Sun Covers for Tires
/ Sun Covers for Tires #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Does anyone know of a company that makes sun covers for tractor size tires? I'd like to help the tires last longer.
rScotty
/ Sun Covers for Tires #2
rScotty
Best sun cover for tractor tires is made of steel .....by... Morton Buildings!
/ Sun Covers for Tires #3
Hmmm... I don't know of anyone specifically but it does remind me of a Navy shop with a large industrial sewing machine. The sailors would make weather-proof coverings for various deck fittings.
Maybe try a chandler shop/website? Sail-maker? They'd just need measurements & a description/drawing of what you require.
/ Sun Covers for Tires #4
A cheapie solution: small tarps and bungie cords. Inexpensive to start and cheap to replace! Get the silver ones to reflect some of the heat.
/ Sun Covers for Tires #5
Thinking a wee bit more on the subject... a local furniture upholsterer should be able to knock up what you'd need. You'd just have to discuss what kind of material, design and dimensions.
Wheel cosies. :)
Wheel cosies. :)
I guess that's right. Or maybe call them tire cosies and let them protect the wheels too. I'd have thought that it would already be a commercial item - though I do sometimes see something similar on RVs that just sit there in the sun for 90% of the year. But apparently there's nothing for tractors even though they could use some protection too. This could be a business opportunity for someone. Around here a lot of people put a sun shade inside the windshield of the their car to protect and cool the inside. Something similar to protect expensive tractor tires seems like a natural.
rScotty
/ Sun Covers for Tires #8
Quick thought would be maybe look at some Grill covers. Some are pretty big ???
/ Sun Covers for Tires #9
That's what I do also....only for equipment that isn't used very often.
/ Sun Covers for Tires #10
West side of my house gets no shade. In trials, shading it reduced outside wall temp by 40^ on a typical sunny August day, 15-20 inside wall. (That's brutal sunlight, folks.)
I've hung a cheap silver tarp like a mural on that wall ever since. Costs me ~$20 every 2-3 years (wind shreds 'em) I buy 8 1/2' x 11 1/2' to have grommets on both long sides and a 'drop fit'. A large enough one could could be cut up. Most home sewing machines will stitch 4 plys of HFT tarp easily if you make your own covers.
Call a 'tent & tarp' shop if you have one local. Sunbrella (TM) or other polyester (boat cover grade) would last the longest of breathable mat'ls, and likely cost the most. UV kills stuff that laughs at weather extremes. Formula 303 is also my pick for slather-on protection of tires, vinyl, patio furniture, paint, recoil pads ...
/ Sun Covers for Tires #11
We have a local shop that makes anything similar made from tarp material. Like awnings, boat covers, car covers.....I'm SURE he could make tire covers.
/ Sun Covers for Tires #12
Rv repair centers probably throw away the 'extra length' of roof material. ( my wife used to work for one) It lasts for 10 - 15 years.
PORTA POTTY (A67714)
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
2017 Chevrolet Impala Sedan (A66738)
2017 Chevrolet...
2010 BRENNER TANK PUP TRAILER (A67714)
2010 BRENNER TANK...
500BBL WHEELED FRAC TANK (A67714)
500BBL WHEELED...
