TC33D Keeps going through fuel shutoff solenoids
   / TC33D Keeps going through fuel shutoff solenoids #21
If this schematic applies to the tractor in question, It appears that the fuel solenoid energizes directly from the key switch. I see no "black box timer" between the key switch and the fuel control solenoid. Perhaps something is missed.
https://www.tractorbynet.com/forums...0288685-whats-tc33da-wiring-diagram-tc33d-jpg
If so, that would suggest that it energizes to allow fuel flow. I've not seen this method used with single wire solenoids. Certainly one could not start an engine without a good battery. ( That would be dumb! But hey! Modern technology ;-)
Regardless, positioning of the solenoid is critical! consult the service literature for specs and procedure.
Additional comments from the past
https://www.tractorbynet.com/forums/new-holland-owning-operating/214341-tc33-injection-problem.html
   / TC33D Keeps going through fuel shutoff solenoids #22
Powered through the key switch? With all the key switch issues that could be the smoking gun. Read the sticky thread on the TC33 at the top of this section (NH Owning/Operating).
   / TC33D Keeps going through fuel shutoff solenoids #24
These documnets may help.
  • TC33D Fuel Shotoff Circuit.pdf
  • TC33D Fuel Shotoff.pdf
   / TC33D Keeps going through fuel shutoff solenoids #25
It does have the washer/spacer.
when key is on there is 12vdc to the solenoid, this RETRACTS the solenoid. By "unscrewing" it you are mimicking the solenoid retracting thus allowing the fuel to flow to the engine.
There is no relay between the ignition and solenoid?
   / TC33D Keeps going through fuel shutoff solenoids #26
Is it this type? They must be adjusted so that the stopper fully retracts or they will burn out .
   / TC33D Keeps going through fuel shutoff solenoids #27
Look at the supplied PDF posted by thclimer. The "type" might be the same, but the configuration is different.
Bonus! The mounting position means NOTHING. The solenoid does it's thing by retracting into it's self.
The "bench test" procedure indicates that the solenoid should live forever, powered up to full activation while on the work bench.
Now the idea that a high resistance connection might actually draw MORE current gets a guy thinking.
Can a solenoid fully energized at 12.5V draw fewer amps than the same solenoid supplied with only 9V based on displacement? The voltage difference lost to connector or switch resistance.
Hmmmmmmmmmm?
An aside, I've always wondered what are the mechanical differences between and AC solenoid linear actuator and a DC solenoid linear actuator. What winding scheme is associated with each?
   / TC33D Keeps going through fuel shutoff solenoids #28
Hmmmmmmmmmm?
Who said anything about "mounting position" ?
I am talking about the ADJUSTABLE link rod ! IF the stop lever on the pump comes against its stopper BUT the plunger INSIDE the solenoid IS NOT on ITS stopper, the wingdings WILL GET HOT !
   / TC33D Keeps going through fuel shutoff solenoids #30
If u still have the original 1.?? it should have a part# on it..
Take that # & call a diesel fuel injection shop.. they might be able to get u an original at a lower cost than a dealer.?
That's "IF" u think the others are infer.
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A57024)
PENDING SELLER...
Ford 655C 2WD Cab Backhoe (A57024)
Ford 655C 2WD Cab...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A55852)
Pallet of...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
