Spreader advice for my property and needs
   / Spreader advice for my property and needs #1
SandraOpines
Marianna, FL
Kubota GL3560, Kubota GL4060
I am in need of a spreader and see a lot of complaints that spook me. I thought my needs were simple but apparently not. Here is what I need to accomplish.
We will ultimately have about 15 acres of field to spread nitrate.
about 3 acres (possibly more) that I will want to spread Black Kow Compost on as it is Centipede
The Centipede grass will also get Milorganite
Also seeding and other things
The complaints I see are:
Striping/overspray of Nitrate
Compost/Top Dressing plugs the spreader
I am looking at the Land Pride PFS series since the tow behind less expensive spreaders all said they won't spread top dressing. I don't really want to spend a ton of money and really didn't want 2 implements.
Any advice would be greatly appreciated!
   / Spreader advice for my property and needs #2
Educate me: What is nitrate? Do you buy nitrate or is it a by-product of farm crops? Is nitrate a fertilizer or a soil conditioner?
   / Spreader advice for my property and needs #3
   / Spreader advice for my property and needs #4
Getting ready to spread some goodness.....
   / Spreader advice for my property and needs #5
Compost will most likely not be spreadable with the land pride or any cone type spreader. From page 31 of the owners manual, “IMPORTANT: Product must be dry (not humid) without lumps to spread uniformly and correctly.” A top dresser does a great job for compost, manure and most fertilizers but dont work well for seed and they can be pricey.
I dont know of any one unit that will do all of those things well.
Millcreek Manufacturing Co., Mid-Size Top Dressers, Turf Tiger Cub
   / Spreader advice for my property and needs #6
If you are looking for something that spreads manure / compost and granulated fertilizer than you are out of luck.
If you are going to be spreading your compost more often, which I would thing would be the case, you need a pull behind manure spreader.
For the granulated fertilizer, if you have a co-op or bulk fertilizer dealer nearby you can more often than not use one of their spreaders if you buy from them. Benefit of that is if you can pull a soil sample you can get the right blend you need. They would load the amount you needed (15 acres let's say it's 100lbs an acre = 1500lbs) in the spreader, you pull it home and spread it then return it back to them empty. This would only be a once or twice a year thing at the most.
I should have said Nitrogen. NPK = nitrogen, phosphorus, and potassium. Field grass ie... Bahia LOVES Nitrogen which is why I said it that way. Sorry I foobar'd :D
   / Spreader advice for my property and needs #8
Spinner-type spreaders are more likely to ‘stripe’ fertilizer than the pendulum-type.
To minimize striping with a spinner spreader, set your rate to half and overlap the rows.
   / Spreader advice for my property and needs #9
Every farmer I know call it nitrate, including the feed store.
Thank you all sooooooooooo much for your valuable comments and insight.
I made a decision to just get a spreader for seeds and dry fertilizer. The teenagers (ages 14 and 15) will just have to be my compost spreaders :D Hey, I tried to do it mechanically. :D
Our local tractor dealer had a AgriFab broadcast spreader in their warehouse that was just a one off and we got a deep discount on it. It is 250 pound with ATV pin hitch as well as an adapter for ball hitch. Here is a couple of pics of it. I am quite pleased with this decision. I just couldn't justify the cost of something to spread the Black Kow Compost..... Sad but I will get over it.
2020 DRAGON ESP...
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
Cushman Electric Cart (A55851)
Cushman Electric...
202480 (A54757)
202480 (A54757)
