Log Splitter Stutters
/ Log Splitter Stutters #1
helpfulbook
Adirondacks, NY
John Deere 4700 Woods Backhoe 750, 460 Loader, Woodmaxx SB-72
Hi Guys, I've been splitting a lot of firewood lately and I noticed the push arm on the splitter when it is retracting backwards stutters.
It only seems to do it after I'm splitting for a while and the machine gets warm.
Does anyone know what the reason may be?
Thank you,
George
/ Log Splitter Stutters #2
Easy one would be low fluid and lube the track.
Thank you, I have added fluid, just wasnt sure how much to put in and didnt want to over fill.
I will grease the track.
Thanks again,
George
/ Log Splitter Stutters #4
It should still have some in the reservoir with the ram fully extended but not overflowing when fully retracted.
/ Log Splitter Stutters #5
Check the fluid when it is warm/hot. It is amazing how much it expands when it heats up. If you overfill it while it is cold you can have quite a mess when it heats up DAMHIKT.
I don't know that I would grease the track. On mine that would just make a mess collecting dust and wood debris. If you use any lube it should probably be a dry lube.
Doug in SW IA
Yeah I can only see fluid at the bottom of the reservoir.
Doug in SW IA
I'll make sure when I check it when it is hot. I was afraid to open the cap when it was hot...LOL
Thinking it would act like a hot radiator.
2013 Mercedes-Benz E350 Sedan (A61569)
2013 Mercedes-Benz...
New/Unused Wolverine Quick Attach Trencher (A61166)
New/Unused...
2019 Kenworth T270 Flat Bed Dump Truck, VIN # 2NKHHM6X3KM358768 (A61165)
2019 Kenworth T270...
Wooden Rocking Horse (A61569)
Wooden Rocking...
2006 Lark United 18ft S/A Enclosed Trailer (A61569)
2006 Lark United...
UNUSED SDLANCH REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED SDLANCH...
