3-Point Hitch 3 point hitch connector
/ 3 point hitch connector #1
nestorint
Yilan, Taiwan
Kubota ZL1-205
Hello everybody. I am a new member and just last week bought a used Kubota ZL1-202. Dealer gave me old, looks like 3 point quick hitch connector . Is this correct? IMG_20190803_103110.jpg
/ 3 point hitch connector #2
I wouldn't use it because you can't use a pto shaft with it on.
You right. Than if I cut central brucket in the middle so it will not interfere with PTO. It may work. Except it may compromise rigidity of this "contraption" :)
This is my tractor. Difficult to believe its 30 years old. Gray import from Japan. Japanese do take care of their machineries
/ 3 point hitch connector #4
If that's a quick attach bracket, why did they move the lower hooks so far inboard? If the one on the right in the photo is as far in as the one on the left (hard to see in the photo), then that thing looks as though it's designed to put implements designed for a subcompact tractor on to a CUT.
BTW, isn't that opening below the center of the cross brace high enough to allow the PTO to pass through? I guess it might depend on what kind of implement you are using.
/ 3 point hitch connector #5
I am not certain what that "contraption" is. it might be part of some kind of implement.
/ 3 point hitch connector #6
It looks like a thingamajig. Used on a 3 point hitch to attach a whatyamacallit.
/ 3 point hitch connector #7
Bingo. We have a winner.
I agree it looks like part of another piece of equipment just the way the lower hooks are so close together.
/ 3 point hitch connector #8
That was my first thought, certionally not a "quick hitch", believe the rest of the impliment it was used with is missing.... Might be a good "connector" if one were to mod it into a rear ballast or "work" platform/box though...
Probably a "bonus" part to sweeten the deal as dealer wanted to get rid of it becauseit was in the way and he could not find any use for it....
Dale
/ 3 point hitch connector #9
I was thinking it was from a old 3pt scoop bucket.
/ 3 point hitch connector #10
Proprietary hitch for proprietary tillers that Kubota uses on rice farming countries like Vietnam, Taiwan, and so on. Proprietary hitches used to be quite common on those older grey market tractors. This quick hitch in particular, would most like work with another proprietary attachments.
Can be barely seen here (white thingy):
View attachment 615833View attachment 615835
Yup, that seems like the same hitch
I will see if I can work with both(so far 2 pieces) of implements. Tiller, similar as on photo and carry all box I finish building as of right now
2015 BOBCAT T590 SKID STEER (A62129)
2015 BOBCAT T590...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
1995 GMC TOPKICK FUEL INJECTION CHASSIS TRUCK (A62130)
1995 GMC TOPKICK...
Claw Excavator Attachment (A61567)
Claw Excavator...
2020 INTERNATIONAL RH613 6X4 T/A DAY CAB TRACTOR (A59909)
2020 INTERNATIONAL...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
