Your towing rigs and trailers
/ Your towing rigs and trailers #3,341
Coming from five generations of railroaders, I know pretty much any full size truck can do the same (trains have very little rolling resistance). Just wondering if anyone is even considering such a thing...
/ Your towing rigs and trailers #3,342
The train is on wheels and level ground. Not impressed at all.
/ Your towing rigs and trailers #3,343
And have very low friction. That’s kinda the point of a train. Agree that it’s not impressive.
/ Your towing rigs and trailers #3,344
Yeah, obviously nowhere need 1 million pounds of actual force on the truck. My 4" recovery strap similar to what they're using is "only" rated for 27,000 lbs so probably much less than that in actual pulling power by the truck. My big thing is how far can you drive on a charge, and how long does it take to recharge? Being all electric means you'll have to plug it in eventually, and can't use a gas engine to recharge or extend range like hybrid vehicles. If you can't get 300-400 miles on it that's going to be tough.
/ Your towing rigs and trailers #3,345
I have wanted an electric F150 after they had one with 600 HP at an auto show in 2014. A 400 mile range would address my towing needs I expect. Currently I am just glad to have my 2010 F150 back from the body shop. I learned the hard way about the blind spot created my the factory tow mirror option.
/ Your towing rigs and trailers #3,346
Anyone that lives near Roanoke VA can visit the Transportation Museum that is in town.
They have a demo set up showing how you can move a massive weight by hand when on steel wheels, and tracks.
A much lower weight on rubber tires can hardly be moved at all.
Chevy did a TV ad ~30 years ago, pulling a very similar train,, with a dumb ol' gas engine,,,
/ Your towing rigs and trailers #3,347
Yeah, not a big deal.
I laugh every time I see Elon Musk's statement that a Tesla pickup will have a 300,000 pound towing capacity.
Sure a Toyota Tundra towed a space shuttle (super slow, probably with substantial modifications as well), but towing capacity is more than "what can you move eventually" and is now actually standardized (though I believe it's still voluntary; SAE J2807).
Presented without comment, man pulls train car with his teeth:
/ Your towing rigs and trailers #3,348
Tesla pulled the same type of stunt so Ford is just going for some EV attention.
/ Your towing rigs and trailers #3,349
Smoke and mirrors. I don't care how many train cars it will pull. I just want to know what kind of range it has empty, towing say a 5-6,000lb load or hauling X amount of payload. Those are the thing that I would be doing with it. I don't even live close to a railroad track. :)
/ Your towing rigs and trailers #3,350
Meh. As mentioned above, there is very little rolling resistance with solid wheels and a solid track under them. A small team of horses could probably do the same. I'd be more impressed if they showed the F150 stopping the train from 50mph...
Rob
/ Your towing rigs and trailers #3,351
Rob
When I was a kid the grain elevators would move grain cars with a 40 HP tractor but the guy on the brake screw wheel to work fast to stop the cars from rolling past the loading point.
/ Your towing rigs and trailers #3,353
I started my towing journey in a 2013 Silverado 2wd with the 5.3L and 3.08 rear axle. Car trailer is 18 steel deck, four feet of it is dove tail.
I rented this dump trailer a couple of times:
The second time, I off loaded over 14k, at the dump. The entire trailer was only rated at that much and my truck only rated to pull 6,900 lbs. I decided I needed a better tow vehicle.
Enter the 2014 F-350 with the 6.2L gasoline engine pushing a 4.30 limited slip differential. Bought it 12/30/2017 with less than 30k miles.
Then, I decided I needed my own dump trailer. 2018 Diamond C 24LPD 16 with some factory upgrades.
I use a GenY hitch. Overall, very pleased with it.
This combo has put a lot of work in. Very capable.
/ Your towing rigs and trailers #3,354
Like that truck sir. How do you like the 6.2? I loved a diesel when I owned one but don’t think I could justify the extra cost when I only two maybe 20x a year and usually not super heavy(although more equipment or larger hopefully is in my future). I currently have a 6.0 vortec in a 2003 Chevy 2500hd with 4.10 rear end. Pulls pretty good but I doubt I’ll own another Chevy, really dislike their frame coating and I’ve had too much hassle with it since buying my current rig.
/ Your towing rigs and trailers #3,355
The 6.2L is solid. Fuel mileage isn’t great at interstate speeds or with a lot of stop and go. In 2016, they upped the torque at a lower RPM. That would be cool. 2020 will have a 7.3L. I’m excited to see what that does.
I couldn’t justify the headaches of a new diesel. I regularly haul my trailer GVWR (14,900) and the truck does great, properly loaded. I’ve had over 20k behind it, a couple of times. On the bumper pull, it was slow, but not problematic. With the gooseneck, it wasn’t a big deal.
My truck with the tools, hitch, and me in it weighs about 8,880 lbs.
15k and under, no reason to mess with diesel, from my experience. 18k to 22k is the upper limit of what my truck should be yanking around. Over that 22ish, the diesel (or maybe the new 7.3L) is really better suited.
/ Your towing rigs and trailers #3,356
The 6.2L is solid. Fuel mileage isn稚 great at interstate speeds or with a lot of stop and go. In 2016, they upped the torque at a lower RPM. That would be cool. 2020 will have a 7.3L. I知 excited to see what that does.
I couldn稚 justify the headaches of a new diesel. I regularly haul my trailer GVWR (14,900) and the truck does great, properly loaded. I致e had over 20k behind it, a couple of times. On the bumper pull, it was slow, but not problematic. With the gooseneck, it wasn稚 a big deal.
/ Your towing rigs and trailers #3,357
Nice upgrades nik - looks quite capable.
wm - off for a week of wheeling..... you know how to live :thumbsup:
Rgds, D.
/ Your towing rigs and trailers #3,358
Saw this beefy trailer on I-66 today. Looks like they just chopped the rear end off a 53’ flat bed. Bet is has a **** of a payload!
/ Your towing rigs and trailers #3,359
No, it's built that way to deliver concrete blocks and other small, but heavy stuff behind a straight truck that has a crane on it. It's probably rated for about 35,000# GVW.
Aaron Z
/ Your towing rigs and trailers #3,360
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59908)
2020 FREIGHTLINER...
FLARE STAND (A60736)
2013 MAXX-D BUMPER PULL TRAILER (A60736)
2013 MAXX-D BUMPER...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
8'X28" Table with sink and dishwasher inlet (A60352)
8'X28" Table with...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
