Cylinder Within A Cylinder?
/ Cylinder Within A Cylinder? #3
Telescoping cylinder. Extended length can be much longer than retracted length, compared to a simple cylinder.
Telescopic cylinder - Wikipedia
telescoping hydraulic cylinder images
Bruce
/ Cylinder Within A Cylinder? #4
I think they are great for extension, but lack strength. That is because there is less surface are to act upon as the hydraulics push on the various stages of ram.
But they have been on dump trucks for years.
You can order them on Surplus Center, but get kind of expensive.
/ Cylinder Within A Cylinder? #5
Generally the applications where telescoping cylinders are used require more lift at the beginning of the stroke (dump bodies). In other cases the design advantage of short retracted length outweighs the design requirement that the maximum force required be met by the smallest diameter stage. They are not weak when properly engineered.
I don't think the cylinder shown on page 20 (see post #1) is a telescopic cylinder. The snap ring shown as item 13 would stop the extension of both the outer and inner pistons and there wouldn't be another stage(s) as in a telescopic cylinder. It appears that the double piston simply adds additional force rather than travel length. It's a bit perplexing to study as it's not what it first appears to be.
The item 5 would appear at first glance to be a rod, as we know it, but I'm thinking that all it does is act as a stop to keep the item 3 piston stationary. Notice that the fluid enters thru the clevis on the "rod end" as well as the post at the base end of the cylinder.
I believe it is a single acting cylinder with the two ports connected to the same pressure source.
/ Cylinder Within A Cylinder? #7
Yes, retract limiter, adjusted by a separate circuit on the control valve
/ Cylinder Within A Cylinder? #8
The parts diagram lists
5 - rod
4 - rod weldmt
3 - piston
1 - tube weldmt
It sure looks like a tube within a tube... never seen one before :confused3:
/ Cylinder Within A Cylinder? #9
They have full strength at the bottom and each step is weaker. A dump truck gets easier to lift the higher up it goes.
Retract limiter! Of course! You nailed it. I can see that now and thanks otherwise it may have kept me up all night. :)
One thing I'm not sure about is when piston/rod item 4 is extended by putting fluid into the ROD/CLEVIS end port, it appears that a vacuum would be created. Perhaps there is a feature in the circuit that allows "makeup fluid" to enter the base port of the cylinder to prevent the vacuum? The makeup volume wouldn't be great since it's only the area of the tubular cross section of the piston/rod.
I understand that fluid is put into the BASE port when adjusting the stroke limiter position. It's an interesting cylinder application at any rate.
John Deere 1025R Tractor (A61166)
John Deere 1025R...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2019 John Deere 700K LGP Crawler Dozer (A61166)
2019 John Deere...
429888 (A61165)
429888 (A61165)
2012 Volvo VNL Sleeper Truck, VIN # 4V4NC9KK7CN542997 (A61165)
2012 Volvo VNL...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
