Spreader advice for my property and needs
   / Spreader advice for my property and needs #1
SandraOpines
Marianna, FL
Kubota GL3560, Kubota GL4060
I am in need of a spreader and see a lot of complaints that spook me. I thought my needs were simple but apparently not. Here is what I need to accomplish.
We will ultimately have about 15 acres of field to spread nitrate.
about 3 acres (possibly more) that I will want to spread Black Kow Compost on as it is Centipede
The Centipede grass will also get Milorganite
Also seeding and other things
The complaints I see are:
Striping/overspray of Nitrate
Compost/Top Dressing plugs the spreader
I am looking at the Land Pride PFS series since the tow behind less expensive spreaders all said they won't spread top dressing. I don't really want to spend a ton of money and really didn't want 2 implements.
Any advice would be greatly appreciated!
   / Spreader advice for my property and needs #2
Educate me: What is nitrate? Do you buy nitrate or is it a by-product of farm crops? Is nitrate a fertilizer or a soil conditioner?
   / Spreader advice for my property and needs #3
   / Spreader advice for my property and needs #4
Getting ready to spread some goodness.....
   / Spreader advice for my property and needs #5
Compost will most likely not be spreadable with the land pride or any cone type spreader. From page 31 of the owners manual, “IMPORTANT: Product must be dry (not humid) without lumps to spread uniformly and correctly.” A top dresser does a great job for compost, manure and most fertilizers but dont work well for seed and they can be pricey.
I dont know of any one unit that will do all of those things well.
Millcreek Manufacturing Co., Mid-Size Top Dressers, Turf Tiger Cub
   / Spreader advice for my property and needs #6
If you are looking for something that spreads manure / compost and granulated fertilizer than you are out of luck.
If you are going to be spreading your compost more often, which I would thing would be the case, you need a pull behind manure spreader.
For the granulated fertilizer, if you have a co-op or bulk fertilizer dealer nearby you can more often than not use one of their spreaders if you buy from them. Benefit of that is if you can pull a soil sample you can get the right blend you need. They would load the amount you needed (15 acres let's say it's 100lbs an acre = 1500lbs) in the spreader, you pull it home and spread it then return it back to them empty. This would only be a once or twice a year thing at the most.
I should have said Nitrogen. NPK = nitrogen, phosphorus, and potassium. Field grass ie... Bahia LOVES Nitrogen which is why I said it that way. Sorry I foobar'd :D
   / Spreader advice for my property and needs #8
Spinner-type spreaders are more likely to ‘stripe’ fertilizer than the pendulum-type.
To minimize striping with a spinner spreader, set your rate to half and overlap the rows.
   / Spreader advice for my property and needs #9
Every farmer I know call it nitrate, including the feed store.
Thank you all sooooooooooo much for your valuable comments and insight.
I made a decision to just get a spreader for seeds and dry fertilizer. The teenagers (ages 14 and 15) will just have to be my compost spreaders :D Hey, I tried to do it mechanically. :D
Our local tractor dealer had a AgriFab broadcast spreader in their warehouse that was just a one off and we got a deep discount on it. It is 250 pound with ATV pin hitch as well as an adapter for ball hitch. Here is a couple of pics of it. I am quite pleased with this decision. I just couldn't justify the cost of something to spread the Black Kow Compost..... Sad but I will get over it.
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2022 DODGE RAM 2500 SERVICE TRUCK (A58214)
2022 DODGE RAM...
Caterpillar 906M (A53317)
Caterpillar 906M...
2003 McCormick XTX 185 XtraSpeed Tractor (A56435)
2003 McCormick XTX...
2017 Ditch Witch FX50 T22S Towable Vacuum Excavator (A55973)
2017 Ditch Witch...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
