kubota, John Deere
There was a thread a little while ago about rotary lasers and there were 2 favorites with Topcon being one of them. The ability to set the grade seemed to be important, but all the ones mentioned were a single grade. There is one from Johnson Level that claims dual slope.
Is the Johnson level any good? and does a dual slope really help? I can see where a single slope is useful, but a dual slope only if you're doing a field. Any thoughts?
https://www.amazon.com/Johnson-Level-Tool-99-028K-Electronic/dp/B074N1B1VY/ref=sr_1_18?keywords=grade+laser+level&qid=1564802787&s=gateway&sr=8-18
/ dual grade rotary laser #2
I have the Spectra Precision GL 422. A big part of my business is laser grading football, soccer, and athletic fields. It has served me well.
GL422N Grade Laser - Spectra Lasers
/ dual grade rotary laser #3
How do you know the grades being set on the model linked ? No screen with info that I can see. Having to set grades with out the screen can be done but is a process to do so.
/ dual grade rotary laser #4
I have a Spectra laser level and highly recommend it, but it's not duel grade. What are you using or going to use the grade for?
When setting drain lines, I set up my laser level and figure out the math on how far down I want it to be at different distances, then I just measure it to see where I'm at. It's very simple and easy to do. Mostly I use mine for building up the dirt for a foundation and I can figure out where I need to add or remove dirt every couple of feet over the area. I then mark each spot with some ground marking spray paint to know how many inches need to be added or removed. Then I use it to set my forms for the concrete foundation. Once the forms are set, I figure out where my toilets are going to be for my main drain lines, and start digging. Depending on how far down I need to be to tie into the septic, or city sewer line, I do the math and figure out how many inches I want to drop over that distance, then divide it up to every 20 feet or so and measure the depth as I'm digging. The entire process only takes a couple minutes to set up, so I've never felt any need for anything else.
/ dual grade rotary laser #5
I bought a Topcon RL-H4C Single slope from Tiger Supplies. Great people to deal with and great pricing.
/ dual grade rotary laser #6
That was my thread... the CTS/Berger laser was a good deal & worked great level (H or V) but painful to setup for slope (and only single slope).
It went back & I got a Dewalt. One of the new ones with bluetooth. Probably a little gimmicky for some functions & definitely a lot more expensive. But I can plug in a grade or slope in X or Y on my phone & get it set in under a minute. A hair more fiddly than you'd expect, but straight forward & you can set it straight without math, measuring or trying to figure out if the remote is working.
It didnt come with a tripod or grade rod like the CTS/BERGER did, so it's definitely a lot more expensive. None of the Topcon lasers would do vertical, which I need for a few projects. They were even more than the Dewalt though. I'd actually recomend the CTS/BERGER one if you can live with the single slope grade stuff that's tedious to setup. It was good value & a good price point. All the Johnson lasers I saw looked like they would have the same guess & check setup for grade.
Also, how often do you need grade in 2 different directions at different angles? I can do most everything by just rotating the laser in the right direction. Although by some of that logic I could just have spent the time fiddling with the remote on the CTS unit setting grade too I suppose.
Thanks, I'll check out the dewalt also. As for how often I need grade in 2 directions? I don't think very often, but my immediate need could make use of it, but after that, probably not. I've actually been trying to determine if I really need a laser at all since everything I've ever done has been with a long board and a level which works fine for 10 or 20 feet, but I've got a lot more area to sculpt with complex slopes and a lot more dirt to move than ever before.
What I've been doing was moving some dirt, waiting for the rain and see how it flows and puddles. When it dries out, I do some more grading and repeat. Now we're in our dry season and I'll have to do something different if I ever expect to get done.
/ dual grade rotary laser #8
If this question is for the GL 422, it does have a screen on the unit. I can set grades to hundreth's of a percent. In other words, I can set either, or both, the X and Y axis to 0.01% or more. I also have a remote control that I use to adjust the slope from inside my tractor.
I need the dual slope model, because I will often set my laser in the middle of a football field and slope it towards the goal, and towards the sideline. This will allow me to create a "pyramid" shape where the peak is at the 50 yard like and the lowest point is at each corner of the field.
/ dual grade rotary laser #9
Can someone maybe explain how the dual slope works? Single slope I am guessing, just means the whole thing is just off of vertical, at some angle, right? I have never even used my single slope function.
/ dual grade rotary laser #10
Dual slope allows me to slope in 2 directions. If I point my laser due North, I can slope it to the north or south, depending on if I set a positive slope percentage or a negative.
At the same time, I can slope it to the east or west, again depending on if I set a positive or negative slope.
/ dual grade rotary laser #11
So a different receiver is required for two channels so to speak?
/ dual grade rotary laser #12
No. I have only one receiver on my blade. The laser transmitter sends only one beam out, which is captured by the receiver. And that beam can be tilted either, or both, north/south, and east/west
/ dual grade rotary laser #13
Nope, the laser is the same. You can just adjust it from level N/S AND E/W. Single slope will only adjust N/S. Obviously you can rotate it before setting slope, but you get the idea.
Dual slope models are much more likely to be stable to a specific value. Like type in a 1% grade & it sets it in the X or Y plane. Single slope units seem to have no screen & adjust a tiny, probably fixed amount every time you hit the up or down arrow... if it's getting signal from the IR remote, which is drowned out by the sun at even short distances. Or walk back to the laser & hit a button. Either way you have to measure off a fixed distance & do the math then change the slope, then re-measure. Then repeat that loop a ton.
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
2020 MACK GRANITE GU713 DUMP TRUCK (A59910)
2020 MACK GRANITE...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
2007 International 8600 Parts Truck (A63118)
2007 International...
