Log Splitter Stutters
/ Log Splitter Stutters #1
helpfulbook
Adirondacks, NY
John Deere 4700 Woods Backhoe 750, 460 Loader, Woodmaxx SB-72
Hi Guys, I've been splitting a lot of firewood lately and I noticed the push arm on the splitter when it is retracting backwards stutters.
It only seems to do it after I'm splitting for a while and the machine gets warm.
Does anyone know what the reason may be?
Thank you,
George
/ Log Splitter Stutters #2
Easy one would be low fluid and lube the track.
Thank you, I have added fluid, just wasnt sure how much to put in and didnt want to over fill.
I will grease the track.
Thanks again,
George
/ Log Splitter Stutters #4
It should still have some in the reservoir with the ram fully extended but not overflowing when fully retracted.
/ Log Splitter Stutters #5
Check the fluid when it is warm/hot. It is amazing how much it expands when it heats up. If you overfill it while it is cold you can have quite a mess when it heats up DAMHIKT.
I don't know that I would grease the track. On mine that would just make a mess collecting dust and wood debris. If you use any lube it should probably be a dry lube.
Doug in SW IA
Yeah I can only see fluid at the bottom of the reservoir.
Doug in SW IA
I'll make sure when I check it when it is hot. I was afraid to open the cap when it was hot...LOL
Thinking it would act like a hot radiator.
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
Decorative Dinner Bell (A61569)
Decorative Dinner...
330 GALLON POLY TOTE W/ CAGE (A62131)
330 GALLON POLY...
TPL MECHANICS BODY LUBE SKID (A62130)
TPL MECHANICS BODY...
Wooden Wagon Wheel Table (A61569)
Wooden Wagon Wheel...
