Aluminum mig welding question
/ Aluminum mig welding question #1
Lucky Dog
Midland, MI
TYM 4820c
I'm trying to learn how to mig weld aluminum.
I have a Lincoln 210mp with a spool gun, and argon.
My question is that when I pull the trigger, the wire hits the piece, but there is no arc for a split second. I can feel the wire push back on the gun before it starts welding. Sometimes the wire will push off to the side and out of the weld area.
What am I doing wrong?
Thanks.
/ Aluminum mig welding question #2
Bad ground is the first thought
/ Aluminum mig welding question #3
Either bad ground or dirty material. Aluminum has to be super clean where your welding and also where your ground clamp is.
Thanks for the replies. I'll check my ground. I make sure the aluminum is clean, but to be honest, have not looked at the ground clamp. Maybe that needs a little cleaning also.
Thanks!
/ Aluminum mig welding question #5
Notorious problem- a lot of folks replace them.
/ Aluminum mig welding question #6
1> Plastic liner in mig gun, 2>Smooth drive rolls, 3> Contact tip one size bigger, 4> Good ground, 5> A book with list of curse words............
/ Aluminum mig welding question #7
5> memorize to save time. Write down newly created phrases for future reference.
/ Aluminum mig welding question #8
I think OP is trying the spool gun. 5 applies to both though!!
/ Aluminum mig welding question #9
^^^^^^^^^^^^^^^^^:thumbsup: 6> Open window before throwing hammer.
/ Aluminum mig welding question #10
No spool gun, the last time I mig welded aluminum I replaced liner with a plastic liner, but just remember to take it back out for steel welding. Although a spool gun might be a good option and my Miller Matic is built for it but I dont know.
/ Aluminum mig welding question #11
I suggest a cobra push pull system at about 3k and a digital Synergic twin pulse power supply at approx 7K. If this is a no go then be sure to secure the ground on clean aluminum and preset hotstart if available. if not. Start in the middle and work back. Good luck and enoy ! Aluminum is awesome.
/ Aluminum mig welding question #12
I can vouch for the Cobra push-pull system. I liked it. The power source mine was attached to, (Miller 350P) not so much.....
/ Aluminum mig welding question #15
Learn what true spray is and looks like. So many people try to short circuit weld aluminum.
/ Aluminum mig welding question #16
Check 3 things, ground- wire to clamp connection, welding wire dirty, or tip dirty.
Also spool gun connections.
gps trailers (A56859)
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A62130)
2006 FORD F-450...
New/Unused Landhonor 78in Quick Attach Rock Bucket (A61166)
New/Unused...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
204158 (A57193)
204158 (A57193)
CAT B30 HYDRAULIC HAMMER (A60736)
CAT B30 HYDRAULIC...
