Tractor Sizing How would you attack this problem? (tractor sizing, etc)
/ How would you attack this problem? (tractor sizing, etc) #1
beep chirp whirr
Olmsted County, MN
n/a - seeking
Hello! I've been lurking on TBN and other sites on and off for the psat few months, as I've been trying to decide how to approach the equipment I need to maintain my land. I can run myself (and have - a major "feature" of my decision process involves 'analysis paralysis') in circles over and over, or I can try and break out and solicit outside feedback. Well, here I am. I'm asking all you fine folks for your thoughts and opinions, to see how you would approach my situation.
I'm looking after two different lots; I've got a 2 acre lot myself (0.3 acres of grass at up to 15% grade; 1.5 acres of forest at up to a 22% grade, although the steepest trail is only 19% in parts) and I have a 3 acre lot that I help maintain as well (0.55 acres of grass; ~0.25 acres of light trees and grass; ~2 acres of forest; only significant grade is the gravel driveway at about a 9% grade).
What am I trying to accomplish?
At a minimum:
- lawn care for at least the first lot (mowing, annual aeration, etc)
- snow removal at least the first lot, but ideally both (just the fel+bucket, or snowthrower?)
- rehab then maintain existing paths through both forests (rotary cutter?)
It would be great if:
- help with forest maintenance/logging - trees die, the ability to lift/move trunks, haul wood, chip small branches, etc - thinking a lot about a grapple and a 3 point hitch chipper, for example
- move mulch/dirt/rock/firewood/x/y/z from drop point (typically driveway) to where needed (hello, fel)
- handle regrading of the gravel driveway in the second lot
- handle graveling additional section(s) as needed
- blaze new paths through forest
- pick up the occasional light pallet and move it
- lift/move/redistribute earth to terrace a new section on the hill in the first lot
How do I do it today?
- push mower
- aging, failing riding lawn mower
- no snow removal equipment yet (just moved back to the state of my birth; didn't need it for the past decade)
- no chipping today, burning brush, but would prefer to get more than that out of it (mulched tree stuff for forest paths, etc)
- hauling everything around by hand in a wheelbarrow
- shovels, rakes, etc - a bunch of human power
Sure, I can repair or replace the rider, source a snowthrower, and continue as is... but I'm wondering if there isn't a case for 'work smarter, not harder' here with a tractor and the appropriate implements.
So I've been debating tractors - subcompacts in particular, although I'll confess to having peeked at the compacts as well. I've been trying to figure out how to right size (or if it's even appropriate or is overkill) for what I'd like to accomplish. I'm also somewhat concerned about the grades present (in the first property, mainly - attaching a topo map of both), about the ability of a mmm vs some sort of 3point finish mower to handle same; the need for a snowthrower as opposed to just using the bucket (or a snow bucket, or a blade) on the fel.
I've been leaning more towards the Kubota stuff (the BX2380, or the B2301 maybe?) but I've looked at the LS MT125 and just started taking a peek at the NH WM25S... at least until I start thinking in the other direction and just repair/replacing the rider and sourcing a snowthrower.
So, now, I ask for your thoughts. How would you approach the work here?
/ How would you attack this problem? (tractor sizing, etc) #2
What is your budget? For you size a B series is right in the wheel house. If you every might get a larger track you may want to look at the L series. The belly mower is great on the B but you may want a RFM with the 2501 L series. If you don't have a lot of obstacles that is a good option. Good luck and keep us posted.
/ How would you attack this problem? (tractor sizing, etc) #3
For five acres either a subcompact or compact tractor could serve. 4-WD should provide traction on your sloped land with R4/industrial tires.
Subcompact tractors with a Mid Mount Mower have about 3" or ground clearance with mower attached, 9" ground clearance with mower removed. Removing and replacing MMM is easier than in the past but still not fun. Minimal 9" ground clearance can make working in woodland difficult. Subcompacts have two-range (2) HST transmissions. Subcompacts generally draw 48" wide implements.
Compact tractors of 1,600 - 1,800 pounds bare tractor weight have larger wheels and tires. Larger wheels yield greater ground clearance, usually at least 12", and a much smoother ride over rough ground. Compact tractors have greater FEL lift capacity than Subcompacts and usually have three-range (3) HST transmissions. If there is some distance between the two lots, you will appreciate the greater road speed of of a 'B' with the three range HST. Compact tractors generally draw 54" or 60" implements. Allowing for a 5" overlap in use, a considerable improvement over 48" implements.
Either a subcompact or compact tractor will operate a proprietary MMM equally well. The compact will be a TINY amount less maneuverable.
A (universal fit) Three Point Hitch mounted Finish Mower is much less costly than a proprietary MMM but also less maneuverable.
VIDEO: Comparing Finish Mowers (midmount VS 3-point) - Kubota B261 - YouTube
If you can afford a 1,600 - 1,800 pound Compact, go for it.
Five reasons owner/operators trade up from Subcompact Tractors:
More tractor weight.
More FEL lift capacity.
More ground clearance.
Three-range (3) HST (Lower LOW, Higher, HIGH) ~~ rather than two-range (2) HST.
Larger wheels and tires yield more tractive power pulling ground contact implements and logs, pushing a loader bucket into dirt and pushing snow.
Larger wheels and tires permit compact tractors to bridge holes, ruts and tree debris with less operator perturbation.
/ How would you attack this problem? (tractor sizing, etc) #4
Lets go by weight of the tractor. For moving snow with a bucket or plow or rear scraper I wouldn't want anything less than 2400 lbs for just the tractor. I'm thinking you get some snow up there in MN. Even with a snow blower, you can get a wider pathway with a larger blower a larger tractor can handle. For moving logs, the same weight. Lawn work, I'd get 6 ply turfs along with a set of chains or a $4000 zero turn.
As Jeff states, you get more capacity all around with a heavier machine.
Everything you describe is tough work. A mistake is to minimilize just how tough it is. I live on 5 acres as well with about your same topography, My 2500 lb tractor (closer to 4000 with fel, filled tires) has done work with so much more authority over my previous 1900 lb machine (closer to 3000 lb with same), I could kick myself for having to put up with the differences for so long.
I do not bring this over the manicured lawn as it has ag tires. 8,000 sq feet of lawn takes me less than an hour pushing a 28" mower along.
The most all around tire on a tractor for a person wanting to do everything I feel is a set of turfs with a set of chains. Turfs are quite good in snow and easy on the lawn. With chains, you pick up their compromises in the woods and anywhere more traction is needed. 2 link ladder chains would be all you need and they'd also help in protecting the tires from abrasions for the tougher stuff.
/ How would you attack this problem? (tractor sizing, etc) #5
Op,
I think for most of what you're looking for, a decent riding mower to mow around the house(s), and a subcompact tractor would get you what you're looking for, as long as your attachments are sized to your subcompact.
Snow removal. Yes, a FEL and bucket will work. It is also the slowest way to do it, but it works. An angled blade would be better, either off the 3pt hitch, or off the FEL. However, a snow blower would be better for keeping snow piles from stacking up around your parking/driveway areas. Being in MN, you'll get plenty of snow (as do we). Currently, I'm still using FEL and bucket (slow, but works), but if I don't start off the snow season by piling my snow far enough away, then late in winter, I start to run out of room to put it. Once the piles are "set" and hardened, it's much more difficult to push them back late in the year. With a snow blower, you can throw the snow farther away, and spread it more, reducing the need for snow piles. Plus, late in the year, you can throw the snow over the top of any existing piles. I would also recommend filling your rear tires with Rimguard. The rear ballast will help with traction while pushing/working snow piles.
Lawn care. You're going to need a lawn mower. I wouldn't use a subcompact, or compact for a primary lawn mower around houses and buildings. Just too hard to maneuver in tight places. A decent riding mower will be very useful, and can keep your "big" tractor from rutting up your lawn/grass areas when the ground is soft. With a riding mower, I'd go with a rear 3pt rotary mower for the "rough stuff". If you go with a subcompact and belly mower, you're going to have much more area to trim/weedeat by hand because you can't get the "big" tractor in there.
FEL/grapple work. Ok, now it really depends on "how big" the things are you want to grab, or scoop and haul. No way around it, if you want to lift heavy stuff, it's going to take a bigger tractor (compact) to have enough mass and lift capacity. How big of trees/logs are we talking about? Are you willing/able to cut those trees/logs up into smaller bites, so a subcompact can pick them up? You need not only enough lift capacity, but you need chassis weight of tractor. And you will need a suitable rear ballast weight before you lift anything meaningful. Be it either a dedicated ballast box, or a heavy enough attachment hanging off the 3pt hitch to give you the needed counter balance weight. Depending on what you're lifting, you may have to go into compact size chassis to do it. The rear tires filled with Rimguard will help here too. If you get big and heavy on your tractor, you'll want to limit how and when you drive it across your lawn, as the heavier chassis will leave marks or ruts in your nice grass areas.
Wood chipping. Uh oh. Now we're talking just straight horsepower. Depending on what kind of wood you're chipping (hard or soft wood), you may need 35-40 hp minimum at the pto to run that chipper. At least in the 8" Woods/Woodmaxx that I've looked at. And even then, you'll have to turn your input feed speed down on the chipper to keep from stalling the tractor. Now a small chipper/shredder can get by with less hp, but it limits the size of what you can chip. I guess it depends on how often, and how big you're going to be chipping. Maybe just rent a free standing (self powered) one for the occasional use.
Moving pallets. You did say "light", so about the only thing I'd say here is make sure whatever tractor you get, it has the SSQA option on the FEL. Some don't come with it as standard. That way you can find more common FEL attachments, like forklift forks.
/ How would you attack this problem? (tractor sizing, etc) #6
Those are the same machine, exactly. LS makes that for NH. Only difference is darker paint and higher price for the NH. Choice there REALLY comes down to whether you think you'll need to be seeing the dealer often or not. Parts are mostly interchangeable so you can get them at the NH dealer whichever brand machine you end up with. NH dealer probably won't want to service the LS under warranty though.
Can't speak to snow removal, but it should handle most everything else. I don't have a grapple, but be aware it will require some additional hydraulic connections.
/ How would you attack this problem? (tractor sizing, etc) #7
I echo the advice on a zero turn around your property. I mow about 2 1/2 acres with a 60" zero turn. I bought a commercial grade ZT because of the terrain and abuse it has seen. However once I get into my 60's in a few years I might get a cab tractor with finish mower as the heat, dust and time it takes to mow is already getting on my nerves. 2 1/2 acres takes me about 4 hrs on the ZT.
I would figure out the amount of HP you need at the PTO to operate the biggest implement and that will decide the size of tractor for you.
/ How would you attack this problem? (tractor sizing, etc) #8
In the past all the work that has been listed, other than chipper & snowblower, I have done using a Kubota B7100 HST with turfs. Chains, all four wheels, really make a traction difference. The smaller size makes for excellent manoeuvreability in tight places.
The biggest drawback was lift height limitations with the loader.
/ How would you attack this problem? (tractor sizing, etc) #9
^^ Looks to be around a 30 year old model, but I see a few in the $5,000 range with a few newer ones closer to $10,000.
/ How would you attack this problem? (tractor sizing, etc) #10
You don't need much of a mower to mow that much area. I would consider a compact tractor instead of the SC, the faster you can remove snow the better. A front mounted blower, a loader and a 5ft bush hog. I would stay around 25hp to avoid regens and all the EPA non sense..
/ How would you attack this problem? (tractor sizing, etc) #11
beep chirp whirr
Loader tasks:
Disclosure: Florida person writing about snow removal.
Snowblowers are for deep snow. Snowblowers do not do well with 2" to 4" of snow.
If you need to clear a road, just one lane, get a front V-plow so you can clear snow rapidly in one or two passes.
VIDEO: tractor snow v-plow - YouTube
If you need to clear a rectangle use your FEL bucket, possibly with Snow Edge or Edge Tamer additions.
VIDEO: SNOW EDGE TRACTOR - YouTube
If you need to clear a rectangle and have regular >4" snowfall buy a SSQA Snow Pusher Bucket for your FEL.
VIDEO: Tractor Snow Pusher - YouTube
Other tractor applications:
Yes, a fairly heavy Rotary Cutter and a Ratchet Rake bucket attachment.
VIDEO: ratchet rake brush clearing - YouTube
DIRECT VENDER: Ratchet Rake, LLC - All Terrain Rake, Snow Edge, Tractor attachment, Bucket attachment, Loader, Skid loader, Kubota, Skid steer, Landscape rake, Brush remover, York Rake, Harley Rake, Rock Rake, Tractor rake attachment, Construction attachment, New Holland, Bobcat, Fire safety, Home fire safety, Fire prevention, John Deere, skid steer attachment, tractor implement
With less than five acres of concern a grapple is overkill in price and will be underused. Allocate grapple money to upgrade from a subcompact tractor to a compact tractor.
Consider 38" (short) SSQA Pallet Forks.
You can tow large trees using chain from the tree to the tractor rear/center drawbar.
LINK: https://www.tractorbynet.com/forums...rs-cross-drawbars-illuminated.html?highlight=
I owned a Wallenstein chipper. PTO chippers require too much maintenance beginning the second year of use. Burn tree debris if permissible.
- lift/move/redistribute earth to terrace a new section on the hill in the first lot.
- move mulch/dirt/rock/firewood/x/y/z from drop point (typically driveway) to where needed.
FEL bucket.
Mid Mount Mower (MMM) ((expensive)) or Three Point Hitch Finish Mower. ((moderate cost))
VIDEO: Comparing Finish Mowers (midmount VS 3-point) - Kubota B26�1 - YouTube
/ How would you attack this problem? (tractor sizing, etc) #12
I see a lot of people recommend a tractor and a separate mower. Great advice if you have the money and the space to store them.
I just want one machine. I had a Kubota BX for 10 years and just bought a Deere 2025R. It similar in size to a kubota B tractor. Just my opinion but the only big advantage of JD is the auto connect deck. The mid mount mower comes off in just a couple of minutes. I would recommend a compact size if you can afford it.
I could do 40k for the solution, whatever combination of equipment that might end up being.
I don't disagree - it is tough work. If I was downplaying / minimizing it at all, it's due to family pressure. We've taken down trees, chunked, hauled them all by hand for 30+ years (5 so far this year, at least another 3-4 to go - downed and chunked by chainsaw, moved, split, etc by human power), so there's some questions about why looking into tooling to help with the task. Personally, I'm of the belief that humans are tool using creatures, and that there is such a thing as working smarter as opposed to harder. Which is kind of why I'm here, seeking advice from those of you who have already gone through this evolution, moving from 'lets do everything by hand, and who needs anything more than a push mower' and into the realm of 'hey, tools are great, lets use the right tool for the right job'.
As for tires, it was either going to be turfs (or turfs+chains as you recommend), or industrials, depending. I know Messicks has put out some interesting videos showing traction differences between them, and also showing how kind/unkind they are to grass. You all here have the experience working with this stuff out in the wild/real world, and that means more than whatever a glossy/brochure can say.
Agreed that I don't have a ton of grass between the two lots... and the first/primary lot isn't a bunch either (0.3 acres). I was debating the SC more because, well, entering the market here, and it looked like the SC would make a better mower. But if the overall recommendation is to split the mowing from the tractor due to size/terrain features, then that isn't much of a consideration any more. And honesty compels me to admit, I like the idea of having a little more capacity in the fel...
If I can make it work in the budget, I do have space to store both. I was originally thinking to try and accomplish everything in one machine, but if it's a better solution to split the duties (especially given size/terrain features) then that's what I'll do.
Given the suggestions so far, it sounds like bigger is better (C vs SC), and that I should consider splitting mowing out to a dedicated machine.
So a B2301 or B2601 (-1?) perhaps? Or the B2650? (or pick your poison from whatever other manufacturer out there - am not wedded to Kubota, just what I've done the most research on so far - if you think a Farmall 35A Series II is the better fit (or whatever, you know, just examples), please, let me know. You're the domain expert here, and I'm new to this domain.)
with the FEL w/ SSQA, not pin, and a ballast box, at a minimum (and a 3rd function valve and probably at least one rear remote, better to have and not need and all that)
Implements being:
- rotary cutter (maybe the rcr12 or the rcr15? or something else?)
- some sort of front blade for pushing snow < 4"
- optionally the 55" snowthrower for dealing with > 4" of snow
- passing on the grapple for now, drag stuff with chains or chunk and put into a carryall
- ratchet rake bucket attachment (and possibly the towed version as well?)
- box blade (and/or land plane? whatever the best approach for grading/regrading land/gravel/etc)
- small ssqa pallet forks
- quickhitch for 3pt?
- aerator for 3pt (or rent annually?)
And a separate mower, if splitting things off. I saw both a rider and a zero turn listed as suggestions. Using Kubota examples (again, not wedded to it, just the one I've done the most research on), so a T2290KWT-48 ? A Z122E ? A GR2120-2-48 ? I'll confess I hadn't looked much at mowers yet because I'd originally been thinking the One Machine To Rule Them All, but if it's legitimately the better solution (and it does sound like it might be, based on the comments so far), then I'll need to do more research in that direction as well.
My thanks to everyone who has taken the time to respond so far, I really appreciate it.
/ How would you attack this problem? (tractor sizing, etc) #14
Implements being:
This seems like a simple question, but it is slightly complicated to answer.
As you now know, the Three Point Hitch is a universal standard. With an economy tractor you have to back the tractor to the implement very precisely in order to insert the two LOWER LINK attachment pins. Many use an iron 'spud bar' to jockey the implement a tiny amount to make holes align, rather then moving the tractor repeatedly. So attaching implements to a 1,700 pound bare weight subcompact tractor, which will use light implements, is relatively easy.
Deluxe tractors have LOWER LINKS which telescope/adjust about 2-1/2", so the tractor does not have to be as precisely positioned. Deluxe tractors have telescoping LOWER LINK stabilizers too, which make implement connection easier. Implements for a 4,000 pound bare weight tractor weigh 500 pounds to 1,200 pounds; heavy implements are difficult to move manually.
VIDEO: Kubota Standard L Series L843 Telescopic Stabilizer kit (overview and install) - YouTube
Economy tractors often have an optional "quick hitch" attached to the LOWER LINKS. This allows LOWER LINKS to pass under pins, then raise, capturing LOWER LINK pins in a slot. Almost every implement manufacturer produces rear "Quick Hitches" as well as implements. The TOP LINK is not modified by the Quick Hitch. (The most popular Quick Hitch not associated with tractor brand affiliated implement producer is Pat's Quick Hitch, produced by Greenwell Manufacturing in Kentucky.)
When I was younger and less experienced with tractors I owned two economy tractors around 2,000 pounds bare tractor weight. Each had individual quirks connecting implements. At first I found connecting implements confounding, especially in hot Florida weather and I grudged the time and sweat involved. With experience connecting implements became easier. (I use my tractor 250 - 300 engine hours per year.)
Do you need a Quick Hitch?
What weight tractor and what weight implements will you buy?
How many implements will you own over time and how often will you exchange one for another?
(Quick Hitch stays on the tractor, so you only need one)
Can you afford a deluxe tractor, rather than an economy tractor?
Quick Hitch downsides:
QHs lengthen LOWER LINKS 3" to 4" so you need to make QH decision before you buy PTO powered implements, as the PTO shaft length has to be custom cut to fit the length of LOWER LINKS.
A QH does nothing to assist mating an implement PTO shaft to the PTO splines on the tractor. PTO mating is always a greasy struggle but another evolution that becomes simpler with experience and finding the appropriate spline lube.
Most tractor implements do not use tractor PTO power, THANK GOD.
Almost all NEW implements are compatible with QHs. Older implements not. So you may find QH is not compatible with old, used implements you may wish to buy.
So many who purchase QHs will be homeowners who use economy tractors around 80 engine hours per year and are not interested in spending time struggling with implement mounting.
VIDEO: tractor quick hitch - YouTube
I am dedicated to simplicity in everything tractor. I love the hitch on my deluxe Kubota 'Grand L' tractor at age 72 years. Now that I have 2,500 engine hours of tractor experience I could live with an economy tractor without a QH if budget required an economy tractor rather than a deluxe tractor.
/ How would you attack this problem? (tractor sizing, etc) #15
beep chirp whirr
Implements being:
Drag with chains or carry on SSQA Pallet Forks. PHOTOS
Using Pallet Forks you can usually push two tines under debris, then pick debris up.
Do not use your back to lift debris into a carryall.
Bucket attachment only. Buy the Ratchet Rake first. You may get along fine using the Ratchet Rake for grading for some time, while you ponder Box Blade and LPGS options.
Ratchet Rake // Today
6/09/2016​
This post concerns Ratchet Rakes Vs. light Box Blades, such as the 60" Land Pride BB1260/346 pounds/69 pounds per foot.
I searched for the weight of Kubota L3301 bucket but could not find a number. I presume L3301 bucket weighs approximately 240 pounds, extrapolating from other kubota specs. 68" Ratchet Rake weighs 88 pounds. Adding 240 + 88 = 328 pounds, pretty close to 346 pounds of BB1260 Box Blade.
In addition, the (operator controlled) weight of the FEL frame bears on the Ratchet Rake. Likewise, weight of the Three Point Hitch bears on the Box Blade. FEL frames weigh much more than ( 3X? 4X?) Three Point Hitch components. So, including some FEL weight, I guesstimate that ground contact pressure on Ratchet Rake and BB1260 would be at least equal, perhaps greater pressure on the Ratchet Rake.
Further in Ratchet Rake's favor you have articulation of bucket/RR combination in two planes from the operator's station and 1-1/2" serrated teeth on the Ratchet Rake.
Box Blade can be raised and lowered hydraulically from the operator's station. Box Blade angle of attack is adjustable via the Three Point Hitch Top Link, but not from the operator's station. Standard Box Blade does not have rippers, standard is a smooth cutting edge.
Ratchet Rake is capable of tearing up sod with its serrated teeth, the initial operation in much grading. The Ratchet Rake will not pull as large a load as a Box Blade but it may pull 35% of capacity of BB1260 per pass, with faster cycles. Ratchet Rake is more intuitive in operation than a Box Blade, which requires considerable experience to operate efficiently.
This is why I feel the Ratchet Rake is superior to light Box Blades for LIGHT grading.
I own both a Ratchet Rake and a Rollover Box Blade.
When I have heavy grading to do, I mount my 60"/625 pound (125 pounds per foot) Bush Hog (brand) Rollover Box Blade on the tractor's Three Point Hitch AND the Ratchet Rake on my FEL bucket.
/ How would you attack this problem? (tractor sizing, etc) #16
While a SCUT can mow, it shouldn't be considered a primary mower due to size, weight and maneuverability. There are a lot of places on a residential lot where they won't go, at least not easily. You'll find you need a smaller rider or walk behind mower for detail work. One could tailor and landscape the lot to eliminate a lot of those areas, but that takes even more work.
"- some sort of front blade for pushing snow < 4"
- optionally the 55" snowthrower for dealing with > 4" of snow"
There's a big difference in the machine required to push either of those. Even a riding mower can push a 4' blade and kits are readily available. SCUTs with loaders can push snow too. Blowers are a whole different issue.
As you price things out, you'll find blue paint costs a lot less than orange does with no loss of capability. Mine priced out at several thousand less than the orange version, which gave me room to buy a 48" tiller and a few other things.
/ How would you attack this problem? (tractor sizing, etc) #17
thing is for an acre or less which that is what it looks like here, you dont need much of a mower. When you look at the cost of a mower deck or pull behind new, then look at big box store rider or ZTR its about the same cost.
/ How would you attack this problem? (tractor sizing, etc) #18
Implements being:
I'm curious as to what method is being used now to clear snow at your properties? Are you hiring it done, and if so, what equipment is the contractor using? Are you satisfied with that method (as in, willing to duplicate), or are you unsatisfied and looking for other options?
As far as grapple/not-grapple,
Bear in mind the "folks" here that are trying to talk you OUT of getting a grapple, will NOT be volunteering to come help you cut up and move trees by hand. If you want a grapple, get a grapple. Only reason I don't have one is, where we currently reside, I just don't have to do much tree/brush work. If the place we relocate to needs a bunch of that work done, I'll be getting one. You'll need a 3rd function for your FEL, but you'll need that for a front blade (to pivot it hydraulically from the cab) anyway.
Strongly recommend SSQA capable FEL. It's usually standard on the "regular" brands, but you have to pay extra for it if you buy a brand in a "premium" color. I also concur with what another member said about pricing/cost. I saved $20K by NOT buying a green one. Let that soak in for a moment, Twenty. Thousand. Dollars... That buys SEVERAL good implements and leaves extra money in your pocket.
Mowers,
Lots of internet 1's and 0's have been slain in the arguments of "zero turns vs. riding mowers" dramas. A zero turn is a one trick pony. It mows grass, does it well, and is the "fastest" type of mower. They will almost always do nothing else at all. And they are very expensive. A riding mower is more versatile. It mows grass, does it well, but is slower-in-time-spent to mow the same areas. It will also pull small carts, sprayers, spreaders, aerators, dethatchers, etc, that a zero turn can't tow. Some guys will insist that if you don't spend $10-15K on a commercial zero turn, then you're not a real man. But $2K into an evil "big box store" riding mower (small lawn tractor), can save you a bunch of money that you can use to buy attachments for your "big" tractor (like a 3rd function, PLUS a grapple, PLUS an angled front blade). Plus you can pull small carts, etc, with it. Just think about it and decide for your own uses which way you're better served for your money.
Tires,
Turfs are probably the way to go, just know that they puncture more easily than R4's will. So if you're out in your tree'd areas, be more mindful about running over stuff with turf tires. I went with R4's and had them filled. But I'm probably more frequently loading down my FEL (round bales of hay, etc) than you will be, and I wanted the heavier duty tires for stiffer sidewall loading, and more puncture resistance out in my pasture.
I just moved back to Minnesota about four months ago; the one snow we've had since then that had any accumulation (maybe 2", in mid April), I dealt with the old fashioned way, by hand. That... wasn't the most fun, given how large the driveway is and the fact that I didn't have an actual snow shovel among my possessions. I returned from a six year stint on the west coast, and when I sold my house on the east coast, I sold all my tools for dealing with both the yard and the snow, given that I had no use for either on the west coast. The goal of this project is to make sure I'm equipped properly to handle what needs to be done for the land I have now (and to help with some family land too). What equipment I have or am using right now is all stuff I have access to from the family. When I started looking at everything I need/want to accomplish, I started to wonder if a small (originally subcompact, now compact maybe, based on feedback) didn't make more sense than doing the traditional thing in my family, which would have been a push mower and a push snowthrower, and continuing to do everything else by hand. I just felt that there was probably a better solution, which is why I'm looking around now.
/ How would you attack this problem? (tractor sizing, etc) #20
Mowers,
Tires,
I will kill some more zeroes and ones. And I like a lot of what you said and not flaming you here.
With that said though some of what you say just simply isnt true about ZTRs. For the most part a one trick pony yes. But You can tow with them, I do, has a little bracket just a like tractor I do it all the time, and it would pull a spreader and sprayer just as easy. Now your not loading it up and trailering, but my guess is you can haul just as much as much as the sears tractor or evil big box store tractors. Ive even seen snow blower attachments on them, but I wouldnt go down that road. As far as price yeah you dont need a 10-15k one for home owner use on a few acres or so. You can get a really nice one for about 5-7k. Or I got mine at Lowes for 2500 bucks and its going strong on year 5, your going to be all of 2500 bucks into a MMM.
Year: 2013 Make: Ram Model: C/V Vehicle Type: Van Mileage: 185,999 Plate: Body Type: 3 Door Van; (A61574)
Year: 2013 Make...
58in Padfoot Vibratory Roller Skid Steer Attachment (A61572)
58in Padfoot...
2022 John Deere DR16 Planter (A63111)
2022 John Deere...
2015 KOMATSU PC360LC-11 EXCAVATOR (A64279)
2015 KOMATSU...
Caterpillar 12H/140H/160H Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
